Cutting with Port-a-torch
   / Cutting with Port-a-torch #1
JoelD
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
HI all, hope this is the correct forum, looking for some guidance on using a port a torch.
Will use for cutting as I've got a DC stick welder for welding.
Looking for help in how do I set the regulators, the instructions in the kit are very poor.
Any help is appreciated, I've never used a torch before.
Will be a bunch easier than cutting wheels for some of the metal I cut.
Thank you,
Joel
J J, thank you very much, excellent reference, I've read through twice and saved to my computer. My brother also has a set and he'll also benefit from this.
Thanks again,
Joel
   / Cutting with Port-a-torch #4
Thanks again,
Joel
It is sometimes best to have a spare set of tanks, in case you run out of gas in the middle of a project. Sometimes town might be 40 miles away, and it is Sunday, etc. By the way, Harbor Freight sells those tanks, but you might find them cheaper.
   / Cutting with Port-a-torch #5
Might be a better idea to have 3 or 4 extra tanks available as cutting uses them up quick. Back when I did HVACR work I carried two extras on teh truck, granted I never went through an entire tank in a day but when ya run out and the shop is 20 miles away and the boss finds out you came back to get a tank... you learn to carry 2 tanks.
   / Cutting with Port-a-torch #6
My free advice is unless you need the portability, get the larger 100cf (or so) cylinders.
You'll learn to use the "blue wrench" for heating (can be heat-treating high carbon and some tool-steels), bending, and small blacksmithing/forging projects. Works nice for silver-soldering, brazing and sweat-soldering large copper pipes (1-1/4" and larger). Rusted bolts come out easy.
My thoughts are you will have spent 75% of the cost of a larger set on the Porta-torch.
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55301)
2023 NEW HOLLAND...
2016 HINO 195 16FT BOX TRUCK (A54607)
2016 HINO 195 16FT...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A51406)
2018 VOLVO SD75B...
