How fast with a canopy?
/ How fast with a canopy? #21
I can assure you that no canopy is indestructible. That said, every canopy that I have seen IS adjustable as to angle, etc. There really is no reason to have a canopy angled upwards at the front. That's pretty much asking for a problem. With the front of my canopy slightly angled downward and of reasonably solid construction I don't see the problem.
I have trailered as fast as 70mph and with semis going past and over some not glass smooth surfaces and all with one very weak fiberglass canopy. The end result was that nothing broke and the leading edge did not peel back or even show signs of attempting to do so. And, yes, I did inspect the canopy thoroughly, afterwards. I have since gone to a much heavier canopy because I like this one better.
If you want to tow with the tractor backwards, please do so but be aware of the potential problems of weight distribution. I would rather remove the canopy, as skipmarcy did, than to risk the dangers of improper tongue weight.
/ How fast with a canopy? #22
Towing with it backwards all has to do with the tractor, tow vehicle, and trailer. So for you to say it will give too much tongue weight is a blanket statement. I always loaded my tractor forward. I drove a F-150, F-350, F-250, another F-350 and a 3500 GM. When we were taking the dog, child, cousin, and my tractor to my inlaws 240 miles it required us to take the wife's 2003 V8 4x4 Mountaineer. It had something like a 7,200# tow rating and was maxed out. When I loaded it forward it put too much weight on the Mountaineer so I flipped it around and she set level. On my trailer with my tractor equipped with my 7' Woods Blade and the FEL as equipped for this trip it moved the weight back on the trailer, not forward as you are stating it will. After that day I never put it on forwards again.
Chris
/ How fast with a canopy? #23
Chris
Well, if you re-read my statements I didn't say it would increase the tongue weight to reverse the position of the tractor, I said it would change the tongue weight. Invariably, it decreases tongue weight to do so. Decreasing tongue weight much below 10% of the weight of the trailer/ load is dangerous. It significantly reduces the stability of the truck/trailer, particularly in an emergency situation. If you "leveled" out a Mountaineer by changing the load you had very little tongue weight. My friend has a Mountaineer and it would take very little weight to drop the rear of the SUV which is why he uses Weight Distribution. If you want to live with that situation (low tongue weight), that's your decision but I certainly don't, which is why I bought a Sherline scale. I have 800 lbs tongue weight with a 8000# load and Reese Dual cam high performance Weight distribution hitch and my combo is rail solid.
/ How fast with a canopy? #24
I tow every other day so towing is second nature. The Mountaineer handled the weight fine and drove nice at highway speed. It had right at 10% tongue weight I would guess but no more. The load weight was right at the max for the Mountaineer which it pulled with out complaints.
Chris
/ How fast with a canopy? #25
The NH I'll be picking up is about 650 miles away and on the ROPS it has a fiberglass canopy. Will that hold up OK on the trailer at highway speeds or will it break, or act like a sail, or?
If I put it down will "down" be far enough to get it out of the wind or will it be acting like a big speed brake?
Do I just need to take it all the way off and figure out a way to put it on the trailer safely, or is it collapsible enough to fit into my Suburban (NH TC40D)?
If your canopy is mounted to the ROPS and the front is cantilevered from the ROPS, then loading it on the trailer backwards will provide a more stable and structurally sound way to tow it on a trailer exposed to ambient air flow.
/ How fast with a canopy? #26
Ding, Ding, Ding.... We have a winner. You said what I have been trying to say.
Chris
/ How fast with a canopy? #27
The Sherline scale is a very cool accessory that we all should have. Eliminates the guessing and makes the roads safer.
I couldn't imagine towing anything much more than a lawn tractor behind a mountainerd. The girl that does the commercials is pretty cute, though.
I've got a FEL, rotary cutter, landscape box, plow, forks, and if I can fit them some disks that I can move around as needed to help balance out the trailer. However, with that much "stuff" to fit on the trailer, I'm still not sure how the tractor must sit yet and will be willing to load it front or back as needed if it means getting the rest on there too, and since my speed at that weight will be relatively low I think it will all work out ok either way I load it.
The reason the dealer suggested loading it on backward was because the ROPS is mounted at the back of the canopy and so there is very little "lip" left for any wind to have any impact up or down vs. pointing forward there is much more room for wind to push up or down.
