4310 - Won't turn over
/ 4310 - Won't turn over #1
CreekChub
Been cleaning up the yard today with my folks 4310. Runs all day, no problem. Turn it off and go in the house for a bit, and it won't turn over. Lights on the right side of the dash turn on, but nothing. PTO isn't engaged. I have a feeling this is something stupid, but what am I missing? Thanks in advance.
Edit:
When I turn the key on, headlights are full strength, and HST light comes on for a sec just like normal. Doesn't appear to be a battery issue.
Hydro, so no gear shift lever. As it turns out I think it just overheated. My wife was putting around the yard in high gear... :mad: Anyway, I waited an hour and it fired up. Thanks!
/ 4310 - Won't turn over #4
Good you got it going, don't know if an overheated tranny would prevent it from starting?
I almost never use high range unless on the road, once in a while if traveling far across the yard I'll use high.
JB.
/ 4310 - Won't turn over #5
These things are almost impossible to overheat if everything is in place. My guess, possibly a switch or the whatchamacallit "thermistor" or whatever that has caused an issue for a few people on here.
/ 4310 - Won't turn over #6
I had the same problem on my JD 770 recently.......it tuned out to be a cracked positive battery clamp. Would stay tight just enough to start then it would not. Replaced clamp and problem solved.
/ 4310 - Won't turn over #7
Not a good sign. An engine hot enuf to be stuck is not going to be in good shape even if it frees up when it cools.
larry
/ 4310 - Won't turn over #8
I have a similar problem with my Kubota M9000. When the weather changes: spring and fall, it won't start. Battery checks out ok, but won't start. Turns out there is a film forming on the battery posts that won't allow enough current to pass. The lights work fine, but it won't start. I clean the posts lightly with a file and she fires right up
/ 4310 - Won't turn over #9
Does the 4310 have temperature guages for both engine and transmission?
What kind of readings are you getting when it won't start?
I doubt it is an overheating problem but instead bad connections.
Steve
/ 4310 - Won't turn over #10
You need to invest $5 in a tube of dielectric grease;)
/ 4310 - Won't turn over #11
There is a good chance that your hydro foot lever was not back into the neutral position. I know my 4400 wont start if that is the case.
/ 4310 - Won't turn over #12
I fried my starter solenoid about 3 months ago by jump starting my 4210 with a 200 amp power boost battery charger, b/c my battery needed to be changed. The 10 series don't have the thermister ,but after I changed the starter solenoid , my tractor would not do start still till I put a new battery on it and it's like it reset everything. It has been working fine ever since. Just remember if your battery gets weak and won't hold a charge, replace it asap.
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A66736)
2022 East...
2006 FORD E-350 PASSENGER VAN (A66091)
2006 FORD E-350...
4 PALLETS OF LIGHTS & MISC PARTS (A66091)
4 PALLETS OF...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2007 REINKE TRAILER Combo Spread Axle Flatbed (A67714)
2007 REINKE...
2013 Toyota Tundra Crew Cab Pickup Truck (A66736)
2013 Toyota Tundra...
