Why 4 Wheel Drive
/ Why 4 Wheel Drive #81
[I didn't think about until I read the link on the drawbars, 4wd due to the torque is divided between 2 axles this also makes the tractor less likely to lift the front end.] That seems to make some sense. I only throught about the added weight. So that would be another plus for 4wd.
Does a link state this or is this a deduction? Off the top of my head --Other than the added front weight there would be no difference if the pull point were the same. Summed torque effectively moves to the rear as the fronts unload.
larry
/ Why 4 Wheel Drive #82
OK so you have a better understanding of physics that Penn State's Ag Department which is putting out safety misinformation? You also seem to know more than probably every farmer I've ever known.
You know it's not about being right or wrong, I come here to learn and share knowledge if I can. If you want to say others are wrong and don't understand, why don't you show us something other than "your understanding of physics". Others here have been good enough to put links to information that supports there point. All you have done is put up at times gobbldygook, and now you say something that does not agree with you is misinformation. No one with a real understanding of physics would say a rotating shaft of any kind, axle or not puts out a forward force, shaft are for torque. [Not only did I take some physics, but I have a job that I actually apply physics in on a regular basis.
You have an inquiring nature, why don't you connect a tractor to something and see for yourself. Or at the very least show us where you are getting your information from.
Look up the Nebraska test data on some tractors. How could a tractor have a drawbar pull almost equal to it's weight if the drawbar didn't keep it from going over? That's pounds of pulling force, not pulling a load on wheels that once moving only takes a few HP to keep the load moving. [Going by what you claim the only force counter acting the rotation is the weight over the front axle which on most tractors is 40% or less, any weight on the rear axle would be trying to lift the front end.]
Im glad you have training in physics. Lets use it. 40% on front axle - radius of rear wheels less than 40% of wheelbase -traction coefficient of 1 - pull point straight back at axle level - level ground - no acceleration. What do you get?
Once I had a high school Physics Prof who was teaching my daughter tell me a motorcycle could stop faster/shorter than a truck because it was lighter. See the problem?
larry
/ Why 4 Wheel Drive #83
larry
An object of less mass (lighter) takes less energy to stop. So I would say the high school physics professor is correct under the same condtions from the same speed most of the time a motorcycle will stop faster than a truck. I say most of the time because you can set up examples of super light truck vs heavy bike that would be different, in gereral though that statement is true. Your question is what I meant by gobbldygook. I have no idea what you are looking for, so why don't you explain it?
"Does a link state this or is this a deduction? Off the top of my head --Other than the added front weight there would be no difference if the pull point were the same. Summed torque effectively moves to the rear as the fronts unload."
Also if you had read the paper sited it did explain that once the wheels were off the ground, it was the same as a 2wd tractor except for the added weight of the drive. The torque split was only as long as the front wheels were pulling. So this shows me that you didn't even look at the paper, yet you totally dismissed it.
Like I asked before, site where you are getting your information from. Instead of being so defensive and dismissive. So far your comments show that you think your veiw is correct and anything that goes against it you aren't even willing to look at. Yes at this point I see the probelm clearly now, you have no idea what you are speaking of. Your last statement shows this clearly. So until you can show something as to where you are getting your information I'm not going to respond futher to your posts.
/ Why 4 Wheel Drive #84
["Does a link state this or is this a deduction? Off the top of my head --Other than the added front weight there would be no difference if the pull point were the same. Summed torque effectively moves to the rear as the fronts unload."]
OK, so I asked an honest question because I didnt see that in the link and you ridicule even tho my [brief hypothetical] included the same consideration: "Four-wheel drive tractors are less susceptible to the rear axle torque hazard than two-wheel drive tractors because torque is applied to both the front and rear axles and tires. Also, more weight is carried on the front axle, moving the CG forward. These features lessen the tendency of the front of four-wheeled drive tractors to lift off the ground. But, once the front end does lift, there is little practical difference between two- and four-wheeled drive tractors." I wasnt sure what link it was in so it seemed easier to ask than peruse each. Thanks for pointing it out in such good form.
I am not getting my information from a site. I learned it previously so it is in my head. Your answer to the motor cycle vs truck stopping gets a 10%. The energys are surely different but so is the rate at which that energy can be subtracted to reach a stop - other pertinent things being equal the rates are exactly proportional to mass. The stopping distance does not hinge on the weight but on brake capacity and tire friction coefficient. With= tire coefficient and controllable brakes of adequate power to bring them to a skid they would stop exactly the same if both operators were equal skill.
larry
/ Why 4 Wheel Drive #85
OK, I'm not taking sides here, I did go to the link provided by jagyzf, there is some good info there, however I think there is at least one error.
