how to install barb wire fencing?
/ how to install barb wire fencing? #21
If you ever want to replace T-posts one at a time all by yourself and you want to keep the wires away from your hands and the post driver, stomp a couple of pitchforks into the ground until you have them holding the wires safely away from you. Of course there has to be a little slack in the wires.
/ how to install barb wire fencing? #22
Just a word of caution (since you said you didn't make H braces) Did you brace the corner posts? Unless you put absolutely huge poles/posts in very deep (like 5 or 6 feet), after you tighten 4 or 5 strands of wire, the post will start to lean. I put up several sets of posts that I thought were strong enough, and after stretching the wire, I had a loose bottom strand and leaning posts. That was a rough lesson.
Besides that, the other advice is right on. Start at the bottom and work your way up. I use a cable come-a-long and pull the wire 'til it's tight. Then start all over again.
I also liked the suggestion about alternating which side of the post you wrap around then end posts. I've had that problem before, and now I think I know how to minimize it.
Good thoughts.
Take care.
Have to agree, put 3 posts in each corner with bracing between them, Id also recommend the same for any change in directionor major elevation change (ie at the top of a hill), otherwise you'll be re-doing it at some ponit
/ how to install barb wire fencing? #23
You might want to pry those pitchforks out of the ground with a crowbar, as pulling them out by the handles could loosen the handles. And the barbs could scratch the handles, so you might want to use old pitchforks.
/ how to install barb wire fencing? #24
3 posts on each end corner run.... makes 5 at a 90 degree corner.
put cross brace near top of posts... not in center for a "H"
use fence strainer/rachet on each wire.. allows easy retensioning at later date
use fence strainer for tensioning brace wire, easy to maintain tension later
use metal pipe cross brace ... wood cross braces come loose too easy
drill hole in corner posts, drive long nail/rod in so pipe can't fall down
/ how to install barb wire fencing? #25
I'm guessing the original poster is long since finished with his fence.
/ how to install barb wire fencing? #27
Link to H Brace.
Building an H-Brace Farm Folly
My daddy sure did it different. When we were lucky they'd be a hickory or oak tree at the corner! When no trees were available it was a post, then diagonal post from the top corner to the bottom of another post (usually 5-6' apart if memory ain't shorted than my hair).
Ocassionally he'd put on of these in along the way too because of soil conditions, hillsides etc., to strenthen the fence.
I've build a lot as a kid. We'd roll wire for a while, that being to the lay of the land..uphill, down hill and nail off and go again.. Nail behind the barbs so the barbs get blocked by the fence nails (staples?). I worked great. We used a fence strecher, a metal bar with a plier type jaw and us leverage to pull that wire as tight as you could while someone nailed it to a few posts. Hard stuff of a kid!
BTW, the wife keeps mentioning a pony so looks like I may have to re-read all this again!
/ how to install barb wire fencing? #28
how do you stretch and attach barb wire to h-brace made with steel pole
/ how to install barb wire fencing? #29
The H brace mentioned above is talking about the horizontal brace between the two vertical posts. However, if you make your entire corner with steel posts, you just tie the wire around the posts. Stretching, you just tie your come-a-long around the corner post.
/ how to install barb wire fencing? #30
You use a come-a-long chained to the corner post and a wire clamp on the other end of the come-a-long. There are a couple of different style wire camps, but they all are made to slip over the wire and grab it without actually breaking or tying the barb wire to the clamp. Start with the come-a-long all the way out and start tightening the fence. When you get it tight, you will still have a bit of slack wire between the wire clamp and the corner post, but the rest of the wire will be taught. The slack at the end allows you to tie the end of the wire to the corner post taking out as much slack as you can by hand. When you have done this, let the come-a-long back out and you are done.
You might think this will loosen the wire too much, but it doesn't. A couple of inches of slack let out over a 1/4 mile of fencing won't even be noiticable. The trick is to know how much to tighten the wire. This is an experience thing and you will have to break a couple of wires before you get the feel for it. Make sure you spend the extra money for a good quality American made wire. It will stretch to a certain point where you can tell it's not stretching anymore. That's when you want to tie it off. The cheap wire will break before it quits stretching.
Plan your fence so you don't have any short sections (100' or less) as they are hard to stretch with this method and stay tight. Dito on the stretching around corners unless it's a very short section.
As far as starting at the top or bottom, it's a preference thing. Properly brace your corners and it won't matter as the top wire won't pull the post in anymore than the bottom will. I prefer three posts in my corners spaced ~8 feet apart with one horizontal 4 feet of the ground and one diagonal brace going down to about 1 foot off the ground.
