Chainsaw vs Outboard 2 Cycle Oil
/ Chainsaw vs Outboard 2 Cycle Oil #1
Workstead
Jonesboro, AR
MF 1010, MF 1250 with MF1246 Loader
I have a few gallons of Outboard Motor 2 cycle oil. It's bee a while since I read the label but is does specifically say "Outboard Motor" oil.
Can this be used in my chainsaw? We had a pretty bad ice storm earlier this year and I'm using my chainsaw quite a bit. I no longer have an outboard motor and I thought I would just use it to mix with gas for my saw.
My chainsaw is air cooled and the outboard was water cooled. Would that make any difference? Is 2 cycle oil 2 cycle oil or are there significant differences?
Thanks for any help.
Clem
/ Chainsaw vs Outboard 2 Cycle Oil #2
I use Castrol 2 cycle oil in my outboard, chainsaws & snowmobiles. Can't bring myself to buy that $18 per gallon stuff. MikeD74T
/ Chainsaw vs Outboard 2 Cycle Oil #3
I've always considered two stroke oil to be two stroke oil. Never personally had a problem regardless of what machine I've run it in.
Joel
/ Chainsaw vs Outboard 2 Cycle Oil #4
If you know that the outboard oil is the same mix ratio (say 50:1) you are off to the races. However, a gallon of outboard oil goes into 50 gal of mixed fuel. That's a lot of fuel to keep around for a chain saw. And, mixing the proportionaly right amount of oil for 1 single gal can be tricky. What I do is save the teeny little oil bottles from a chain saw or leaf blower kit and fill them from the gallon jug as needed. That way I keep the 2 cycle motors from smokin' or getting smoked.
BTW: I have a lot of unused snowmobile oil for the same jobs, too, although I actually got it out on the trails this year for the first time in 6 years (Global Warming, don't ya know).
/ Chainsaw vs Outboard 2 Cycle Oil #6
I used some marine 2 cycle oil in my chainsaw one time.......and only one time. The chainsaw over rev'd for a few moments and quit. :( I ended up having to rebuild the engine. :eek:
Don
/ Chainsaw vs Outboard 2 Cycle Oil #7
Most TCW3 oils are not intended for air cooled engines. There is a difference in most air cooled 2 cycle oils and outboard engine oils. The difference is that the majority of TCW3 outboard engine oils are formulated to be used in water cooled engines. If the bottle does not say it is suitable for use in air cooled engines I would not use it, if it does then you should be fine.
/ Chainsaw vs Outboard 2 Cycle Oil #8
One thing I've not done is used "outboard Motor" labeled oil.
I obvisously need to revisit my practice, because I've used standard two stroke in my outboard, which may have been a mistake?
Thanks for the follow-up posts.
Joel
/ Chainsaw vs Outboard 2 Cycle Oil #9
Joel
It could well have been a mistake.
/ Chainsaw vs Outboard 2 Cycle Oil #10
Back when I always used straight non detergent SAE 30 in my old Johnson 25.
We'd burn as much as 25-40 gals every W/E. and 10-15 rest of the week.
Ran that motor 10 years and also sunk it maybe 10-15 times.
When I sold it (10 yrs) the compression was as good as when new!
What has changed? or is it just marketing.
Thanks for the replies.
I'll check to see if the label says it's OK to use on air cooled engines. If it doesn't I willl probablly continue to let it sit on the shelf and wonder what the differences are that could make it damaging to use on an air cooled engine.
Clem
/ Chainsaw vs Outboard 2 Cycle Oil #12
The marine 2 stroke oil isn't designed to run at the high rpm's. Chainsaws and trimmers run about 10,000 rpms, what do outboards run at, maybe 5-6000 max, i dunno.