In the section on drawbar leverage it talks about angle of pull, and shows a picture (figure 5) of a tractor and a tree stump. There appears to be a chain connected from the tractor drawbar that goes straight back horizontally to the tree stump. The text says that the angle of pull provided by the load is down and back, shown going to the base of the stump at ground level. I believe that when pulling on a chain that the angle of pull is directly in line with the chain, or in this case horizontal. Any thoughts on this?
/ Why 4 Wheel Drive #86
Yes, I agree with you. I mentioned the same in post 78. There is a previous thread where it was discussed about a year ago.
larry
/ Why 4 Wheel Drive #87
I only really popped back on to mention that David Bradley is just one I found for sale on Ebay (in case anyone is interested)
I read the link about the stump pulling thing, and I did not see any problem with any of it except one of the line of pull diagrams. The first one looks funny to me, but the other two are quite reasonable in my opinion.
/ Why 4 Wheel Drive #88
Now I'm not the sharpest tool in the shed and I don't pretend to be. I also agree Figure 5 doesn't seem right in that paper, but 6 and 7 do seem correct along with the rest of the document. Like I said I found it and it fit what I have had in class's on equipment safety. I also agree with JasG at times Spyderlk I can not follow what you are trying to explain at times. Which you may be the smartest guy on the planet, but if you come across in a way that 1) can't be understood, and 2) is to be so unwilling to explain why your point is correct you won't be of use to many people. You say you learned it and it's in your head. I work with engineer's everyday, all of them very smart and hardworking. Not one of them does everything from there head. They know where to find the correct formula, but unless it's one they use everyday they look it up. The electrical engineer's I have worked with carry "pocket" references just because of this. Not say you are wrong, but you are not in my mind explaining things very well and it at times conflicts with things I have learned over the years.
/ Why 4 Wheel Drive #89
PLEASE explain this;
It might be geometry, it might be physics, it might be mechanics that I lack a good enough understanding of.
Just HOW can you set up a tractor to "actually be pulling down on the front end" ?
You hit it. You would have to set up a pull point below ground level!!! - Forward of the rears would be a help too. No sweat. :rolleyes:
larry
The wheels apply force at the ground. If the load applies resistance above the ground you cant be pulling the front of the tractor down.
larry
Note that the description is regarding ground engaging implements. All of their resistance to motion is at or below ground level. So yes in that instance the front end is pushed down. The distance below ground the force is applied times the force applied by the tires at ground level is the net torque trying to rotate the tractor forward [front tip]. If the resisting force is at ground level there is no net torque. If above ground there is net torque trying to back tip the tractor. In each case these torques are proportional to the vertical distance from the level at which the tractor exerts horizontal force to the level at which the load exerts horizontal force.
larry
[[How do you figure that?]].
Nothing I said prevents a tractor pulling a load up a hill. The hill just lightens the front a bit more.
The tires apply force rearward and the axles apply the same force forward into the tractor body. Force resisting motion of the tractor [for acceleration or pulling a load] has effect based on where relative to the ground that force is applied. That resisting force is applied at the tractor Center of Mass [pretty high]for acceleration or when climbing hills. It is applied at the level of the hitch point when pulling a load at steady speed. Accel and/or a hill will still increase the tendency to tip back regardless of the hitch level because of the high COM.
larry
Obviously no, since the axles are the only connection of the tractor to the wheel, whose traction applies the push. Yes, the tractor tries to rotate backward about the axle. A pull point below the axle resists this and a pull point that is below the axle an amt = to the wheel radius will resist it completely. The drawbar not being this low does not counter it completely until the tractor rears up enuf to bring the pull point [bar end] down to ground level - long bars are pretty safe.
While the link has good info, the pull angle diagram on the stump is totally bogus and discussed in a previous thread.
