Looking for advice
/ Looking for advice #1
kcook
MI
Cub Lawn Tractor
Ive been looking for years, and we are starting to get things paid off so a tractor is closer than ever before. We want to get one before the market improves to much. I want to stick to the main brands Kubota, JD and Kioti. I have several great dealers in my area.
We own 4 ackers, I currently mow 1. I will be mowing another acker next year and will need to Brush cut 3 ackers now with more to come down the road. I have landscaping to do (moving stone and rocks around). And road and driveway maintence in winter and summer.
Money is tight but I hope to get tractor/loader, brush cutter and rear blade to start. Finish Mowing will be done with my current lawn tractor for a few more years.
I have been looking at JD 3032E and Kubota B3200. There are things I like about both units. Any comments on either unit? Price is with in 500 between the two with Kubota being the more exspensive. Both dealer I have been to are very good, great service department and have been around for many years!!
One thing I can tell you BH is not on the plate at all, to much money for the little I would need one. I also am not sure I need a Mid mount mower as I have a small tractor now.
I was thinking of larger tractor to do Brush hog and dirtworks. Some weeks/months I don't have time to spend all day on a tractor to do brush work.
Thanks
KC
/ Looking for advice #2
If you have your choices pinned down to those two. I would choose the one that feels most comfortable to you. You will be the one sitting an operating it for hours. If they both feel the same to you than I guess flip a coin.:D
Good luck I don't think you will go wrong. Enjoy your ride.
I have not sit or driven either.
KC
/ Looking for advice #4
I would like to have the features that I like on both on the same tractor....... :D Have the dealers show you how to maintain a constant height with your brush cutter on both models. If you are going to use the loader check to see if you can use the brakes to help steer if you are back dragging, or leveling dirt, etc. Both those things will favor the JD probably. I like the 3 range hydro on the B3200, the mid pto, and the ergonomics of the 4wd control, and some other ergonomic issues on the Kubota. See which feels the best, and decide which good things are most important to you.
/ Looking for advice #5
KC,
definitely drive them both, that may make up your mind for you. :) good luck with your choice
/ Looking for advice #6
If you test drive a Kubota B3200, you may want to make sure your bring the RPMs up to close to the PTO speed. There is a thread going now in the Kubota owning/operating section on vibration. When my wife and I were deciding on a model, we were alternating between a BX2350, a B2920, and a B7800. One thing we both noticed was the vibration in the engine of the B7800. I later read some threads about this issue and apparently the B3200 is experiencing similar issues with the 4 cyl. engine.
/ Looking for advice #7
With only 4 acres and less than that to mow, I'd say save some money and look at a 20 something hp tractor rather than the 30+ hp models. I took care of 5 acres, mostly bushhogged, with a 20hp Kioti CK20. I loved the tractor and it was the right size. I did wish it had a three speed hydro though. I think the newer Kubota B series would also be great (they have the three speed) and both JD and NH have similar size tractors too. If you know you will be working only on the 4 acres why invest in a larger tractor than necessary?
/ Looking for advice #8
I have customers maintaining seven acres with BX Kubota's not even getting into the size that you are picking.
A new B-series like a 2320 or 262o will leave some more money in your pocket for additional tools for the tractor.
Both my local dealers suggested the larger tractor to use a larger Brush hog for faster cutting time.
KC
/ Looking for advice #11
The difference of a 48" to a 60" bush hog would be 1.5 acres an hour to 2 acres an hour at four miles an hour cutting 80 percent of total width.
I have heard of five foot hogs on BX's without the top link fastened, that would mean that it could also be done here. I would be sure of level ground and a loader on the front and if your worring about the horsepower step up to the larger one. The three range trans should be a big plus for putting the power out.
/ Looking for advice #13
KC
In that case I'd suggest a 75hp tractor with a 15ft batwing.
Yes, a larger mower will allow you to cut faster but you will not save that much time with a small plot like you are going to be mowing/bush hogging. A 20 something hp tractor is usually matched with a 48" bush hog and 60 inch finish mower. Add 12 inches plus a few hundred bucks to each implement if you go to a 30hp tractor. Remember that you will spend about 15 minutes before and after mowing with any size tractor just getting set up and closing things down. The time actually mowing would theoretically be about 15%-20% less but with one acre that will translate to about ten minutes. So, for an acre you might end up spending 70 minutes instead of 60 minutes with a larger tractor. Considering that you will pay more for the larger tractor, more for the larger implements, require more storage space etc etc, it really doesn't seem worth it for the acreage you are managing. It would make sense for a commercial operator where time is indeed money but for the rest of us it is an iffy proposition.
As I priced tractors I can get a nice 30 HP tractor for around 15500, some of the 20 hp tractors I priced around 14500+. So I can get 50% more tractor for about 1000 and move up to a larger size implement and stay in my price range.
Thanks
KC
/ Looking for advice #15
For 4 acres, I agree with the smaller horse power models, around 20 HP should be more than adequate. The time savings in brush hogging an acre or so is not worth it. The implements cost more as well. Get a 4 foot rotary cutter, a 54 inch to 60 inch midmount mower and a 48 inch front end loader. You could also get a small rotartiller for the back and maybe a snowblower or blade.
Don't forget each implement is going to cost more as well. And your wife will probably like driving a little smaller unit as well.
I have an older Kubota B6200 HST 4wd with only 15 HP and it works great for me. It was built in 1983, yep 26 years old and still working fine. I wouldn't mind another 4 HP but I already own it and bought it used from my brother.
You might also look for 200 - 300 hour used equipment to save money and get more implements for less investment. With 4 acres, it will still last you a lifetime.
/ Looking for advice #16
I just did a "Build Your Own" on Kubota's site.
You can get a B2320 4wd with HST with loader valve for $12,755.
This has 23 HP engine and 17 HP PTO. That will do what you need and you could be very proud and happy with it. Don't let the dealer sell you more than you need. Now if you had 15-20 acres, I could see a bigger tractor.
In the above tractor, you can add a loader, midmount mower and rotortiller and ballast box and get the whole thing for $20,500 and that's all retail, no dealing.
Up to you, of course, but you asked for advice.
15855 with a loader, my wife doens't like the SCUT, so we won't get one. With a deal Im sure my local dealer would be under 15800. When I walked in tto the Kubota dealer I asked about a 5' brush hog, he walked me over to a B3200 as a size to do the job.
KC
/ Looking for advice #18
Completely up to you. I consider the BX line a SCUT and the B line a CUT. You don't need a 5 foot brush hog for 4 acres. But I have run a 5 foot brush hog with my B6200 once but don't recommend it. a 4 footer would do you fine. After I brush hogged the first time, I just mow with the mmm.
/ Looking for advice #19
Thanks
KC
It will cost you well over $1000 to get a bigger tractor with similar features etc. Usually to go from a 20 something hp machine to an equivalent brand 30-32 hp will cost about $2000-4000 more. Bigger implements cost more too.
I will mow a small section with my lawn tractor the other 3 to 5 ackers with a brush hog once a couple of weeks.
"It will cost you well over $1000 to get a bigger tractor with similar features etc." I would agree with this. I plan on getting a rear blade only, then a brush hog down the road. I will use other implements from friends as needed. My thoughts are if I can get a larger tractor under my budget, get it.
KC
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A62131)
UNUSED PAIR OF 76"...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
