Tiller Tiller conversion - Forward rotation to Reverse Rotation Complete!!
   / Tiller conversion - Forward rotation to Reverse Rotation Complete!!
Hey Don,
The clay here is just like concrete when dry, after the conversion, the finished bed was a drastic improvement, no more clumps.
Works great.
   / Tiller conversion - Forward rotation to Reverse Rotation Complete!! #12
I have hard ground with lot's of clay, and I too found that in my ground the reverse rotation was better.
I couldn't compare 'apples to apples' as the 30" reverse rotation tiller was on the old Cub Cadet 2160, and the new 48" 'forward rotation is on the Massey. Although I could plant after one pass with the reverse rotation, and it takes two passes with the forward rotation.
   / Tiller conversion - Forward rotation to Reverse Rotation Complete!! #13
Just curious, how did you determine the exact location of the gear so the meshing would be correct? I would think it would be critical to prevent excessive wear.
Take Care,
Doug in SW IA
Take Care,
Doug in SW IA
The housing is a perfect square, it was machined out by Kubota to make selling either reverse or forward rotation tillers as low cost as possible.
We only needed a new bearing pressed on. Was that simple.
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
2008 Ford F-350 Service Truck (A53422)
2008 Ford F-350...
Sterling AT (A55315)
TANK MANIFOLD (A55745)
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