There is a lot of misinfo out there. The most effective weapon is an inquiring nature and an understanding of physics.
larry
larry
larry
I am not getting my information from a site. I learned it previously so it is in my head. Your answer to the motor cycle vs truck stopping gets a 10%. The energys are surely different but so is the rate at which that energy can be subtracted to reach a stop - other pertinent things being equal the rates [at which energy can be subtracted] are exactly proportional to mass. The stopping distance does not hinge on the weight but on brake capacity and tire friction coefficient. With= tire coefficient and controllable brakes of adequate power to bring them to a skid they would stop exactly the same if both operators were equal skill.
larry
I am not unwilling to explain and the above posts go a ways toward it. In the interest of brevity [and laziness] they were written assuming a reader with a good grasp of the fundamentals. Even without that a question about my statement giving you trouble would help me address any issues in a directed manner. Instead were getting arguments that are based on links that the quoter has not fully understood. Sometimes a link will be correct but still mislead. Sometimes they are wrong in part or whole. Even worse there is the posturing, exaggeration, and twisting the flavor of my posts.
larry
/ Why 4 Wheel Drive #90
so, to summarize:
"the angle of the dangle is proportionate to the heat of the beat when the throb of the knob is constant." (unless you have four wheel drive....)
yes, i have been called "thread killer".....
amp
/ Why 4 Wheel Drive #91
larry
See here is the problem, with me and others you are holding us to one standard and your self to another. You can use generality and we have to be in absolutes. Your terminology is incorrect, yet you nit pick and cherry pick mine. You say we are twisting the flavor of the quotes, yet you are the one using brackets to cherry pick what you want.
This all started with a statement I made that a drawbar by design help to hold the front end down and at times push down on the front end, I never said all the time. The drawbar does not need to be longer than the radius of the wheel. As another poster put about the 3 pt hitch, if the front end comes up it would have come up much sooner than it would have other wise.
I will break down my understanding of pull again as plain as I can. Lets start with the most basic pull which is from the ground. As your tractor moves forward you have opposing forces and these are dynamic forces, that will change. I'm not going to go into every little detail but basically as the tractor goes forward the load is going to resist this in 2 ways pulling back and down. This downward force will being to load the rear axle of the tractor. This gives us 2 forces trying to lift the front end, the torque of the axle and the downward pull of the load on the drawbar. 2 forces are trying to resist this, one is gravity pulling on the front end, the 2nd is the drawbars location being below the axle and usually connected forward. Lets say just to get to the good part the load does not move. This due to the down force and the rear force are greater than the forward force, but the tractor has HP and traction enough to move the load. Now the front end begins to lift, once it passes the point of alignment of the attachment points now the drawbar leverage has shifted. Now instead of loading the rear end the drawbar is unloading the rear end and will continue to do so until traction is lost and the front end goes down. This is why a modern farm tractor under normal conditions will not flip.
Now most of the time we don't pull from the ground, we pull from a neutral or even a slightly elevated position. Neutral being one that is straight and does not load the rear. Look at wagon gear, or a manure spreader usually the drawbar is slightly higher than the tractor. These are the conditions that the drawbar leverage work to help keep the tractors front on the ground.
As far as the connection point needing to be below the ground, its all about what force in total is greater. Take 2 bars one bar 1 meter long, the other 2 meters long, apply 100 lbs of force to the end of the 1 meter and 10 lbs to the 2, which one is going to exert the most force all other things being equal? You keep saying that the drawbar would need to be below the ground, again it depend on the force. If the tractor is pulling a 200 lbs load and the operator pops the clutch, I would bet the front end on a large tractor is going to lift if it already has a light weighted front.
Here is a link to artical about a demo that they actually connected a tractor at different points to show just that.
Tractor roll-over demonstrations show severity, reality of accident | Farm and Dairy - The Auction Guide and Rural Marketplace
/ Why 4 Wheel Drive #92
I will break down my understanding of pull again as plain as I can. Lets start with the most basic pull which is from the ground. As your tractor moves forward you have opposing forces and these are dynamic forces, that will change. I'm not going to go into every little detail but basically as the tractor goes forward the load is going to resist this in 2 ways pulling back and down. This downward force will being to load the rear axle of the tractor. This gives us 2 forces trying to lift the front end, the torque of the axle and the downward pull of the load on the drawbar. 2 forces are trying to resist this, one is gravity pulling on the front end, the 2nd is the drawbars location being below the axle and usually connected forward. Lets say just to get to the good part the load does not move. This due to the down force and the rear force are greater than the forward force, but the tractor has HP and traction enough to move the load. Now the front end begins to lift, once it passes the point of alignment of the attachment points now the drawbar leverage has shifted. Now instead of loading the rear end the drawbar is unloading the rear end and will continue to do so until traction is lost and the front end goes down. This is why a modern farm tractor under normal conditions will not flip.:confused:
As far as the connection point needing to be below the ground, its all about what force in total is greater. Take 2 bars one bar 1 meter long, the other 2 meters long, apply 100 lbs of force to the end of the 1 meter and 10 lbs to the 2, which one is going to exert the most force all other things being equal? You keep saying that the drawbar would need to be below the ground, again it depend on the force. [[If the tractor is pulling a 200 lbs load and the operator pops the clutch, I would bet the front end on a large tractor is going to lift if it already has a light weighted front.]]
