Cutting with Port-a-torch
/ Cutting with Port-a-torch #1
JoelD
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
HI all, hope this is the correct forum, looking for some guidance on using a port a torch.
Will use for cutting as I've got a DC stick welder for welding.
Looking for help in how do I set the regulators, the instructions in the kit are very poor.
Any help is appreciated, I've never used a torch before.
Will be a bunch easier than cutting wheels for some of the metal I cut.
Thank you,
Joel
J J, thank you very much, excellent reference, I've read through twice and saved to my computer. My brother also has a set and he'll also benefit from this.
Thanks again,
Joel
/ Cutting with Port-a-torch #4
Thanks again,
Joel
It is sometimes best to have a spare set of tanks, in case you run out of gas in the middle of a project. Sometimes town might be 40 miles away, and it is Sunday, etc. By the way, Harbor Freight sells those tanks, but you might find them cheaper.
/ Cutting with Port-a-torch #5
Might be a better idea to have 3 or 4 extra tanks available as cutting uses them up quick. Back when I did HVACR work I carried two extras on teh truck, granted I never went through an entire tank in a day but when ya run out and the shop is 20 miles away and the boss finds out you came back to get a tank... you learn to carry 2 tanks.
/ Cutting with Port-a-torch #6
My free advice is unless you need the portability, get the larger 100cf (or so) cylinders.
You'll learn to use the "blue wrench" for heating (can be heat-treating high carbon and some tool-steels), bending, and small blacksmithing/forging projects. Works nice for silver-soldering, brazing and sweat-soldering large copper pipes (1-1/4" and larger). Rusted bolts come out easy.
My thoughts are you will have spent 75% of the cost of a larger set on the Porta-torch.
