Backhoe Design Ideas
/ Backhoe Design Ideas #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
I've been daydreaming about building a backhoe attachment for years now, and I think I'm almost ready to start the build. I blame Moss Road for getting me started since his backhoe build thread was (is?) so detailed and helpful. I've also watched the whole series so far on YouTube of a guy building a towable backhoe. This is a very helpful set of videos. I just wish I had the shop and tools that he has. He's not bad on the guitar either.
I've looked at the examples from the P.F. Engineering mini backhoe site, the Ubuildit site, and the CADdigger site. Each plan has parts I like, but I'll probably end up doing a modified hybrid plan. Anyone who has opinions on any of these plans, please chime in. I'm hoping to benefit from the collective wisdom of TBN as I complete the design phase of this project. I want first-hand, real-world opinions.
With that long winded introduction, here's the first question... Some plans have a straight boom, some have a 20 degree or so angle in the boom. What's the advangate to one over the other?
/ Backhoe Design Ideas #2
Curved have lower transport height for the depth.
There are probably other benefits too, only the OLD stuff (like I own) have straight booms.
/ Backhoe Design Ideas #3
One of the main advantages of the curved main boom is the ability to dig deeper closer in -- You do not hit the boom on the edge of hte hole.
Mike
So, for the backhoe owner/officianados... What do you find yourself needing more often, Depth, or reach?
It seems the curved boom is the trade off between reach and depth.
/ Backhoe Design Ideas #5
Whats your use plan? I keep thinking about converting mine to extend. I don't think that you will loose much reach by curving the boom. Trenching and pond clean out reach is good.
Phil
/ Backhoe Design Ideas #6
I have a strait boom on my BH and I would opt for reach vs. depth. In most cases I don't dig further than 4' deep. Another pro on a BH is that it's frame mounted and not 3 pt. The ability too move yourselft with the BH is a huge advantage in my eyes vs having to move the tractor to repossition.
The big push right now is to dig a foundation for a deck we're putting out in front of our house. I'll have to dig about 5 feet down. After that I will be digging trenches for water lines, electrical, planting trees, etc. Then I'm going to have a special section of the property that is set aside for digging holes and then filling them back in :).
/ Backhoe Design Ideas #8
I owned a caddigger 628 and then cut off the motor and frame mounted to my Kubota b6000e.
A guy (Al) in VT built mine, I **** and built the frame mount myself.
I ended up selling the machine with the hoe and loader.
Couple of personal experiences (I used as towable for a couple of years prior to converting to framemount).
1) Super strong backhoe, I actually bent the pin between the boom and the dipper, I ran 3000 psi and that thing had approximately 4000 lbs of ripping force, I literally did not find a rock I could not dig up.
2) Super reliable backhoe, never had a single problem.
3) Super simple backhoe, very straight forward to work on, replace pins and bushings, etc.
I miss that backhoe, it was amazingly strong for it's size, feels as though my 7.5 foot hoe on my Kioti has less ripping power than that little machine did.
I recommend the caddigger product big time and I recommend Al's backhoe building in Vermont (not sure if he's still out there).
Sincerely,
Joel
/ Backhoe Design Ideas #9
A bunch of years ago I built a (freestanding) CAD digger. I used it hard for exactly the things you describe. It was a wonderful addition to my stuff. I even used it for some very interesting applications like being lowered down over a very steep embankment to make emergency repairs on a frozen drain field where the earth was frozen to the point that a pick would just bounce much less use a shovel. I could go on.
The point I'm suggesting is that I am a pretty good scrounger, the engine was free, the steel was either scrounged or surplus at somewhere around $0.10 to $0.20 a pound, the cylinders about 1/2 new price, wheels and tires used, etc. The hoses, controls, bucket teeth, welding rod and paint were about the only things I paid full price for. I did add a couple of things like a roll bar, second bucket, and canopy. It still came out to be about $1500.00 in 1970 dollars.
I didn't mention a couple of special tools like reamers, more hole saw sizes, abrasive saw blades, grinder wheels etc.
I also didn't mention a whole lot of labor, in the hundreds of hours. Don't get me wrong, I love creating things and enjoyed the process totally. But I probably could have spent the time better using the backhoe to do the dirtwork. But at the time money was a consideration plus the price for this same or a similar machine was as I recall in the $4000.00 range
Bottom line, if I was to do it again, I would think very seriously about one of the HF hoes (#65162) which will be on sale with a $400 coupon from (Mar 18 - Apr 5) ($2999.00 -$400.00)
I've used my digger in a whole bunch of applications; by itself, hooked to the tractor, hooked to a pickup (the over the bank adventure) dismantled and re-assembled under a house, in a barn, in a lake and so on. I long lusted for a backhoe attachment, but after I built this, I realized I could do more things by keeping the tractor free, like move the spoil with my tractor, or backfill while digging, or bring gravel for curtain drains, or (more or less) safely put the digger into places I wouldn't dream of putting the tractor with an attached backhoe. Plus the other advantage was that the digger was ready to go at a moments notice with no tractor subframe, no hookup other than a trailer ball.