Think of a lever and how it works. This is just another example of what I've seen some others here post already.
For the record, my canopy is fiberglass so pretty sturdy, and has a slight downward slope going forward....
Another tip I got that has nothing to do with this thread, but since I'm new to this and others may be too I thought I'd pass it on. He told me that since it's such a long way, cover the exhaust with a towel or something so that wind won't blow in there and eventually cause the cylinder to dry out. If I had a turbo (I don't) it would also keep that from spinning and running dry for so long. Not a problem on short trips, but for a long 1 or more comfortable 2 day trip, was recommended to avoid any possible damage.
/ How fast with a canopy? #29
Yes, she certainly is!:D:D:D:D
/ How fast with a canopy? #30
That's most likely part of the reason for the downward slope-so it can be transported without the canopy catching wind underneath.
Oil in a cylinder would not "evaporate" (like water would) from wind blowing on it, so I think that's much to do about nothing.
I've towed a lot of equipment a lot of miles and never did that or heard of anyone covering the exhaust to keep the turbo from spinning, but it might not be a bad idea for keeping heavy rain out of the exhaust.
/ How fast with a canopy? #31
I agree with Builder about the cylinder becoming dry? Kind of a curious statement.
I HAVE heard that it is a good idea to cover the air intake to stop the turbo from spinning on high speed trips so that may be equally true about covering the exhaust on a turbo engine.:)
/ How fast with a canopy? #32
my dealer put a balloon on my exhaust when i picked mine up
/ How fast with a canopy? #33
The canopies I'm familiar with are set up to be easy to remove--just two large knobs to unfasten it from the bracket that holds it to the ROPS. Why risk a problem--remove it and put it in your Surburban.
/ How fast with a canopy? #34
My dealer is 650 miles away from me, I towed my rig home with no problems what so ever. If I was to have problems, then I would be in real trouble, it is not unheard of for the wind to blow at 80+ MPH at my place.:eek:
/ How fast with a canopy? #35
Nice tractor. Nice rig. Can't make out the truck model.
Especially nice: the In n Out Burger place in the strip mall behind you there. Right now I'm jonesing for a #2 with extra onions. Unfortunately, the nearest InOB is 40 miles away in Chico. Oh, well. Maybe next week sometime.
80 mph! Last time we had wind like that we called it Hurricane Rita! :D
Drying out the cylinder- now that you say it like that I agree that I don't understand how that could be an issue either, but keeping water out might be a better reason, although my pipe is on the side anyway.
I was thinking about putting the canopy into the Suburban but being in a "big city" where you have a Harbor Freight, Mike's "warehouse", TSC, an Ag Equipment place and a nice Co-Op...well, that is no longer an option! I should have left a week ago when I still had some money left. :( And room. :rolleyes:
/ How fast with a canopy? #38
Just a thought...
Everyone in this thread is concerned about the structural integrity of their canopy when exposed to aerodynamic loads encountered while trailering at speeds of up to, let's say, 75 mph.
But...
Has anyone thought about the potential guillotine effects during a rollover situation of that same canopy that everyone is concerned about not being able to withstand aerodynamic loads at normal road speeds?
I don't want to activate the Safety Patrol over this for goodness' sake, but, I would think that any canopy that can't withstand the aerodynamic loads imposed by normal trailer transport speeds certainly isn't strong enough to be a safe addition to the tractor's ROPS...
Just my way of looking at it...
What do you all think???
/ How fast with a canopy? #39
Flusher, the truck is 1988 F250, getting ready to turn 300K miles. I special ordered this truck back in 87. It has been a very good truck for me.
My gosh that grapple is HUGE for the size of the tractor.....but it looks like it would fit nicely on my backhoe. ;):D
Builder, The grapple was not for me, I'm not sure if my little tractor would even pick that thing up,:eek: I was delivering it for the dealer, saving him about a 1000 mile round trip. ;)
/ How fast with a canopy? #40
Not that 80 MPH winds are an everyday occurrence, usually only a few times a year, although I was told that once last year, or maybe it was the year before,:confused: :eek: they got up close to 100. :eek:
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
1991 25ft Wellcraft 250 Sportsman Boat with 2008 T/A Boat Trailer. (A61574)
1991 25ft...
Caterpillar D5M and D5M LGP Dozer Service and Parts Manuals (A63117)
Caterpillar D5M...
