Driveway Problem
   / Driveway Problem #11
I think your problem has a lot more to do with that big truck than your driveway.
I would think long & hard about finding some way to park the truck next to the road and take a car up & down the driveway.
Even better yet, take a look at one of those new Kioti UTVs. For $10 k you can solve your problem by buying a new toy. Leave the truck out by the highway and use the UTV to get to the house. I suspect you will put a lot more than $10k into your driveway, and it would be a lot less fun that the Kioti.
   / Driveway Problem #12
So the problem area lies alongside the pond. What is the slope of the ground on the side away from the pond? :D
   / Driveway Problem #13
CurlyDave, Where were you when I decided to put blacktop on my drive. I have been trying to think of a reason to get another little Kie class truck.
   / Driveway Problem #14
So, the key word I always hear is "drainage". Keeping the roadway as dry as possible with proper run off. I believe this comment because all of the areas of my drive that have more water retained are the areas of issue for me. I have a gradual hill that directs water toward the drive in some areas. I'm looking at building in a ditch on both and/or one side of the drive to direct water off and away. I've attached a sketch to illustrate a cross section. What is the optimal distance vertically between bottom of ditch to road surface and angle of deg. of ditch? What is the proper fall within the ditch for proper run off (i.e. 1" per 8'?). Does it vary by soil type or is there a general rule?
   / Driveway Problem #15
to answer OP his question about the big size rocks: NO
You will only, just as you are doing now with the smaller size rocks/gravel, push it in the clay.
Your problems sound very familiar.
I agree on the geotextile things but just dont see how good it will be fighting with that truckload. I would never use it for driveways.
We have similar problems in our region and it is a habbit to order a load of clean gravel every year after winter to top dress our driveways. Just, i'm an immigrant here and i hate topdressing with $$$ every year (even more as i do hate the manual labour involved with gravel). So, i did it a little different.
We rented a backhoe and took about 10" from the top layer (so the muddy stuff was gone and you are back at firm clay level).
We then dumped in the most unwanted mix of rocks, gravel and stonedust. This is the stuff nobody wants and much cheaper than a nice calibrated mix.
The point being that this rough mix makes for a very hard layer which does not allow water to go flow through but stay on top of it. (so ask for a lot of dust in your mix) and because it settles as a crust it also spreads the load more evenly.
If you can grade this mixture a bit you are making a flowdirection for the rainwater. (or you put your drainage tubing under this layer if you have groundwater issues)
then we added mix on top, like 3", as a finishing layer. (there i used small pebbles and gra as you can grade them much easier, that was also an unconventional move)
When it was raining the water flowed through the toplayer and then on top of the mix layer to the sides of the driveway.
If you allow water to go to your clay layer it will weaken the clay and thus allowing the clay to absorb any toplayer when you put pressure on it.
When we build our house and had to put pavement for a parking and driveway the construction company took off the 3" and left the bottom layer as it was. He could not make it a better underlayer, only make it worse.
Oh, and needless to say that all types of gravel consisting of round shaped pieces (pebbles) are a no-go as they never stabilize.
2cents only
   / Driveway Problem #16
We grade roads at 1/4" per foot (2%) and the shoulder area we try to get at 3/4" per foot (6%)
This way the road drains well and then once the water hits the shoulder it runs faster. This helps prevent soft edges of the road.
As for the ditch we never cut any shallower than 2' and use 3' of side slope for every 1' of depth.
In my area we build everything on clay. Most of the time it is wet and will move when driven on so we use alot of Geotextile and alot of "oversize stone" We call it 1"by3". We usually place a layer of the 1"by3" down on the clay so the equipment can get across to work. Then a layer of Geotextile with more 1"by3" on top of it. If possible the 1"by3" should have drain tile placed at its edge and outlet to a lower area so it will not set full of water and soak into the clay below. Then I like another layer of geotextile on top of the 1"by3" to keep the top gravel seperate and provide another bridge of fabric. I have done this layer method many times over the years while building county roads.
