YIKES---4100 ring and pinion
/ YIKES---4100 ring and pinion #1
acs55812
Duluth, MN
Got a call from a friend to whom I loaned my 4100/410 loader so he could clean up his place for an upcoming wedding.
Seems he loaded up some logs and was backing up a slight hill----until the ring and pinion gears in the front end gave out, he figured the front wheels were doing most/all of the driving as the rear end was probably lighter than it should have been without ballast.
It is at a good John Deere dealers shop and will be done next week.
Should I offer to split the cost as some normal wear and tear would have been done thru normal usage (tractor has less than 300 hours on it) prior to him borrowing the tractor.
Has anyone been thru this and know what those gears run for price plus labor?
I need to talk to the dealer as he did mention something about a rear axle seal leaking also so I probably will have that fixed while its in the shop.
/ YIKES---4100 ring and pinion #2
/ YIKES---4100 ring and pinion #3
That's the bad thing about loaning expensive tools/equipment out. If it breaks who pays?. I'd say it would be fair for you to pay half though depending on hrs and how truthfull the friend was about how it broke.
/ YIKES---4100 ring and pinion #4
I'm going to stray from the herd here. He borrowed a perfectly good tractor with extremely low hours and precipitated a major component failure. He should be completely liable for the total repair cost as a matter of respect and courtesy to someone who considers him a good friend. Anything less proves him to be not a good friend at all. If this were a pair of farmers loaning equipment to each other, the borrower would pay the bill without question in all but the fewest cases, and those cases would cause hard feelings.
We will never know if those suggesting you should split the bill would actually do so themselves if they were in your shoes. I'm betting they would not be so free with their own resources.
The lessen here is to keep your tractor at home, or go and operate it yourself if you want to do favors.
/ YIKES---4100 ring and pinion #5
This statement is key to me...
-Did you loan him the tractor without ballast?
-Did you tell him rear ballast was required when using the FEL?
If the answer is yes to both, then I think you are responsible, if the answer is no then he is.
He wanted to move "mulch" which he was originally going to do by hand, I figured the tractor would speed the process, along the way somewhere he decided to move "logs" up a hill, had I known weight would be involved I may have thought of ballast,,,,as it was I didn't even think of it since it was to simply make easier what he was going to do by hand.
/ YIKES---4100 ring and pinion #7
A neighbor and a broken expensive piece of equipment is never good.
I think you will have sticker shock when you see the bill.
You might consider trying to find a used front end. It might be way cheaper, but it might be a piece of junk.
Will your/his insurance cover it?
Get the estimate and ask him how he wants to handle it.
D.
/ YIKES---4100 ring and pinion #8
I change my vote, He abused it and should fix it.
/ YIKES---4100 ring and pinion #9
This is a hard way to learn a lesson. I would ask him to share the expense since this was a friendly gesture, not a rental. You'll quickly see how good a freind he is.
I learned this lesson years ago to a much lesser extent. My rule now is "If you borrow it, I go with it"
I just re-read my original post, I didn't make it clear that he is intending to pay for this on his own, he had it in the shop and diagnosed prior to calling me and telling me what was wrong--that way no guessing and such on either party's part as to what might be broke.
As for the ballast I didn't send it as I didn't think heavy stuff was being moved---had I known that I would have sent it with the tractor.
/ YIKES---4100 ring and pinion #11
Sounds like he stepped up and did the right thing. Hard to fault him here.
If it was me, id likely split it with him, because he did the right thing. If he didnt volunteer, my opinion would likely be different.
/ YIKES---4100 ring and pinion #12
There's no way I'm going to pay $500 or more for the privelege of having my neighbor break my tractor. Sorry, that's just the way I am.
/ YIKES---4100 ring and pinion #13
Then its probably not a good idea for you to loan your tractor. I would rather go and do the work for my neighbour myself so something like this discussion doesnt need to happen.
What if you broke your tractor at your neighbours? would you expect him to pay the whole shot if you were operating?
The guy did right in this case, and theres no guarantee that the axle wasnt damaged when he got it. THe fair thing is to meet him halfway at least in my opinion.
Now if he dropped a tree or something on it.. id expect him to foot the whole bill.
/ YIKES---4100 ring and pinion #14
Then its probably not a good idea for you to loan your tractor. .
That's something I figured out years ago. It's usually not a good idea for me, or anyone else. That's how guys get in these situations. The borrower should man up and fix the tractor, as he is attempting to do. He's doing the right thing.
No, if I were operating it, I would drag it home and fix it. It would not matter if I was charging for the work, or doing a favor; I broke it, I'd fix it.
/ YIKES---4100 ring and pinion #15
I agree with most of what you say. Only place we differ is splitting the cost.
/ YIKES---4100 ring and pinion #16
How heavy of a load are we talking. Doesn't sound to me like the thing should have broke in the first place, even with out the ballast.
I found out tonight, the estimate is $1200.00 total---ouch
/ YIKES---4100 ring and pinion #19
What all do you get for $1200?
I just spend $650 replacing some u joints, yokes, dipstick, etc on my batwing from hitting a stump.
It is always something...
D.
/ YIKES---4100 ring and pinion #20
ACS: you said you were going to maybe have the rear seal fixed too. Here's a compromise suggestion for ya to consider: Maybe, since you were going to have that rear seal done, and you'd have to have it hauled both ways ( I am assuming you or your neighbor did not haul it, considering the liabilty and weight), he's planning on paying the repair, so you offer to pay the transportation costs since you have the rear seal done now too, and anything else you feel it needs.
I know if I borrowed the tractor and broke it, I would pay for repairs. I have a neighbor's disk setting in my yard right now. Sure enough, as soon as I started using this borrowed disk a bearing went out. I bought the bearing, and the owner (of the disk) and I are going to do the labor together. Never a question about it: I broke it, I pay. If I need the disk again, he will loan it to me I bet.
sometimes it helps to look at the other side of the coin.
2001 Ford F-250 Reading Service Truck (A66736)
2001 Ford F-250...
2007 WESTERN STAR 4900 SB CRANE TRUCK (A67714)
2007 WESTERN STAR...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
Generator (A64553)
Generator (A64553)
2012 Ford Transit Connect Cargo Van (A66736)
2012 Ford Transit...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A68183)
2017 Ford F-250...