I use brackets to highlight something that I have something to say about in a quoted post. I dont know why you would call that cherry picking.
Im not sure what you refer to as incorrect terminology. The only thing I can think of that would affect what were talking about is "push down". I use it literally, as increasing the downforce the tractor front has in static conditions or at least non tractive situations. You may be using it as offsetting the tendency to rise exhibited by a less optimum setup.
[This is not part of the drawbar problem. Its COM and acceleration - I mentioned this idea earlier].
I said the pull point would have to be below ground to add more down force to the front. That makes that lever longer than the tire radius lever. Equal force on that longer lever tries to tip the tractor forward at the rear tire contacts . That would put more downforce on the front.
:confused: It looks as tho you are saying that a downward drawbar angle causes a lift force on the back of the tractor. What the downgoing drawbar does is decrease the pull point to at or near ground level where there is a physics enforced balance between tractor and load torque forces. It is then impossible for the tractor to turn itself over unless it has built significant rotational momentum andgets past the point of no return by inertia. Thats why a long drawbar is safer - the enforced balance comes earlier.... -Its possible you meant a downward angle of the chain from the load caused by the drawbar dropping causes the rear to lighten. That is right, but often the chain or other link angle is quite small because the link is long.
larry
/ Why 4 Wheel Drive #93
I want to say these discussions are a bit interesting. My background is Mechanical Engineering and Physics.
(Spyder, I see you just responded again. You strike me as having a handle on these things. That other thread about the 3PH "lift" capacity proved that to me in the end. What's your background?)​
Let me throw this out there to try to help with understanding... This can be broken down to a system of balanced forces and looking at the critical cases of impending movement.
The first illustration is of the only forces acting upon the tractor. Any question of the pulling action can be broke down into these components.
These forces are:
  1. Driving force on the tires, front and rear acting to propel forward, is a result of the axle torque of the machine.
  2. Drawbar force acting to oppose the driving force
  3. Gravity acting upon the CG of the tractor
  4. Support force on the tires acting to oppose the gravity force
That's it, nothing more. Talking about the torque of the axle just confuses the topic in that the only function of the torque is to produce the driving force on the tractors tires.
Now, look at the forces as they act about the pivot point of the rear tire contact patch (FXd). Sum the moments of these forces and that will tell you if you could get rotation. If the drawbar force is large enough, or more correctly the moment, the tractor will come to a point of rotation about the tire contact patch. Every force (it's moment) is trying to rotate the tractor counter-clockwise, except the drawbar force. Look at the drawbar moment as a function of the lever arm. The lever arm is always acting to rotate in a clockwise direction. Always. If the tractor is rotating, the lever arm is getting shorter and reducing the tipping moment.
This is the safety feature of a properly located drawbar; a longer and lower drawbar is quicker acting to remove the lever arm, and thus the moment.
You can move the "drawbar" force to a point below the ground to make a moment that wants to rotate the tractor onto the front tires. This is accomplished by a rigid attachment (3ph of appropriate geometry) effectively extending the machine to a point below the ground surface.
*Now the disclamer- this is not accounting for any theoretical dynamic transient situation where an axle torque could result in popping a wheelie, or a tire frozen to the ground :)
/ Why 4 Wheel Drive #94
This whole drawbar torque and 3ph pushing down on the front end sounds like the geometry of "instantanious center" Basically the center of gravity changes via angles of attaching points to a member. In drag racing you can change your car's instantanious center to create lift of the rearend which increases load on the rear tires, and also less wasted energy from "squatting" the rearend (using energy to compress the springs) By using geometry in the connecting points from the rearend to the car's frame you can utilize axle torque to lift the wieght of the rear of the car. In a "stock" car the factory design will squat under hard acceleration. A factory setup may put the instantanious center in front of the car while a "traction tuned" setup may put the instantanious center in the middle of the car. The trade off is you get more frontend "dive under braking.
