worn valve guide
/ worn valve guide #1
tmar04
YM 276
How can I tell if valve guides are worn enough to cause excessive oil consumption and smoke.(blue/white) Have ym2500 w/3t80 eng, 1000 hrs, runs great, starts good even on coldest of days, but uses 1 qt oil in 8-9 hrs!! seals replaced recently. old seals looked good. Head just checked, no problems. I have changed oil several times, used MMO, synthetic oil and now have 30 W. in it. still uses oil. I hate to tear engine down(overhaul) til I know for sure problem is not in valve train. thanks for the help.
/ worn valve guide #2
If /when you had the head checked . They should have checked the valve guides
/ worn valve guide
is this something that is obvious to the experienced eye? or could they be worn beyond specs, enough to cause excessive oil consumption. like 1 qt in 8 hrs. thanks
/ worn valve guide #4
Valve guide to valve stem clearance should be 0.04 - 0.06 mm or .001578" - 002363". Wear limit is 0.15 mm or .00590". new valve guide ID is 7.00 mm - 7.02 mm or .2758" - 27658".
Danny
/ worn valve guide
Thanks, Danny. I will get some measurements on my guides when I get head removed. If clearance has exceeded maximum, would that allow oil consumption to be excessive? tractor runs great other than oil usage and smoke.
/ worn valve guide #6
Do you have much blowby?
Danny
/ worn valve guide #7
It would be hard for me to pull the head off and not replace the piston rings.
Danny
/ worn valve guide #8
I agree with danny.It is hard to detect worn oil rings with good compression or good compression rings.It would be IMHO to replace the rod bearings and piston rings while I had the top end off and checked then you should have years of service life.If the engine is using oil valve seals or rings since there is no visble signs of leaks.Worn valve stems or bad seals will be oily and dirty inside the head easily visible with the head off. Valve guides essessive valve noise and poor performance the valves will not seat or adjust properly and wear from the movement.I by no means am I an expert but found over the years these thing to be true.I also would check the transmission housing for oil your rear main seal could be leaking I believe there is a drain plug you can remove.
/ worn valve guide
Thanks so much for the kind reply. I already have the new rings and rod bearings to install. Might as well bite the bullet and do it. Tractor does not leak a drop of oil. blowby is minimal. no restrictions in the blowby line. Could be either worn oil rings, broken oil ring and stuck oil rings. just my opinion. will advise more later after dissassembly. Thanks again to all.
2009 Chevrolet Tahoe SUV (A64557)
2009 Chevrolet...
2022 EZ-GO ELITE...
2013 MITSUBISHI FE 4X2 S/A 20FT BOX TRUCK (A67147)
2013 MITSUBISHI FE...
47in GD47 Land Leveler Skid Steer Attachment (A64553)
47in GD47 Land...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2013 Vermeer Vac-Tron LP855SDT T/A Vacuum Trailer (A64194)
2013 Vermeer...
