New W.R. Long grapple/3rd function electric valve on my B2320
   / New W.R. Long grapple/3rd function electric valve on my B2320 #1
tutorbell
Fort Worth, TX
2008 Kubota B2320 - Bar/Turf Tires
This weekend I installed a W.R. Long 3rd function valve and OBG2-48 grapple on my B2320 with LA304 loader. The grapple was made to fit the pin spacing of the LA304 loader arms. Weight is supposed to be 357 pounds and it feels like every bit of it. Third function valve came with a custom bracket that mounts it behind the seat on the right inner fender. I picked up all of the parts and installed it myself.
I purchased the bulkhead plate with quick connects also. There isn't a custom one for this tractor so it just came with a generic 1/4" plate that is supposed to be welded to the torque tube. Room is kinda tight there so I ended up welding it to the reinforcing plate on the inside of the right side loader arm. Everything worked just fine with the one exception being the adapter for the power beyond port on the loader valve was not the right size. Salesman sent me to a local hydraulic shop to pick up the right fitting and have it billed to him.
How does it work? Great! I'm not going to be picking up any huge logs or boulders but I can bite down on enough brush that I can't see where I am going and I have to drive backwards instead. I was very concerned about the lift capacity of the LA304 not working well with it. As it turns out, my salesman at the dealership said they will happily put an LA364 on a B2320 or an LA304 on the B26/2920. Brackets, etc. are the same and it's just Kubota's marketing department writing the specifications so they can upsell the B26/2920 for the greater lift capacity loader. :rolleyes:
I wish I would have known this when I got the tractor--I would have got the LA364 instead! :(
No pictures yet (too much fun using it :D) but I'll put some up this evening. Regardless of what some may say a grapple really does work well on a tractor this small. I was pretty certain I would have to up the relief valve pressure 10% or so to get acceptable performance. After using it for a weekend, I realize there is no need to.
   / New W.R. Long grapple/3rd function electric valve on my B2320 #2
I'm thinking of the RBG2 48" myself on my L3400. I just can't decide between the RBG2 or the OBG2 style. Any reason you chose the OBG2?
Thank you
   / New W.R. Long grapple/3rd function electric valve on my B2320 #3
I was curious if you could give us a break down of what this cost you in all?
Cost is the primary reason I chose the OBG2-48. I didn't price the RBG2-48 but the RBG2-38 was more than $1,800. I originally looked at the RBG2 because it was lighter.
Sure, the following prices are including freight to Fort Worth, TX:
W.R. Long OBG2-48 Grapple................$1,415
W.R. Long 3rd Function Valve
(including bulkhead plate and fittings)....$690
Pictures will be coming tomorrow - I ran out of light tonight.
Pictures as promised. Please don't make fun of my welds, it's just a bracket.
   / New W.R. Long grapple/3rd function electric valve on my B2320 #6
Wow, that looks great! I'm calling about mine tomorrow. Nice clean install you have. Thank you for sharing!
Thanks! Here are some in-use pictures:
   / New W.R. Long grapple/3rd function electric valve on my B2320 #8
It's amazing to me that the WR Long grapple is so much more expensive than the Markham grapple for basically the same thing.
Markham makes a fine grapple for those that have a OEM skid-steer universal adapter or can get one third-party for their loader. I was more than happy to fork over an extra $500 for a turn-key solution. It's unfortunate that Markham doesn't offer custom mounts to fit different models of loaders. They seem to make the majority of their money in the skid-steer attachment business and seem to be happy supporting that market.
If you notice, the W.R. Long grapple has cylinder protection comparable to Markham's HD Grapple Rake. Markham's LD version doesn't have the same level of cylinder protection as Long's.
Didn't notice this at first, but the WR Long grapple has seven bottom tines while the Markham has five. Have seen that others have had Markham customize by adding more tines to the bottom. Don't know how much that increases the price, but I'm willing to bet that it narrows the gap between the two.
   / New W.R. Long grapple/3rd function electric valve on my B2320 #11
I noticed your rear tires. I have been looking for something similar for my b2630. Who makes them? How do like them?
Thanks
I LOVE them, they are known as the bar/turf tire option for the B-series tractor. The rear tires are Goodyear Terra Tire Xtra Tracs in 31x15.50-15 and the front are Firestone Turf & Field in 21x8.00-10 size. I bought the tractor with R4 tires and they gouged up my lawn every time I turned. I traded them in at a loss and paid extra for these. They are one of the tire options on the standard B-series tractors. My salesman said that in his 20 years he has only sold perhaps five B-series with this tire option.
Unfortunately, I had a look at the B2630 model configurator on Kubota's website and it appears that these are not available for that model. It looks like just regular turf tires are available for it.
   / New W.R. Long grapple/3rd function electric valve on my B2320 #13
Thanks for the info.
   / New W.R. Long grapple/3rd function electric valve on my B2320 #14
Nice set-up and installation work:)
The weight of the grapple at 357 lbs isn't probably that much more then my bucket & grapple set-up.
I bought a Tatro bucket grapple for $400 http://www.tatrosite.com/
and a WR Long valve kit ($600) Valve Kits for my B7800 a few year ago.
For a $1000 total it has been a great investment for me as I use it often for moving the maple trees I fell for firewood. I can lift entire huge trees so long as I have a my snowblower or box blade on the back of my tractor.
   / New W.R. Long grapple/3rd function electric valve on my B2320 #15
Very nice! Can anyone point me to post with directions for installing the W. R. Long elect over hydraulic valve kit or the selector valve kit? I'm interested in a bolt on grapple for my LA 724 loader but and leary as to whether I can handle the install.
I got a quote the other day of 519.00 for the Elect/Hydro
and 254 for the Selector valve, this was from Carver Equipement in N.C.
   / New W.R. Long grapple/3rd function electric valve on my B2320 #16
I bought my WR Long valve kit from Carver as well. I don't think you will have a problem installing everything since I didn't and I am not overly technically inclined.
Here is the link I started with but I did have a 24" long by 1" deep steel plate welded to the bucket. The grapple mounted to that.
http://www.tractorbynet.com/forums/customization/79451-tatro-wr-long-grapple-combo.html
   / New W.R. Long grapple/3rd function electric valve on my B2320 #17
I've got the same tires and they fit my uses perfectly. Nice grapple!
EtW, what pressures do you keep in your tires? I have the fronts at 24 PSI, the max listed on the sidewall, and the rears are water filled and I have them at 10 PSI. I find that even at the maximum sidewall pressure, the fronts tend to squirm a bit with the grapple and a full load of brush. I'm debating bumping them up to 28 PSI or so and wanted to see what your experience has been with the pressure and performance of your front tires.
   / New W.R. Long grapple/3rd function electric valve on my B2320 #19
Mine are not loaded. At delivery, the driver told me the tires were overinflated to set the beads. I checked them and they were at or near the max pressure listed on the sidewall.
   / New W.R. Long grapple/3rd function electric valve on my B2320 #20
Thanks for the info. I just can't stand paying over $1,000 from the dealer to install the remote. I just had them do my 50hour service and it's running me 425.00 Ouch!!!
2018 CATERPILLAR 242D SKID STEER (A60429)
2018 CATERPILLAR...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
Electric Golf Cart (A56859)
Electric Golf Cart...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- DEMO UNIT (A56438)
Greenworks...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
