Top Link Pin - Homemade ballast box
   / Top Link Pin - Homemade ballast box #1
RobR
Kent, Wa
Kubota BX1500
I have a question regarding the top link pin size. Would it be a good idea to use a 1/2" pin as the pin when attaching a homemade ballast weight? I am building a concrete block (~350 lbs) for my BX1500. I have a 1/2" pin from an old hitch receiver and was wondering if I can use that? Or do I need to purchase a 3/4" pin?
   / Top Link Pin - Homemade ballast box #2
I'd say you should be fine with the 1/2" pin for the top link (only) if used for the ballast box. The top link only holds the the ballast upright, there is no other forces on it.
However! If you ever get another implement such as a grader blade or box blade you should get the proper diameter pin. There is a lot more push/pull force involved when using those.
   / Top Link Pin - Homemade ballast box #3
easygo is correct that 1/2 inch would be strong enough but proper size pins are cheap at under $10 and you won't get get any clunking with the extra play.
   / Top Link Pin - Homemade ballast box #4
I agree 100%, and that extra play could damage the ball in the top link. Pins are cheap.
   / Top Link Pin - Homemade ballast box #5
I agree , half inch will work, but do you want to have it rattle back there a bit and hear it everytime you stop ? besides, If you are building a concrete ballast, now is the time to add i the 2 inch receiver tube before concrete is set so you can slide in a hitch when you need to tow something.
Looks like 3/4" is the answer. I appreciate all of the feedback. Thank you!
Rob
   / Top Link Pin - Homemade ballast box #7
Don't forget pictures of the ballast box!
When I get it built I will share some pictures...
One more thing. I just realized that I need a 3/4 hole in the piece steel I have. That $10 pin just got a bit more expensive.... hmmm... Maybe a piece of pipe used as a bushing? 1/2 inner with 3/4 outer diameter.... just a thought.
I will have to see where to get a bit that big.
   / Top Link Pin - Homemade ballast box #9
I believe you will need (2) 3/4 holes... one on either side of the toplink.. from there.. you could use a cat 0-1 bushing and use that 1/2" bolt.. etc.
soundguy
   / Top Link Pin - Homemade ballast box #10
I second this comment (I didn't think about doing this to mine until it was too late -- what a pain having to switch between the counterweight and the hitch).
Chevrolet 2500 Flat bed (A56438)
Chevrolet 2500...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
Case 1020 25ft Draper Head (A56438)
Case 1020 25ft...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
Metal Transport Rack (A59228)
Metal Transport...
