5525 Fire Extinguisher
/ 5525 Fire Extinguisher #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
After one too many grass fires while cutting hay I decided I needed a good size fire extinguisher on my tractor that is easy to get to, etc. Here is what we came up with.
D.
Thats big !
Same one as mounted on my baler and I have one on my welding trailer. Water and refillable - so, it should work. I have a smaller chemical one in the cab, but I hate to waste it on a grass fire since I can't refill it, etc.
D.
/ 5525 Fire Extinguisher #4
I like it. Did you build the bracket or buy it? If bought, where?
I need to mount one on my 5101 and would rather have it on a heavy duty bracket outside the cab like you have there rather than inside the cab.
I looked and could not find a good solution. So, a buddy of mine looked and it and the tabs on the loader brackets for the fenders and lights looked like a good spot.
A buddy of mine wanted one also. Maybe we need to crank out some extras. We painted this one, but we could get them powder coated.
D.
/ 5525 Fire Extinguisher #6
D.
Gees, what starts these grass fires? Never experienced it or heard of it here in Central Pa and I've been in and around haying a long time. I'm not doubting your word -- maybe I should invest in fire extinguisher just in case.
Hot, dry days + rocks + disc mower - I only had one fire this year. it was the last cutting when things were really dry. One really has to be careful around here.
D.
/ 5525 Fire Extinguisher #8
Next time you refill it, try a "little" bit of dish detergent with the water. It allows the water to penetrate better and extinguish fire.
Interest, that is a new one.
I wonder what I should do for winter? I might just pull it off and put it in the garage.
D.
/ 5525 Fire Extinguisher #10
Very nice!
I just have a small fire extinguisher on my tractor.
Where did you buy yours at ?
Very nice!
I bought the outside unit from my JD dealer. it is the same as they put on their balers.
We had to fabricate the mount. It bolts to one of the tabs on the front end loader.
D.
/ 5525 Fire Extinguisher #12
Very nice Darin,..looks cool with all that chrome and of course the green sticker matches the JD or at least a nice contrast. Beautiful installation! Very handy when needed.
CHEERS!
. . tug
/ 5525 Fire Extinguisher #14
D.
Thanks for the info!
I've never seen one at my JD dealer.
You did a great job on the mount, and the fire extinguisher looks good on the Deere:D
Nice job Darin, and it fits nicely on your rig. Can you add a second one on the right side?
I bet I can. I would have to see where the tool box sits.
D.
I had to make the mount, but they stock these fire extinguisher and and the holder. Same as you see on balers.
D.
/ 5525 Fire Extinguisher #19
Great if you are in the UK.
:D.. I done a search and copied the first link that came up.
I noticed on that one that it was a 9-litre water fire extinguisher,and I was trying to find out how much his holds:D
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
2016 Forest River Viking Towable Trailer (A62613)
2016 Forest River...
Pallet Racking (A65640)
Pallet Racking...
2009 Infiniti FX35 AWD SUV (A64557)
2009 Infiniti FX35...
Auger Cart (A65640)
Auger Cart (A65640)
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
