Tiller Tiller conversion - Forward rotation to Reverse Rotation Complete!!
   / Tiller conversion - Forward rotation to Reverse Rotation Complete!! #1
WilliamBos
Super Member
Innisfil, Ontario, Canada
MF 1635 12x12 Powershuttle
Hi All,
We decided last week to explore the gear box of our Kubota Turfbuster, and without too much work, it looked easy to convert it from Forward rotation to reverse rotation.
All that was involved was removing the shaft, taking the gears off, and putting them on the other end. BUT, we had to have a new key way groove, and snap ring groove machined in to the shaft, so off to the machine shop it went.
The red circle is where the gear was for forward rotation, and it has been moved as you see in the pic. The machinist recommended putting new bearings on while we had it apart, so we did that too.
We tried it out in the garage today, and it was a success. It is also in for some paint, and a few other changes.
I will post more pics once it is done.
[FONT=&quot][/FONT]
   / Tiller conversion - Forward rotation to Reverse Rotation Complete!! #2
What on earth posessed you to do that? Really neat but you are really thinking out of the box. Amazing!
   / Tiller conversion - Forward rotation to Reverse Rotation Complete!! #3
I am going to do the same to one of my old flail mowers so it cuts going backwards into scrub after i reverse the flails . I hope my shaft is made to go both ways , i think it is .
What is the effect on a tiller ? Are the blades straight cut so they will chop in either direction ? Does it have an idler on the chain/belts ? If so it will need to be moved to the slack side now .
We were looking and scratching our heads for a while. Opened up the gear box to change the oil, and we noticed that housing is set up for both. I am guessing Kubota did it that way to keep production costs down.
The rest was aphone call to our machine shop to find out how long it would take.
Once it is all done (paint) I will ut up the rest of the pics.
We unbolted the blades and flipped them over. The gear box contains 2 chains, and the idler is a gear. So looks like no changes are needed with it.
Works Great!!
   / Tiller conversion - Forward rotation to Reverse Rotation Complete!! #7
Looks great, and a super job on the gearbox too, but I think I would have masked off the side link arms before painting them orange!!! :p
My Dad needs things to keep him busy, so he is going to do touch ups on the tractor. :)
   / Tiller conversion - Forward rotation to Reverse Rotation Complete!! #10
Cool, let us know what you think of the difference between forward and reverse rotation.
KEWANCE 200 9' GRADER BLADE (A51243)
KEWANCE 200 9'...
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
John Deere 603 3 pt Mower (A50514)
John Deere 603 3...
2013 Nissan Rogue S SUV (A50324)
2013 Nissan Rogue...
