Adding weight to a tractor with a twist.
/ Adding weight to a tractor with a twist. #22
You may want to check this out although it's for the rear. Tractor receiver hitch and weight bracket for 3 point lift, 3 Point Tractor Hitches for John Deere Tractor Accessories | Heavy Hitch Looks like it would work pretty well other than having to buy the weights!
But if you already had front bumper weights that you did not know what to do with after adding a FEL, it would be a great simple way to add weight to the rear. Good idea that will go in my file of good ideas.
Mike
/ Adding weight to a tractor with a twist. #23
I didn't need that much weight. Went down to my local aircraft landing gear overhaul shop and he had some 2 x 8 laying around, made me a bumper including paint for $100. It weighs a little more than 100 lbs. Works great.
/ Adding weight to a tractor with a twist. #24
LOL! Now that is humorous. "Local aircraft landing gear overhaul shop".
Are they right next to NAPA? LOL!
The chunk of steel on there looks good.
/ Adding weight to a tractor with a twist. #25
Good threads never die, this one started 10-06-2007. :thumbsup:
/ Adding weight to a tractor with a twist. #26
I'm adding a real rear weight to my Kubota BX2350 after a couple of years of using a kit-bashed "garbage can" weight that proved the concept. This time I'm using a real heavy gauge 55 gal. drum and some sturdy, welded brackets. I THINK I should be using around 400 lbs. of weight, total, but I'm having a great deal of difficulty confirming this, despite tons of searching the forums. Can anyone give me some guidelines on this? I can't even find anything on Kubota's site for BX series tractors regarding this. Thanks!
/ Adding weight to a tractor with a twist. #27
From BX2360 manuals:
Loader manual recommends a maximum of 420 pounds on the rear as loader ballast.
Tractor manual recommends a maximum of 275 pounds on the front as rear implement ballast.
Bruce
/ Adding weight to a tractor with a twist. #28
The manual, really? :) I imagine the 2350 and the 2360 must be pretty similar but I'll have to dig mine out and check that, thanks for the reminder. Funny how nowadays everything is so internet-centric that it's easy to forget about the much simpler look in the printed manual.
2006 Ford Freestyle SUV (A64557)
2006 Ford...
2023 Bobcat T595 Compact Track Loader Skid Steer (A64553)
2023 Bobcat T595...
1996 Chevrolet Astro Cargo Van (A64194)
1996 Chevrolet...
2012 Subaru Forester SUV (A64557)
2012 Subaru...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2015 CATERPILLAR 336FL EXCAVATOR (A65053)
2015 CATERPILLAR...
