Our Outhouse
/ Our Outhouse #1
coreshot
Gold Member
Utah
Kubota BX24
The wife and I decided this year that we needed an outdoor bathroom up at our cabin property. We entertain quite a lot, and our RVs take on quite a bit of traffic that I would prefer didn't happen. I bought a refurbished 8X10 shed from a local manufacturer. Actually the sheds were the display units at Lowe's, and the builder decided to pull them off the lots and fix them back up and sell them.
My plan was to build a full service restroom, complete with toilet, garden tub/shower, and sink. I plan on using a propane on demand water heater, and a propane ventless heater to keep things comfortable. I framed off the 2 feet of shed by the original door, and built a divider wall for a small utility area.
I installed a new entry door for the bathroom area, as well as a window for ventilation. A few pics...
The lizards were a father's day gift from my boy. He bought them for me on a recent trip to Baja Mexico with his mother. What a boy!!
/ Our Outhouse #2
that looks really nice, it should last a long time. great idea
/ Our Outhouse
On a side note, the entire project got under way when I had our septic system installed earlier this spring. It includes several dumps around the pad, a concrete 1000 gallon septic tank and around 80 feet of leach feild down below the pad. They did an excellent job of installing it all. It was a challenge placing the shed precisely over the vertical dump when we brought it in, but all went well.
I installed raingutter down both sides of the shed, and plumbed them underground out to irrigate the scrub oak around the edge of the pad. Once I had trimmed out the window and door that I installed, the outside was pretty much complete. Now on to the inside...
We were trying to decide whether too go with a shower stall or a tub/shower combo. After going back and forth over the issue, we found a brand new garden tub on the local adsite for $100. We couldn't pass that up, so tub it is. The tub couldn't have been any bigger for an 8X8 foot bathroom, or we wouldn't have been able to use it. The new tub required us to replan the placement of fixtures in the rr, as there was only one way to install the tub.
Now I hadn't ever done any of this type of work, with framing and installing fixtures and all, so it was a learning process as I went. I ran the neccessary wiring for three light circuits and two outlets. The electrical will eventually be a solar/inverter system, so it will be a stand alone unit. Right now I have everything wired to my generator. After insulating everything with R-19 fiberglass, I started installing the tongue and groove. I went to a local log home manufacturer to purchase the wood, they had several different types/colors of wood. We went with one called blue stain pine. It has all different tones in it from browns to grays the yellows and reds. It really looks great when you apply the polyurethane waterproofing over it. Of course, I had to add a log up in the top for good measure. A few more pics...
/ Our Outhouse
After getting most of the wood done, it was on to tile. I put this step off as long as I could, because I had never done tile, and I was rather intimidated by it. It went well, and turned out as well as I had hoped. My boy had the idea to do the cut tiles along the front top on the tub, and it worked out good. Next, I installed the propane heater. It is a 300 sq. ft. unit, so it heats up my 65 sq.ft. area quite quickly. As for now, I am at a standstill as winter has arrived up there. I will post more photos as I make progress, but I am sure progress will be slow until next spring when I can get water to the building and install the water heater. What do y'all think?
/ Our Outhouse #5
Just an Idea, but you could put tile on the wall behind the tub and put in a shower head. Take a long piece of conduit and curve it to make a shower rod. Thread each end and attach it to the wall with bases. Then hang a curtain from it for those that like to shower. I hate to take a tub bath :( .
BTW.... Your outdoor shower/restroom is nicer than a lot of those I see in houses. My FIL just built one for the hunting club, but he just used OSB inside and a fiberglass shower unit. He put a 50 gallon gas hot water heater in his.
Chris
/ Our Outhouse
Those are exactly the plans we have. I have been holding off on the tile behind the tub to make sure I have everything plumbing wise done correctly. A long shower rod with a curtain on each side is the plan, so they close in the middle. The shower head actually comes out of a knothole in the ceiling.
Thanks for the kind words.
/ Our Outhouse #8
Great idea and looks good too. When you said outhouse I thought you meant the kind with a hole in the ground. I'm going to suggest something similar to the rest of the family for our cabin up north. Great job. Thanks for sharing your project and pics.
/ Our Outhouse #9
How's the skiing.??
Nicest outhouse I have ever seen though Snowbasin has the nicest bathrooms ever....but you already knew that, right.??
/ Our Outhouse
Are you gonna add a sauna to it?:D
If I leave that heater on high for too long, the entire room is a sauna;)
Thanks guys, I will post more as I progress.
/ Our Outhouse #13
Wow, that's some "outhouse" - geez, the ones I've "met" in my travels are pretty shabby compared to this Taj Mahal!!
/ Our Outhouse
I agree it's a little over the top, but it's more of a peace offering to my bride. She loves it down on the mounain, but I'm sure here are times when she would rather not deal with the work involved and go shopping or something. Yet, she is right there by my side week in and week out. I figure she deserves to be pampered a little with her own full service restroom.
/ Our Outhouse #15
If you're going to do it, you might as well do it to the extreme!!
From some of the pictures, it looks like a pretty incredible view that you have from there. Did you put in a window to take advantage of that view?
Eddie
/ Our Outhouse #16
The is actually a perfect application for a Sun-Mar composting toilet. Composting Toilets By Sun-Mar - The Environmental Solution I installed one on my farm years ago and it truly is easy to use , requires no plumbing and has absolutely no odor. My wife and I enjoy it so much that we decided to sell them.
Andy
/ Our Outhouse
Eddie
I wish I would have! I actually had the shed at my home in SLC for a while while I installed the door and window and such. I didn't realize how nice a big picture window by the tub would be intil I transferred the shed down to the mountain. Oh well, hopefully she won't spend THAT much time in there!:D
/ Our Outhouse
/ Our Outhouse #19
That's a great looking out house.I am planning a 12x12 gambrel shed with a home office loft.I was planning a shower stall,toilet and vanity.The size is dictated by a concrete pad that had a utility building on it.I can rebuild on the pad,but I can't build a bigger foot print with out dealing with permits.
/ Our Outhouse #20
Those look pretty slick. I'll have to read up on them when I get time.
We can assume you'll be "reading up" in that well made reading room;)
Looks tons better than some places I've had to meet nature's calling, nice work
Tom
