Tires Loading Tires with this?
/ Loading Tires with this? #1
mcd176
Gold Member
Wheeling, WV
Kubota M6800HD / Kubota B2150
/ Loading Tires with this? #3
Let's find out!
Get a gallon and a good thermometer (that goes down to -5F or what ever your freezer is set at ... you will also be verifying this if you try), mix up some WWF at 55:1 and see if you can make blue ice cubes. If you get cubes, try again at 20:1. If you still get cubes, put the rest of the WWF in your car's WWF reservoir?
-Jim
/ Loading Tires with this? #4
What Egon said.
This product does not change the freeze boil point at all. It would be no different than putting pure water in your tires. It is bug/dirt wash not anti-freeze.
/ Loading Tires with this? #5
Methanol only provides significant antifreeze to below zero (-20C) when it is diluted to no more than about 30% in water. Those numbers are not exact but close enough to say for sure that any compound that can be diluted 1:55 (about 2%) cannot possibly prevent freezing.
Regular full strength sold by the gallon type of windshield washer fluid is about 30% methanol as I recall. You need to use it straight if you want full protection.
/ Loading Tires with this? #7
I have been searching for the most cost effective windshield wash fluid to load my tires and found this GUNK Concentrate at Grainger, It says to dilute 1 gallon of concentrate to 55 gal of water, It is only $12 a gallon, What do you all think?
Wndshd Washer,Concentrate,128 oz,Blue - Automotive Fluids - Chemicals - Fleet & Vehicle Maintenance : Grainger Industrial Supply
as has already been pointed out.. this won't have any freeze protection. I'd load with rv holding tank antifreeze.
even if you mix it a lil weak.. a 'slushy' tire is ok.. you want to avoid the 'froze solid' tire.. etc.
soudnguy
Thanks guys, I didn't read the description close, I figure I will go to advance and buy the $1.99 a gallon -20 degrees WWF, They told me they have a few hundred gallons in stock!
-Mike
/ Loading Tires with this? #9
-Mike
See if they will give you a volume discount.
/ Loading Tires with this? #10
i hope you not serious about using straight WWf? Even if your planning on putting like 10 gallons per tire if will be far cheaper to go to walmart and get several gallons of the around $7.50 gallon antifreeze.
/ Loading Tires with this? #11
You need to be careful about the dilution factor and impact on freeze point. Most antifreeze is not intended to be diluted more than 1:1 with water as I recall. It also has more toxicity issues than methanol. Methanol based WWF is actually pretty cost effective if you can get it for $1.50/gallon or so. Straight methanol with added water can be cheaper in larger volumes but buying methanol in anything less than 55 gallon drums can be expensive.
/ Loading Tires with this? #12
Stuff's pretty toxic if/when you get a flat and some 6-9 gals of the stuff soaks the ground. Hope your tractor isn't parked anywhere near your well head when it happens. Just sayin'
/ Loading Tires with this? #13
Island tractor and BP fick.
Remember.. times are modern.. we have non toxic AF based on propylene glycol available now, as oposed tot he toxic ethelylene glycol stuf.
rv holding tank AF is the safe stuff.
soundguy
/ Loading Tires with this? #14
soundguy
Yep, that is right but (I haven't checked recently) the RV stuff is more expensive so if someone is trying to find the cheapest antifreeze solution they might still settle on ethylene glycol (I presume it is still available).
/ Loading Tires with this? #15
It is.. and you just have to catch the rv stuff when it's priced right.. napa had it in gallon jugs a few months back ( when it was still 'summer' for 4.99 / gallon!! )
I got enough to load some 16.9-24 tires at a mix strength that would be safe for florida winters.. Ie.. perhaps slushy at 10'.. since we almost never see anything lower than teens for very long.
soundguy
/ Loading Tires with this? #16
Has anyone used magnesium cloride to load tires? Seems to be pretty popular with dealers around here.
/ Loading Tires with this? #17
-Mike
Check with your local oil supplier. They carry all kinds of stuff. I just got a 55 gallon drum ordered today of minus 20 stuff for $.94 per gallon so just $51.70 The guy is even going to delver it for free because he has a delivery to make just a few farms down. I said that was a great price and he told me he had $.54 a gallon in it and his standard mark-up was $.40 per gallon. I thought it was a great deal. I only need 40 gallons for this tractor but the cheapest I had seen it was $1.69 per gallon at WalMart and my local Rural King so I will have extra and still be money ahead.
Chris
/ Loading Tires with this? #18
soundguy
I run a marine business and the cheapest I can get it is about that price. My local Menards, which is like a Home Depot, has it on sale every year for $2.49 per gallon during the first week in October. Its made by Peak. I just bought 100 gallons last week. Crazy I can get it cheaper there then buying in my version of bulk. By the way the oil supplier I called about the WWF said he gets his there also and marks it up $.40 a gallon for resale.
Crazy world.
Chris
/ Loading Tires with this? #19
I think "Builder" used mag chloride. You might send him a PM. It is still a fairly corrosive solution though. Not sure if it is as cheap as CaCl which is the most popular salt solution. Those seem to be the choice of most old time farmers and it is apparent CaCl has done the job. The trend, at least as I perceive it, is away from the corrosive salt solutions towards non toxic non corrosive (and more expensive) solutions such as beet juice, WWF and antifreeze in addition to just plain water for folks in places like Texas, CA and FL.
/ Loading Tires with this? #20
Crazy world.
Chris
yep.. makes ya wonder.
I too was surprised at the low napa price.
the stuff worked out great for me.
soundguy
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
Kubota M4700 (A60462)
2014 KENWORTH T800 MIXER TRUCK (A63569)
2014 KENWORTH T800...
2025 Swict 60in. Bucket Skid Steer Attachment (A61572)
2025 Swict 60in...
JOHN DEERE 1700 - 6R VACUUM PLANTER (A63291)
JOHN DEERE 1700 -...
