Fill to top of rim, leaving room for air.. needed for pressure and sidewall flex.
For 95% of us, traction is a moot point, 95% of the time.
It really matters when plowing very large acreage for hours on end.... where a small slippage is desired (maybe 15%) and R1's (loose field dirt) is the right answer. Here it translates into fuel efficiency versus dirt engagement efficiency versus acres per hour. A proper balance between RPM'S, speed, weight balance/distribution/ traction translates into optimal field work. How many of us do this, in reality.
Mostly, we use our tractors as a utility vehicle, doing lots of short term chores of very diverse kinds.
For FEL work, most important is 4WD+toothbar for digging into a pile of material and proper rear weighting (filled wheels and/or rear weight) for moving the material in a FEL. Rear traction will be OK if this is done, either R1 or R4 tires.
IMHO, R1's will dig a deeper rut and fill up with mud and spin just as soon as R4's. Difference is depth of rut.... result is still a spinning tire.
Rear wheel spin is best avoided by proper RPM'S and locking both wheels (operator action) when spin is likely as determined by experience.
I recently assisted a neighbor in cleaning out his dirt tank, prior to recent rains. It was slick mud, very slick, but mostly a firm foundation. I'd get a full FEL load, lock rear wheels as I carefully backed up the slick incline out of the tank, seeking to avoid wheel spin. Mostly this would work. Loaded rear wheels, 1000 lbs on 3ph via box blade/weights, 4WD.
When slippage did occur, it was over... I had to reenter the tank, reverse, and come backwards at speed to get past the slick point. Then, I'd put some drier (relatively) mud on the slick point and all would be good for about another 10 trips, then repeat. I have R4's, don't believe R1's would have been any different.
My point is that for best traction you need, IMHO in this order:
4WD
proper RPM's/horsepower...
loaded tires
proper 3ph weight
lock rear wheels together
R4's or R1's
Actual tractor weight does not matter (within reason).