Some of the places near lakes around here we have done 4 or more alternating layers of fabric and stone to build the road. One of these areas that come to mind, it was hard to even walk across the cut area before the first layer went down. That was 10 years ago and the road is still there and several thosand cars and trucks per day drive on it.
   / Driveway Problem
Yeah, the truck is most definately the problem. Remove it from the equation and the problem is gone permenantly. Unfortunately, parking it at the street is not an option. I could relocate it to somewhere else if I can find someone willing to allow me to park it on their property, but I want to try to fix the road to where it will support the weight first. As to the $10k, I can't put that into it regardless. So far, I have 7 18 wheeler loads of rock in it or around $2800 in 2 years.
I think it's just a matter of putting the right material on it at this point to fix it. I'm just not sure what material to put. If I can keep the clay dry, it's solid as concrete, so that's the key. That's why I'm asking about the large washed stone without the fines, since it seems to me that would allow the water to get to the clay versus keeping it dry. Maybe I should do both. First the large clean stone, pack it down good and then immediately place the smaller rock with the fines in it on top to seal it off. That's 2 truck loads at $400 a load. I can stand that, if that's the way to do it. But if it would be better to just put twice as much smaller stone (say up to 1 1/2") with the fines down and skip the larger washed stone, then I'd rather do that. I guess what I'm saying is I'm tried of spending money experimenting with this and that and just want to do something that will last a few years. If I could find railroad ballast reasonable, I'd use that. But so far I haven't found a source. The limestone quarry where I've been buying the rock doesn't have it at that quarry. I've got to make some calls to see if I can find it elsewhere.
As to the pond, the grade is probably an inch per foot from the driveway to the water level. So the water doesn't sit on driveway long at all. The problem was that back in the winter, before I fixed the drainage issues, I didn't fix the ruts has they started to develop. As a result they got deeper and deeper, filled up with water when it rained, and that just saturated the soil. Now that I've fixed them and the water issues, it doesn't rut now except in couple small spots where it is still damp and then the truck only goes down an inch or 2. But I can see the ground rolling under the wheels in these areas, so I know it's still wet deeper down.
   / Driveway Problem #18
I just finished grading for proper runoff. Immediate runoff will be sheet flow across a (future) grassed area, and then to the ditching adjacent to my main farm road (an abandoned town road). The moisture of the clay is perfect - just enough to pack nicely without that powdery texture. Tomorrow morning I'm getting 2+ stone. I have decided to not put fabric down, for as long as the water doesn't sit on it, the stone will hold up nicely. Some areas of the farm roads have had stone w/o fabric doing its job for over 20 years. Not to mention that I'm getting about 660 tons of stone for stockpiling, so I'll have extra to add as needed. The material price was good. I also have miles of farm and woods roads to maintain, so having a stockpile is key to keep farm operations seamless.
I'll take some pics in the morning of the program.
   / Driveway Problem #19
Well...the job is done. Here are some pics. We put about six to eight inches down. My buddy really worked his JD 450 hard. This large stuff is a bear on equipment. I did do some fluff work with the Kioti.:D It's going to take a while for the cobbles to settle in, and I may have to top-dress it with some crusher run before my wife breaks a heel. :eek: The truckers ran over the freshly cobbled surface to get to the stockpile area, so it packed down pretty well. They were running about 78k pounds loaded, one guy said.
The stockpile is one half of the total piled up. There are 5 or 6 loads by one of my tractor roads.
   / Driveway Problem #20
Dahammer,
Have you looked into chip seal (also called tar and chip seal)? I really don't know a lot about it, especially how well it holds under the weight of your truck, but I have seen it used on several drives. It's basically a base layer of asphalt with finely graded aggregate. It is significantly less expensive than asphalt. Might want to check around your area, could be an option.
2018 Chevrolet Colorado Pickup Truck, VIN # 1GCHSBEA6J1312961 (A57453)
2018 Chevrolet...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2015 HYUNDAI TRANSLEAD TRAILER (A59575)
2015 HYUNDAI...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A60460)
2017 Ford F-550...
Powerhorse Air Compressor (A56860)
Powerhorse Air...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
