Top Link Pin - Homemade ballast box
   / Top Link Pin - Homemade ballast box #11
When I get it built I will share some pictures...
One more thing. I just realized that I need a 3/4 hole in the piece steel I have. That $10 pin just got a bit more expensive.... hmmm... Maybe a piece of pipe used as a bushing? 1/2 inner with 3/4 outer diameter.... just a thought.
I will have to see where to get a bit that big.
Look into getting a step-bit that goes from about 1/4" to 5/8". You can drill holes into material about 3/16 thick and it goes a lot easier then if you bought a 3/4" drill bit. Don't ask me how I know that on a large (1/2" and up) size bit it is very easy to chip the cutting edges and also very easy to drill triangular shaped holes. I don't have a drill press and a hand-held drill makes it all that much harder to complete these tasks. Good luck.
   / Top Link Pin - Homemade ballast box #12
Hello Robr. Welcome to tbn.I have a suggestion for your weight box i welded plate to mount trailer ball to. Works well don't have to take of to put hitch
on if you have trailers to move around.Also thought about a receiver hitch
mounted to bottom for different attachments extra weight would be nice.
Haven'T done that yet. Good luck. Framer
Massey Ferguson 2650, 4WD, Loader, Canopy (A47371)
Massey Ferguson...
3 Point Hitch and Set of Rippers (A48837)
3 Point Hitch and...
Storage Bin (A49251)
6000LB Axle (pair) (A49251)
6000LB Axle (pair)...
2009 Harley Motorcycle (A47371)
2009 Harley...
2013 PETERBILT 367 (A48992)
2013 PETERBILT 367...
