TS1910 Replacement Battery
/ TS1910 Replacement Battery #1
chetorba
Member
NE PA
Iseki TS1910, Kubota M5500
Does any one know the correct size battery for a TS1910. The specifications state the the battery is a 12 volt 65 amp. How does that relate to CCA (cold cranking amps)?
/ TS1910 Replacement Battery #2
I think it depends on the particular battery how it tests for CCA, which is amps available at 0-deg.F. for a certain short period of time. A MF-1020 which has a 3-cyl. diesel of about the same HP rating as the TS1910 (21HP) uses a recommended battery with 475 CCA. That should get you in the right ballpark. Apparently the old amp-hours rating of 65 to 70 is not used by the industry much anymore.
Bill
/ TS1910 Replacement Battery #3
Any battery about the same length width hight with the post in the same position that will fit in the battery box will work.
Thanks to both of you for the info
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
2013 Dodge Charger Sedan (A61574)
2013 Dodge Charger...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
SET OF (3) CHEMICAL HOSE REELS (A63569)
SET OF (3)...
2006 JOHN DEERE 160C LC EXCAVATOR (A64279)
2006 JOHN DEERE...
