Need electrical HELP LK3054 Alternator
/ Need electrical HELP LK3054 Alternator #1
philshel
Oakhurst, CA
Kioti LK3054
I just found that the wires that connect to the rear of the alternator via the four connector plug have been ripped or chewed out of the connector. I have a manual but the wire colors/numbers do not match with the schematic. The plug has places for four separate connections but it appears as only two were used and I have about eight wires hanging loose with no idea what was where. It's a '90 model, can someone post or email a couple of good photos of the connector and wire loom for me.
Thanks,
Phil Adkins
philadkins@gmail.com
/ Need electrical HELP LK3054 Alternator #2
I dont know if this will help you cause my tractor is an 2002.
Dirtnut,
Thanks much, the pictures are perfect but it is a different alternator and does not correlate well to mine.
/ Need electrical HELP LK3054 Alternator #4
Dirtnut,
Can you post a pic or two of your rig and its wires, etc. And what make and model alternator you have on your rig. This may help someone here to determine what you need to do.
In the meantime try tracing backwards where the wires go to on your tractor's engine- this might narrow down what came from where, and eliminate unconnected wires from your choices.
Also send a pm to Wallace Equipment, they may be able to send you a schematic for your setup.
Post back results.
/ Need electrical HELP LK3054 Alternator #5
I think you want (philshel) to take pictures, i did post pictures of my alternator.I have the shop manual with the wiring diagrams but it may not help due to the age differance.If you want them let me know i can try to take pictures of them and post them.
/ Need electrical HELP LK3054 Alternator #6
If you provide the serial number of the tractor, we can help get things back where they belong.
All KIOTI Schematic color codes refer the the Harness wire color. The final wire tail and harness colors don't always match (some fru-pa-pa in the purchasing system). With the serial number we can figure out the wiring pattern.
/ Need electrical HELP LK3054 Alternator #7
Dirtnut,
You are correct- sorry- I wasn't paying close enough attention
:eek:
Thanks all for the help. I will post my serial and some photos as soon as I get the opportunity (once the rain drops down to a simple deluge). As I stated earlier, my schematic not only has different colors but also fewer wires listed. It may be a replacement/adapted alternator for all I know as I am the second owner.
OK folks I finally got some (blurry) photos of the alternator and wires. The serial number is:
826500612. There is a white plug which is visible in the photos, it had two connectors in it, one in the upper right spot and the other in the lower left. The wire colors are; 1 black, 1 blue, 1 red, 1 white, and 1 black with a yellow stripe.
/ Need electrical HELP LK3054 Alternator #11
Phil's tractor is a 1998. Should be good information.
/ Need electrical HELP LK3054 Alternator #12
Not much info there. Pic shows 2 wires and Phil has 5?, and unless your an electrical engineer, the schematic is of little use
/ Need electrical HELP LK3054 Alternator #13
OK, checked the pictures. That is an older style alternator. Give us a couple hours, we'll see if we can match it up to the plug.
Thanks, that would be great!
/ Need electrical HELP LK3054 Alternator #15
Oops! :eek: Sorry Phil - I'm getting old.
My LK3054 is a 1993 (I only wish it was a 1998).
/ Need electrical HELP LK3054 Alternator #16
We have contacted KIOTI Technical to make sure they agree with what we came up with. There are several different engineering updates for the LK3054charging system. Hope to hear back from them on Wednesday.
/ Need electrical HELP LK3054 Alternator #17
I've got a '98 LK3054. After reading your post I went and took a pic of my alternator. Yours look pretty much the same as mine. See the attached pic. It's not a real good pic, but if interested, I can point out colors and take better pictures.
Hillbilly,
It looks like your alternator only has two wires going to the connector, are there some unseen wires? Mine seems to have had five.
Just keeping the post alive
/ Need electrical HELP LK3054 Alternator #20
Looking at HB61's pic; seems there are at least two wires in the white plastic connector,and two more wires going to the battery post on the alternator. That leaves just one unaccounted for, and it very well may be hidden in the pic
