Tiller Tiller conversion - Forward rotation to Reverse Rotation Complete!!
   / Tiller conversion - Forward rotation to Reverse Rotation Complete!!
Hey Don,
The clay here is just like concrete when dry, after the conversion, the finished bed was a drastic improvement, no more clumps.
Works great.
   / Tiller conversion - Forward rotation to Reverse Rotation Complete!! #12
I have hard ground with lot's of clay, and I too found that in my ground the reverse rotation was better.
I couldn't compare 'apples to apples' as the 30" reverse rotation tiller was on the old Cub Cadet 2160, and the new 48" 'forward rotation is on the Massey. Although I could plant after one pass with the reverse rotation, and it takes two passes with the forward rotation.
   / Tiller conversion - Forward rotation to Reverse Rotation Complete!! #13
Just curious, how did you determine the exact location of the gear so the meshing would be correct? I would think it would be critical to prevent excessive wear.
Take Care,
Doug in SW IA
Take Care,
Doug in SW IA
The housing is a perfect square, it was machined out by Kubota to make selling either reverse or forward rotation tillers as low cost as possible.
We only needed a new bearing pressed on. Was that simple.
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
2018 Chevrolet Malibu Sedan (A53424)
2018 Chevrolet...
2021 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2021 INTERNATIONAL...
(3) PALLETS OF HEATERS (A55745)
(3) PALLETS OF...
2008 Ford F-250 Crew Cab Pickup Truck (A55852)
2008 Ford F-250...
