1989 JD 955 engine
/ 1989 JD 955 engine #1
KELLHAMMER
We think the engine is shot. Possibly a bad piston or rings.
Are parts availble to do a rebuild? Might do a compression test to see.
It does run but has a miss and is low on power. Are replacement engine availble or maybe a repower with kubota engine?
/ 1989 JD 955 engine #2
Parts should all be available, but to do it right is gonna hurt, If I remember right there are short blocks still in stock, but you will be tying some serious money up in the repair
/ 1989 JD 955 engine #3
There could be other reasons for misfiring and lack of power. First do the diagnosis, then do the repair. Yes do a compression test, and if necessary do other tests. Check it over carefully.
contaminated fuel, dirty fuel filter, fuel delivery problem, bad/dirty injector(s), injector pump timing, weak injector pump, timing chain/gear issue, worn/burnt valve(s), blown head gasket(a little coolant getting into a cylinder)etc.(what else am I missing guys?)
How many hours on the engine?
/ 1989 JD 955 engine #4
I have rebuilt 3 of those engines, using 0.5mm oversize pistons. A few years
ago, they were a bit over $100/hole for the piston/ring set from JD. If
you have a broken piston, I have some spares if you don't need oversize.
I am about to do a JD4300.
Forget about a new engine from JD, unless you find a 3TNE84RJ in old
stock at a dealer somewhere. I looked for one when I started my first
955 rebuild and I found a dealer who had one....for $5300!
As for replacing the engine with a non-JD, that is a very doable project,
since the 955 has a full frame and no bell housing betw the engine and
tranny. Only a bare drive shaft with no clutch. I considered subbing one
of my bad engines with a gas Honda engine I happen to have. Also, the
955 has its hyd implement pump on the back end, rather than on the engine.
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
TRASH PUMP (A63569)
TRASH PUMP (A63569)
60� Drum Mulcher (A64047)
60� Drum Mulcher...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
2006 Miller Built Gooseneck Trailer (A63116)
2006 Miller Built...
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
