Land Pride grading scraper
/ Land Pride grading scraper #41
I own a model 700 Adj Dura-Grader and it works very well. From what I have found is that the people who manufacture the dura-grader model developed and patented these types of graders and have been building them for 30 plus years. The unit I own is adjustable. The cutting edge assemblies can be adjusted from an angled position for crowning and grading my roads to a straight position for spreading material and leveling without moving the material to one side of the unit. I have adjusted it into five different positions to due different types of jobs and have come to realize that I would have had to purchase four or five other name brand graders with the angles in the different positions to take the place of this one unit. Also the unit I purchased has a hydraulic top hitch which allows me to adjust the cutting pressure from the rear cutting edge to the front or vise versa while in motion. I am very pleased with this grader and would recommend it to anyone who is in the market for a grading implement. I looked at the land pride I just don't see any reason I would use scarifying teeth to rip up my road. It just seems like it would tear up the top pan of my road and leave streaks in the road which would most likely promote erosion when it rains. That's just my opinion wwww.dura-grader.com is the website where I bought my grader
/ Land Pride grading scraper #43
I just got off the phone with the ABI rep. The smallest size TR3 Rake, 5.5', is $3695. It's 810 lb. and shipping to CA about $450. Their smallest Gravel Rascal, 4.5', is $1995, weighs 350 lb., has an optional actuator for $495, with shipping to CA about $325.
I inquired online with DuraGrader about model 40AD (4'), their smallest manually adjustable, and also about that model with hydraulic top cylinder. The fixed version of that size is $920 and the manually adjustable model is $1170, with free shipping through the 15th of this month. They also have what's called an ATV grader, but it is available in Cat. 0 and Cat 1 3ph versions. There's a 4' model: wt.: 280lbs., price $720.00; and a 5' model: wt.: 320lbs. price $780.00. The blades on these are fixed.
/ Land Pride grading scraper #44
gravelman2000,
May I please ask what the cost of your unit was?
I Purchased my Dura-Grader about 2 years ago and I think I paid around $2,700 Which included the hydraulic top hitch. Also, my grader is a adjustable Industrial Model. I really was impressed with the 90 day satisfactory guarantee and 12 month warranty. I'm not sure if any other company gives that.
/ Land Pride grading scraper #45
I just got a little more info. on the Dura-Grader "ATV" models with the Cat. 0 and Cat. 1 hitch setups. The blades are fixed (not adjustable). You can get them straight across (perpendicular to skids) or set at a crowning angle. They did not tell me how deep below the runners the blades are set.
I have narrowed my search to either a Land Pride 48" model or the Dura-Grader 48" manually adjustable model. The LP has removable scarifers, but the blade angles cannot be adjusted (only their depth). The D-G has blades whose depth AND angles can be adjusted, but no scarifers. Scarifers seem to be a good idea for ripping out the grass that grows between tire tracks and for making rip depth equal to the deepest potholes. Adjustable blades seem good for being able to crown, or to smoothe without crowning, as needed. I do have a 42" box blade, a 42" rear blade, and a sub-soiler. I wish I could get a scraper grader with both removable scarifers AND blades which adjust for both height AND angle, but that beast doesn't exist. With all this in mind, can anyone offer an opinion as to which of the two units would be best?
The dealer should be delivering my Landpride 48" GS any day now. I had a load of stone delivered so as soon as the scraper arrives I'll be able to try it and let you know how it works. Stay tuned!
/ Land Pride grading scraper #47
I'm hoping to get my Landpride 72" grader/scraper tomorrow.
/ Land Pride grading scraper #49
/ Land Pride grading scraper #51
we've had some threads on graders if you do a search - seem to be a decent number of companies making them
/ Land Pride grading scraper #52
I'm not sure what side to side angle the blades can be adjusted to on the Dura Grader but the LP has a 5 degree angle. That's not a whole lot. It helps to maintain the crown but it would take many passes to try and build a crown on a flat drive (not saying it can't be done though - coming from a guy who ditched and constructed his 3/8 mile long driveway with a tractor and a rear blade). Maybe with some tweaking of the blade depth it could be done faster. Wet material just seems to mix and flow over the blades. Dry material will get more of a right to left movement helping to maintain/build the crown. I find it easiest to use my rear blade in the spring to capture the material that has been pushed to the shoulder and quickly bring the drive back to a proper crown. Then I just use the LP grader to maintain it. As mentioned above and from what I have read it is best to get down to the bottom of a pot hole to keep it from returning. The scarifiers work great for that. They are also great for breaking up the top crust during the dry summer and then I just run over with the grading blades to bring the gravel back to the surface.
