Wood hauler
/ Wood hauler #1
Hookblock
WI
JD 4310
My first trailer, first time with hydraulics. I had everything but the but the hoses. It actually works :D
/ Wood hauler #2
I like it...especially the removable tonque jack.
Is that a 5000lb house trailer axle?
/ Wood hauler #3
That is a nice looking trailer and it dumps!
The axle size looks like it will carry all you can put on it, which is good.
Randy
/ Wood hauler #4
Very nice!
I like how you have the setup on the hitch.
Thanks for the pictures:D
/ Wood hauler #5
Looks great. Those are some hefty rams.
You might want to zip tie your hoses up a little better. They look like they're just looking for something to catch on.
/ Wood hauler #6
Well done using tractors hydraulics, need high sides since it looks like it can handle the weight.
Looks like a little bit of plumbing involved with those DA cylinders, maybe you could some how rig it to split wood, you already have the HD rolling frame, would make one heck of a nut cracker :eek: with those two cylinders retracting.
JB.
/ Wood hauler
Thanks for the replies, the axle is from a mobile home, I cut about 2' out and put it back together. The hitch is an old receiver on a 7''x7''x 3/8 angle, but still flexes a little. The plumbing went well for an educated guess. I still have some finish work to do, clean up the hoses, some welding, and some paint.
/ Wood hauler #8
Are you going to fix it to haul dirt???
/ Wood hauler #9
You need to put some gussets in the angle, just far enough from the ball to allow good radial movement of the trailer tongue. The flex will eventually fatigue and then break the angle.
2019 P.J. Trailer Trailer, VIN # 4P5F82029K1307542 (A65563)
2019 P.J. Trailer...
2021 ASV RT-120 FORESTRY SKID STEER (A65053)
2021 ASV RT-120...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
(4) Yetter Trash Wheels and Cutter (A65640)
(4) Yetter Trash...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