/ Chainsaw vs Outboard 2 Cycle Oil #13
What has changed is that newer 2-strokes are making a lot more power. Water cooled marine 2-strokes should use a BIAA or NMMA TC-W3 rated oil. Air-cooled 2-strokes (chainsaws, motorcycles, snowmobiles, etc.) should use an API TC rated oil. If you really want to use just one 2-stroke oil go with NMMA TC-W3 TM. The TM designation indicates that the oil is approved for both water-cooled and air-cooled engines. Typically, a water-cooled type oil will be a heavier oil with low detergents, and other additives to prevent rusting and provide anti-oxidant protection. The air-cooled oil will be a lighter oil with higher detergents. The API TC oil costs more to make.
I'd say that if you're running an old water-cooled outboard than the oil isn't that critical, but if it's a high-performance air-cooled 2-stroke, like a modern chainsaw, then the API-TC is a must. My Stihl Pro 361 chainsaw makes 4.4 hp and spins at 13,200 rpm; it needs a TC rated oil.
/ Chainsaw vs Outboard 2 Cycle Oil #14
In fact I do now use the newer designated oils, if nothing else to be on the safe side.
Also since the mixes are much tighter (leaner) I appreciate the need for higher quality.
But still my chainsaw seems not to be fussy as long as it is quality 2-stroke oil.
Biggest hassle to me is liters vs ounce vs gal vs ML etc etc. and then is that can/tank in US gal/qt or is it Cdn gal/qt?
Yes, a member did fwd a copy of a great conversion chart that sure helps. (thanks)
/ Chainsaw vs Outboard 2 Cycle Oil #16
Get the containers marked in liters. Makes for easy figuring.:D
In fact I have some but with age the 'sight guage area' yellows so that levels tend to be kinda difficult to sight accurately.
Fact is I should make a dip stick and that would solve a lot of hassles.
/ Chainsaw vs Outboard 2 Cycle Oil #17
Ok, we want a little more info about what the real difference is between a TC and a TCW 2 stroke oil. Here goes. For starters the W in TCW is for "water cooled". TC, or two stroke oil meant for air cooled engines, use large amounts of ash forming metallic additives while TC-W3 does not. These metallic additives help lubricate the engine when operating at extremely high temperatures or when starved for lubrication.
Truth of the matter is that TC oil is needed for free revving engines while the metallic ash causes nothing but problems in constant load engines like outboards because it leaves deposits. Free revving engines need protection when running lean, and will burn off the deposits TC oils leave during these lean runs. As I already mentioned there are oils on the market that are rated for both air cooled and water cooled 2 stroke engines. They tend to be more expensive because they use a more expensive additive package which can still protect a air cooled engine while not forming deposits in a water cooled engine.
/ Chainsaw vs Outboard 2 Cycle Oil #18
That's nice information to know Dieselpower. Thanks:D
[/the 'sight guage area' yellows QUOTE]
It is quite obvious you do much more work than I Pillion as your containers get to sit outside if they are yellowing!:D
/ Chainsaw vs Outboard 2 Cycle Oil #19
Clem
Heck, in a worst case scenario you could add some STP and use it for bar & chain oil instead of having it on a shelf indefinitely! :D
/ Chainsaw vs Outboard 2 Cycle Oil #20
I've been in the boating industry for over thirty years now. It doesn't make me an expert on two stroke oil but I have learned a few things in those years. Any oil is better than no oil, but the right oil works better than just any oil. Through the years engineers have learned what helps and what doesn't help so much. An air cooled engine runs at different temperatures than a water cooled one, that's why they throw that W in the TCW designation. W for water cooled combustion chamber temperatures. The same oil in an air cooled engine is better than nothing but it breaks down at the higher temperatures resulting in accelerated wear. Even in the two stroke outboards today we have oil specifically formulated for the application, such as oil for injected engines as compared to oil for carbureted engines. Use the wrong stuff and I can vouch for the fact that it shortens the life of the engine sometimes resulting in catastrophic failure. It's not just marketing hype. Compared to the engine, oil is fairly cheap. I'd recommend getting the right stuff.
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
CAT 336E (A58214)
CAT 336E (A58214)
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2023 Peterbilt 567...
2018 Ford E-450 Shuttle Bus (A61568)
2018 Ford E-450...
Horse Weathervane (A61569)
Horse Weathervane...