Finally got my grading scraper on Thursday and had a chance to use it yesterday. Without making any adjustments and without adding any fresh stone I ran it over the driveway several times and was immediately impressed with the results. The crown in the middle is gone and it turned up the old gravel giving the driveway a finished look. Can't wait to make some adjustments, add some fresh stone and try it again. So far so good.:rolleyes:
/ Land Pride grading scraper #54
Couple of questions if you don't mind:
Which tractor were you pulling with and how much power did it take? I am concerned as to whether my BX2200 will be able to pull the 48" model.
What were the presets on blade depth and scarifer depth?
When you say that The crown in the middle is gone... is that a reference only to the grass, or do you mean the drive is level/flat? I presume you do want drainage crown.
Thanks in advance.
I am using the B2320 and there is no strain on power at all. By crown I mean that the center was raised with grass growing and the wheel paths were depressed which made clearing snow in the winter troublesome. Now it's level and I can shape it how I want. I didn't use the scarifier blades and the scraper blades were at about 1/4". Now I can set the blades up above the side skids about 1/2" and put down and spread fresh stone. Probably won't get to that until Monday. Family coming over tomorrow for a cookout. They just don't understand!:D Hope that answers your questions.
/ Land Pride grading scraper #56
Thanks!
Since you have snow, do you plan to leave the surface level or to re-crown? Please let us know how it goes after you lay down the new stone. I'd especially like to know how well the unit re-establishes a crown, as I need to do that on my drive. The drive is on a slight grade and I get only rain, no snow.
Thanks again.
/ Land Pride grading scraper #57
My drive was begining to get a little growth in the middle again and the tire tracks were starting to make ruts. One pass down and back and its in perfect shape again and looks freshly graveled. It has been dry for well over a week. The material does flow much better from right to left when it is dry to maintain the crown. If the material was dry and you made some blade adjustments it probably would not be to tough to create a crown if the road was flat. It would probably take a few passes though. Each time I use my LP grader blade I am more happy with the purchase. I only use the scarifiers to tear up heavy vegitation or get to the bottom of deep pot holes. Otherwise I flip them upside down to keep them out of the way. Here are a couple before and after photos of the work I did yesterday. Once down the drive and then back. Super easy. For those of you who like seat time this may not be a good thing. ;)
/ Land Pride grading scraper #58
I might be out of the norm, but I'd rather have the 'before' driveway. :cool:
/ Land Pride grading scraper #59
mlevendo, don't know if you have this problem or not, I see a little in your pics, but sometimes I end up going back over the center because of a lot of material being left there. Anyway, I do it going backwards and the twin blades make it smooth out just about perfect. ;)
Just a tip that works good for me, may or may not work for you. Your road looks good by the way.:cool: I sure wish that I had grass next to my roads.:(
/ Land Pride grading scraper #60
To each their own Willl. The center grass makes it more of a pain when it comes to snow removal so I like mine grass free.
MntView - I found I get more of the center buildup when material flows over the rear blade too. It also does not spread as evenly when it goes over the rear blade. I have my back blade set all the way up so it does not dig into the gravel (flush with skids). The front blade is set about a quarter inch or so below the skids. I then adjust the top link so it raises the rear of the grader so the rear blade is about a half an inch or so off the ground. The material then flows over the front blade and the rear blade smoothes it out if it become excessive. I don't have too much of a problem with excess buildup in the center of the drive. I do have the driveway crowned down the middle. If you do a more aggressive dig and particularly with both blades you will get the chuncky build up.
Two summers ago when I built the driveway the ditches on both sides were all sand. That fall I picked up some pasture mix grass seed and put it on the slopes and in the ditches. Not much happened that fall. The next spring it greened up a bit but this spring it filled in nicely.
I attached a photo of how I posistion my shanks. I noticed at some times that they can hinder the material in front of the front blade even when set in the highest postion. I like to keep them completly out of the way when not needed.
Bulk Bin (A66408)
Bulk Bin (A66408)
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A64557)
2010 Mercury 15HP...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
