Oil & Fuel Oil in 2000BD Brake Drum ????
/ Oil in 2000BD Brake Drum ???? #1
scesnick
Garrett County Md. ( Western Md.)
Kubota MX5100
I bought a new set of brake shoes for my YM2000BD thinking the brakes where shot since the did not work at all. So, i took off the brake housing/plate showing that my brake shoes and the brake drum was just totally covered in oil.
I'm guessing I have a seal that is bad, but which one and where is it located and how hard is it to replace? If i had to guess i would say that the seal in question is #30??? any advice on how to change this oring, if infact that is the reason i have oil in my brake drum?
Yanmar Tractor Parts: BRAKES
OK thanks. I have been trying to pull the drum for the past two hours,( usinf a clutch puller) any suggestions?
/ Oil in 2000BD Brake Drum ???? #5
Had to do the same thing on my 1610D and was tough getting the drums off also. I ended up going to Advanced Auto and buying a three jaw gear/seal puller. I had a two jaw but the way the drum was made the two jaws would not align with anything for the jaws to grab. I have a good friend in Terra Alta and he was born and lived in Garrett county for awhile, super nice area. Best of luck with your project.
You did remove the nut?
LOL !! yeah after an hour or two i noticed the nut,,, (just Kidding)
Danny
So i am correct using the gear puller. BOY that thing is on there ! it makes sme crazy sounds when i wrench on the puller.
/ Oil in 2000BD Brake Drum ???? #7
My drum was rusted on and yes, it made a few groans to start with! Puller jaws came off at least a couple of times too.
2006 HONDA ACCORD (A65057)
2006 HONDA ACCORD...
2008 BIG TEX DUMP TRAILER (A67714)
2008 BIG TEX DUMP...
6 wheels to fit a CAT 120G (A68134)
6 wheels to fit a...
2022 ASV RT135 MAX-SERIES SKID STEER (A65056)
2022 ASV RT135...
Bomag Roller (A63689)
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A68183)
2008 Allmand...
