4310 - Won't turn over
/ 4310 - Won't turn over #1
CreekChub
Been cleaning up the yard today with my folks 4310. Runs all day, no problem. Turn it off and go in the house for a bit, and it won't turn over. Lights on the right side of the dash turn on, but nothing. PTO isn't engaged. I have a feeling this is something stupid, but what am I missing? Thanks in advance.
Edit:
When I turn the key on, headlights are full strength, and HST light comes on for a sec just like normal. Doesn't appear to be a battery issue.
Hydro, so no gear shift lever. As it turns out I think it just overheated. My wife was putting around the yard in high gear... :mad: Anyway, I waited an hour and it fired up. Thanks!
/ 4310 - Won't turn over #4
Good you got it going, don't know if an overheated tranny would prevent it from starting?
I almost never use high range unless on the road, once in a while if traveling far across the yard I'll use high.
JB.
/ 4310 - Won't turn over #5
These things are almost impossible to overheat if everything is in place. My guess, possibly a switch or the whatchamacallit "thermistor" or whatever that has caused an issue for a few people on here.
/ 4310 - Won't turn over #6
I had the same problem on my JD 770 recently.......it tuned out to be a cracked positive battery clamp. Would stay tight just enough to start then it would not. Replaced clamp and problem solved.
/ 4310 - Won't turn over #7
Not a good sign. An engine hot enuf to be stuck is not going to be in good shape even if it frees up when it cools.
larry
/ 4310 - Won't turn over #8
I have a similar problem with my Kubota M9000. When the weather changes: spring and fall, it won't start. Battery checks out ok, but won't start. Turns out there is a film forming on the battery posts that won't allow enough current to pass. The lights work fine, but it won't start. I clean the posts lightly with a file and she fires right up
/ 4310 - Won't turn over #9
Does the 4310 have temperature guages for both engine and transmission?
What kind of readings are you getting when it won't start?
I doubt it is an overheating problem but instead bad connections.
Steve
/ 4310 - Won't turn over #10
You need to invest $5 in a tube of dielectric grease;)
/ 4310 - Won't turn over #11
There is a good chance that your hydro foot lever was not back into the neutral position. I know my 4400 wont start if that is the case.
/ 4310 - Won't turn over #12
I fried my starter solenoid about 3 months ago by jump starting my 4210 with a 200 amp power boost battery charger, b/c my battery needed to be changed. The 10 series don't have the thermister ,but after I changed the starter solenoid , my tractor would not do start still till I put a new battery on it and it's like it reset everything. It has been working fine ever since. Just remember if your battery gets weak and won't hold a charge, replace it asap.
Rotomec PHD200 (A64911)
Rotomec PHD200...
2015 CAT 730 (A68134)
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
1990 Ford F700 (A64911)
1990 Ford F700...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2020 Chevrolet...