/ Why 4 Wheel Drive #95
IMHO, this thread has gotten away from the original question and has gotten tedious...... very tedious... :rolleyes:
/ Why 4 Wheel Drive #97
This thread has gotten real interesting and I always enjoy these types of debates:D
I agree with most of what spyderlk said and even some of what Jasg said.
After following this thread for a few days, here is my understanding of what everyone is trying to say.
Jasg: I think you are trying to emphasize that a tractor CANNOT flip backwards if hooked to the drawbar. I'll agree with this because it is true that the rears will break traction before a flip can happen, BUT...the fronts can come up a foot or so, as explained in one of the links with the remote controlled tractors. Which leads me to Spyderlk's position.
Spyderlk: Correct me if I am wrong but I don't think he's arguing the flipping of the tractor, rather the comment made about hooking to the drawbar putting downward force on the front end.
My understanding of this is that a drawbar, below the axle line, and a straight pull rearward, does indeed help to counteract the axle torque, but not stop it completely. It's about leverage, the drawbar is only about a foot below the CL of the axle. The tires are contacting the ground about 2' or more below the axle cl. The wheels have more mechanical advantage than the drawbar, therefor the possibility is still present to raise the front of the tractor. How far it raises is dependent on several other variables like length of drawbar, weight over front, traction, etc. In all reality, everyone knows that a tractor will break traction first, if hitched properly, but it DOES NOT add more weight to the front end, even if pulling in a straight line.
My conclusion is that traction, or lack of, is the only thing that keeps the front planted, not the hitch adding weight.
For sake of argument, take traction out of the equation. Say that the tires absolutly could not slip no matter what (like frozen, or poured in concrete), hook tractor to something with the drawbar, and put scales under front tires and see what happens. (This is just a hypothetical situation, I hope no one is dumb enought to do this)
/ Why 4 Wheel Drive #98
These forces are:
So, is your point that a plow buried (say 8 inches down) represents a force below ground level that tends to "load" the tractor's front wheels ?
If so.... Well, Yeah, kinda, iffy/maybe.
But (Butt, but, butt) the empirical evidence suggests that the plow ALSO "pulls down" on the 3PH (mostly via tension in the top link) as it lifts soil to turn it - - and that down pull certainly overwhelms any below grade drag.
This is typically "solved" by adding front weights (suitcase) to hold the front end down.
Now I just have to b'leeve that smart old farmers know a thing or three...
They would LOVE to shed those weights off the front bumper and I don't mean just to replace it with a loader.
So given all this time and country experience I think they would have figured out how to keep the front end down by now without using weights, i.e. JUST by mucking with lift arm and implement geometry if it were practical.
{NOTE: "possible" .NE. "practical"}
/ Why 4 Wheel Drive #99
smaller tractors don't have individual rear brakes. having the front wheels pulling gives you a lot more steering in difficult situations similar to what you can get by riding the left or right brakes on a rwd larger tractor.
My Kubota has individual brakes. The issue, is it is about impossible use the brakes to steer in conjunction with the hyrdostat pedal. I have done it, and turned that tractor on a dime. It was an exercise in contortions though :eek: Trying to get a heel on the hydro pedal, and a toe on the right or left brake pedal reminded me of playing that "Twister" game when I was a kid.
I have seen my tractor with a gear tranny. It would be pretty easy to use the breaks for steering. Not with the HST though...
Of other note is power steering. A large percentage of CUT's have PS now days. For the most part, with PS you don't need steering brakes. Sure, they are a benefit for tillage, when you want to make a sharp u-turn to start your next row.
One thing of note, after making some small use of steering brakes on my Dad's 9N and my old Farmall-A, It would seem to be more of and advantage on a tricycle tractor than one with a wide front. With the 9N and the Farmall-A, it sure drug the front tires.
Having my Kubota for 10 years, there have only been once or twice where steering with brakes would have been handy.
/ Why 4 Wheel Drive #100
I find I barely ever use separate wheel breaks on a 4WD tractor, they are always left locked together.
2WD tractor, they are always left unlocked but I still don't think I use them very much.
Only time I can think of using them in earnest is when pulling a heavy load up a hill or something heavy on the linkage with a 2WD and then front wheels are off the ground. Then you use them to steer.
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59910)
2018 VOLVO VNL...
John Deere Loader Frames (A63116)
John Deere Loader...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2013 ISUZU NQR 4X2 REFRIGERATED BOX (A59910)
2013 ISUZU NQR 4X2...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