Sometimes I go by a fence I've put in several years ago and pluck the wire to see it's still guitar string tight. It's a nice feeling.
/ how to install barb wire fencing? #31
Solid H corners, H Brace every 300', Pull with the Golden Rod Fence Stretcher every 300', NEVER pull the bottom wire first, if you have built any amount of fence on a ranch you know why .... always set your end corners at a 5 degree line slope away from the pull.
Say what you want ... I have built miles of 5 strand barb wire fence ... only a novice would pull the bottom strand first !!!
/ how to install barb wire fencing? #32
If pulling the bottom wire first and top wire last creates a saggy bottom wire, your end bracing is not strong enough, your soil is too loose, post not deep enough, etc. If the post doesn't lean, top and bottom wires remain tight regardless of which order they were stretched.
Perhaps this is a regional issue where soil conditions make bracing more of a challenge. Around here, a $5000 Beltec with carbide teeth is the only thing that will dig fence post holes. If I'm driving them with my Shave HD8, I have to predrill the holes with a rock drill. Getting our posts in the ground is a challenge, but they don't budge one bit.
Also, everyone please understand the difference in barb wire and high tensile fencing. The latter is not as forgiving when it comes to staying tight as it has less stretch.
/ how to install barb wire fencing? #33
I'm not talking about the wires sagging ... if you pull the bottom wire first you will fight each wire you pull with the already installed lower one. Alot of time will be spent walking back and forth to get the wire above the already done one.
CORNERS are the most important, some I even drop a bag of quick crete in .. The most amazing fence tool I have is the golden rod fence stretcher ...
/ how to install barb wire fencing? #34
Okay, that makes sense. I've had people tell me if you stretch from the bottom up, it will loosen the bottom wires which is not true if your bracing is good and strong.
The other day, I saw a fence being built that had all the wires stretched and tied at the ends but not lifted and tied in place at the t-posts. It was a long fence so the wires weren't going to get off the ground just by tightening. Still, it must have been a mess to untangle as they put the t-post clips on.
Can you post a picture of your golden rod stretcher? I think I have one that I use for fence repairs.
/ how to install barb wire fencing? #35
When I build barbed wire fence, after the corners are in I tighten a wire on the ground between them temporarily for a guide for putting in posts lined up and then I put in the line posts and then I put that ground wire up to start hanging wire at the top. Gravity won't make the next wire catch on wire already hung above it and it seems good to set the height of the top wire first instead of the height of the bottom wire first.
/ how to install barb wire fencing? #36
hello
i do this and .. I put in the line posts and then I put that ground wire up to start hanging wire at the top. Gravity won't make the next..that would be finished.
/ how to install barb wire fencing? #37
Here's a Golden Rod stretcher.
Dutton-Lainson Company - Since 1886
Golden Rod improved its jaws over ten years ago by making them curved instead of straight. Buy only a genuine Golden Rod! Don't buy a look-alike of a different color! I use Model 400s. I have an old Model 405 with the slow release, but I don't usually need slow release and it slows me down. The Model 415 with extra hand is a fairly new offering by Golden Rod. I don't feel I need to buy one when I have more than one stretcher, but a Model 415 could come in handy when attaching wire to a corner. A come-along with wire-holding attachment may be better for that job, but I get by with Golden Rods.
/ how to install barb wire fencing? #38
Sometimes on a long pull you will have to set a t-post to keep the spacing on the wires, I set the t-post every three steps or about 9-10 foot ... my neighbor carries a 10' piece of PVC so all his are the same spacing. He also does 7 strands of wire ??
Someone already did the picture of the Golden Rod ... THE BEST BY FAR ... I also like the fact it can be used to pull two together after a line wire breaks, from a fell tree or a bull fight.
/ how to install barb wire fencing? #39
I have a couple of those fence stretchers. Not sure if they are Golden Rod or cheap nockoffs though. I'll have to go look. I pretty much just use them for reparing fences these days. For new builds, I use a a come-a-long modified for fence building. I removed the grab hook on one end and replaced it with a short 1/4" high grade chain to wrap around the post.
1453 (A57192)
1453 (A57192)
2006 FRAC TANK 500BBL WHEELED (A60736)
2006 FRAC TANK...
Kubota ZG222 (A60462)
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
Sdlanch SDLD25 (A60463)
Sdlanch SDLD25...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
