Mowing why does a rotary mower have only 2 cutting edges?
  • Thread starter washita
  • Start date
   / why does a rotary mower have only 2 cutting edges? #1
W
washita
Guest
came across a ford push mower at a garage sale it had a x style mowing blade 4 cutting edges per revolution why do most lawnmowers only have 2 cuttting edges? is it a hp issue? cost issue? not effective? rough calculation on my push mower is 1135 mile per hour tip speed, I am just curious if any one knows why ?
   / why does a rotary mower have only 2 cutting edges? #2
It requires more power to spin it... that's the only real reason.
I have a double-blade for my Snapper Commercial 21 trim mower. I think they called it a "Ninja" blade -- it's just for mulching. Likr you say, it's more of an X than a + since the cutting edges are about 30-45 degrees from each other, instead of 90 degrees. The idea behind those was that the first blade cut it, and the second chopped the clipping into pieces. That was before the decks were designed to create a vortex underneath them that would keep the clippings up in the air long enough for the blades to chop them repeatedly.
I've also seen aftermarket kits that would mount a second blade at 90 degrees to your original blade.
   / why does a rotary mower have only 2 cutting edges? #3
I wonder if it is harder to balance a 4 bladed blade VS a 2 bladed blade?
   / why does a rotary mower have only 2 cutting edges? #4
I have tried two blades at 90 degrees on my Dixie Chopper, and it did put an extra load on the engine. I have also tried putting edger blades with the single blade. Not much advantage. Someone also makes a disk with 4 small blades to retrofit on mowers. I have one somewhere in my stuff.
   / why does a rotary mower have only 2 cutting edges? #5
Whyaren't mower blades sharpened on both edges so that when the becone dull they can be turned over and the other edge used for a while, like planer blades? Easy. The blade manufacturers would only sell half as many blades.
   / why does a rotary mower have only 2 cutting edges? #8
To make the blades reversible the trailing edge would have to be shaped exactly like the leading edge. The leading edge is designed to cut flat, going under the cut off piece. The trailing edge is designed to lift the cut piece up higher. If the trailing edge was shaped the same as the leading edge, it would have very little lift and the clippings wouldn't be suspended in the air long enough to get chopped up more or blown out well.
That's my take on it. ;)
   / why does a rotary mower have only 2 cutting edges? #9
One more thing... I have two sets of blades. As soon as I change one I sharpen it, wipe it down with oil and put it in a bag for the next time I need it (which is about every 3-4 years!). It takes the same amount of time to switch blades as it does to change them. Put them on your wish list and the next time you order filters, etc... from PT add them to it to get your $50.00 minimum. Or, find some at a local lawn mower shop.
I've been tempted to find some high lift blades and converting my 60" rear-discharge deck to a mulching deck. I'm fairly happy with the current design, however in thick grass I get a windrow out the right side. I can eliminate it by going clockwise around the yard, but I like to "stripe" my lawn and cannot do that with the windrow.
   / why does a rotary mower have only 2 cutting edges? #11
I'd venture a four cutting edge type would be able to move forward faster but require more power as more work is being done.:confused::confused:
Note: the tip speed of the blades would have to be the same.
   / why does a rotary mower have only 2 cutting edges? #13
Honda has microcut. Which is 2 cutting edges, one mounted higher and slightly offset to the first. Not a true x configuration. I havent tried it personally, but ive read a few reviews that claim that do to the fine cut of the clippings, mulching is better (more even no clumps) and you can get more into the bag when bagging.
Whenever i have to replace the blade on my honda mower im going to check on the Microcut blades and see if theyll fit. Also cost and ease of maintenance would be considerations on whether or not ill buy them.
   / why does a rotary mower have only 2 cutting edges? #14
Honda has the Quadra Cut, and Snapper has the Ninja blade. 4 cut per rev.
   / why does a rotary mower have only 2 cutting edges? #15
So on the PT mower spindle, there are those spare holes. Would it make any sort of sense to add blades to those holes? (make each rotor a 4 blade instead of a 2 blade)
   / why does a rotary mower have only 2 cutting edges? #16
Carl,
Show us a picture if your spindles. I think the answer is that more blades on there would just collide with other blades.
   / why does a rotary mower have only 2 cutting edges? #17
You ever pedal an air fan exercise bike? The faster you pedal the harder it gets. If you add another blade to your mower, it will make the machine work twice as hard to spin it just through the air, let alone the grass.
   / why does a rotary mower have only 2 cutting edges? #18
I never thought of aerodynamic drag. Or actually getting that sort of mass rotating.
I upgraded my PT blades from soft 3/8" to hardened 1/2" blades custom made, and it does take the PT more time to wind up that big mower... Also Vibrations are more prevelant...
JJ, Here is a couple of pix of the belly of the beast.
   / why does a rotary mower have only 2 cutting edges? #19
Carl, Thanks.
My new observation on the four holes verses 2. If you wear or strip out the current hole the blades are mounted in, just switch the blades to the other set of holes.
I see you found that fence you were looking for.
   / why does a rotary mower have only 2 cutting edges? #20
As far as the number of blades, you could have from one blade to 20 blades on a mower set up as long as they are balanced, especially the one bladed cutter. The speed of the unit is dictated by the available HP, and motor limitations, and being down right dangerous at extraordinary speeds. One has to keep in mind, the weight of the object being thrown around by centrifugal force. There would be no difference in applied HP or speed, if the weight of the 4 blades equal the two blades, and so forth, with any number of blades.
Years ago, I remember someone came around and was trying to sell a new safety blade for a walk behind Snapper. It was a 14 in disk, with what looked like 4 in harden wire that swung freely in 4 holes. I didn't buy it, but was an interesting idea.
Just another interesting mower concept. Thy hve een around awhile and have there uses.
http://www.seagointernational.com/allenhovermower.htm
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
Eagle Weathervane (A55853)
Eagle Weathervane...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2016 FREIGHTLINER...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
