B7800/B29xx Telescoping stabilizers
   / B7800/B29xx Telescoping stabilizers #31
Woo Hoo!!!!
I just got the telescoping links installed on my B7610. It only took about 20 minutes. I've had the parts all summer -- don't know why I waited so long to actually install them.
I'd take pictures, but it looks just like these from peterc38:
I have a B7610 also, how hard is it to remove the old turnbuckle system? I purchased a set of the new telescoping links.
   / B7800/B29xx Telescoping stabilizers #32
I just replaced the turnbuckles on my B7800 with the adjustable stabilizers. It took me about 15 minutes using just a couple of wrenches. Really worthwhile improvement to this machine.:) And I have Pat's easy change system as well!
   / B7800/B29xx Telescoping stabilizers #33
It's really easy to do. It took me about 30 minutes but I wasn't trying to set any records. There is a long pin that you have to tap back and forth to remove the old brackets and reinstall the new ones. You don't have to remove the tires or anything like that.
   / B7800/B29xx Telescoping stabilizers #34
It's real easy, although, if you have your rear wheels set narrow, you might need to remove one to get the shaft out that holds the chains.
   / B7800/B29xx Telescoping stabilizers #35
i just ordered them as well should make installing and taking off the backhoe much quicker. i will take some pics when i install. :D unscrewing the turnbuckles was getting old!
   / B7800/B29xx Telescoping stabilizers #36
I installed mine today, pretty simple and I didn't even have to remove a tire. I just slid the shaft to one side all the way removed old turnbuckle style and installed the new. I didn't have to remove shaft at all, just slid it from one side to another. This is the hot set-up, now I see why everyone recommended it.
   / B7800/B29xx Telescoping stabilizers #37
I was wondering how thick the stabalizers is. The reason I am wondering is I use my B7800 to mow hay with a 6 foot sickle doses great but this weekend a chain that raises the sickle got caught between the turn buckle and the lifting arms and broke the turn buckle. Though even before now the threads on the turn buckle was sticking and had jambed up once all ready and I am going to have to replace thim so I figgured if I was going to spend the money to replace the turn buckles I might aught to just go with the stabilizers. But I was wanting to know how sturdy they were.
   / B7800/B29xx Telescoping stabilizers #38
I know this is an old thread but where can I find the B7800 stabilizer kits or parts to make these?
Thanks
Perry
   / B7800/B29xx Telescoping stabilizers #40
Bought a pair of these generic sway bars to modify and fit on M59. $115 on eBay. Much better stronger than the OEM turnbuckles and a whole lot quicker to adjust. Like them so much did the same for the B26.
(APPROX 15) 6" X 2" X 68" TUBING (A57192)
(APPROX 15) 6" X...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52707)
2016 CATERPILLAR...
1824 (A57192)
1824 (A57192)
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