I can't attest to anything about the quality or reliability of HF's hoe, I've never even seen one of theirs for real. I'm only saying I've had some very positive experience with a towable hoe, and speaking strictly for myself, I would do some checking.
Stay well
Sherweld
/ Backhoe Design Ideas #10
The 3 things I wish my BH had more of are;
1) reach
2) reach
3) reach
And my bh's both have 17'9" reach from the swing post and are rated to do a 22' 11" trench 4' deep (by digging under the machine).
1) reach
2) reach
3) reach
I was wondering if that would be the case. I've noticed that all of the name brand hoe attachments are straight boom (i.e. Massey Ferguson, New Holland, etc.). The only curved hoes I'm seeing are on construction vehicles and P.F. Engineering's homemade plans.
I also wonder if there is some kind of transport advantage to the curved boom. Maybe the bucket tucks up closer to the boom or something like that.
Okay, Next design question...
Is it worth it to get a PTO pump? My onboard pump is rated at 4.8 GPM, but some of that is taken by the power steering priority valve. I can get various pumps from Surplus Center in varying GPM ratings that I could run off my 2000 RPM midmout PTO. I can get a pump for under $100, but I'd have to get a tank, filter, etc. to set up the system. If I run it off the tractor it only costs me a little more hose and a QD fitting.
Thoughts?
/ Backhoe Design Ideas #13
Perhaps someone can elaborate on Airic's comment on not being able to reposition the tractor with the backhoe, if using a 3PH mount? I have already made up my mind that I am going to use a 3PTH mount on my project which should make the intitial hook up easier. I am thinking that on a 3PTH mount the lower link arms will only position the BH fore and aft and you would still need a couple of stought support brackets to triangulize the mount and lock it to allow lifting the weight off the wheels onto the stabilizers. Why would I then not be able to drop the tractor back down and push it forward with the bucket? (Perhaps I miss-interpeted the comment) thanks Dave
/ Backhoe Design Ideas #14
The 3PTH has lift power but no down force at all. If you lift the Hoe with the bucket the tractor stays in place. I can get a little lift due to binding on the toplink but not enough to lift the tractor. I am in the process of frame mounting the Hoe for that very reason.
Harold
/ Backhoe Design Ideas #15
I've noticed that all of the name brand hoe attachments are straight boom. The only curved hoes I'm seeing are on construction vehicles and P.F. Engineering's homemade plans.
That is not really true. Woods' back hoes have curved main booms and it is an option on the CAD Plans bh's. I would say that MOST of the current production machines have curved booms. That includes the name manufacturers like NH, Kubota, Woods and JD.
The curved boom is now the standard. Its advantages include digging deeper and closer to the machine, more compact, stronger, and better aesthetics. :)
Mike
/ Backhoe Design Ideas #16
Thats interesting because I looked at several comercial 3PTH backhoes and they have hydraulic stabilizers, how do they work if there are not some extra parts to keep the 3PTH backhoe locked in a specific position. My plan was use the 3PTH and then I could easily hook up the BH and raise it to a static position and then attach some brackets to maintain that static position. In the case of my MF135, there are a series of holes cast into the rearend housing that I would use for these brackets.
/ Backhoe Design Ideas #17
Thoughts?
If you go to a hydraulic site with calculators for cylinder speed like;
Hydraulic Cylinder  Speed Calculator
you will find out how slow 4.8 gpm is. (think frozen molasses in January).
Typical operations will have you using the boom cylinder, the dipper stick cylinder and the bucket cylinder at the same time. That's how you dig a flat bottom by raising the boom, crowding the dipperstick and un-curling the bucket all at the same time. Then when you lift, you are using the boom, dipperstick, bucket and swing cylinders all at once. You can probably put postion locks on the controls and get off and brew a cup of coffee while it does that! My hoe has 22 gpm and it is too slow.
I would advise against the mid-pto option. You will loose clearance and you WILL rip it off when using the FEL. Find a used 540 pto pump for $100 and encorporate the hydraulic tank into the box of the hoe. 5-10 gal will be plenty. Naturally, more is better, but the practical improvement from 5 to 20 gal on a hoe the size you are making is very very small.
jb
/ Backhoe Design Ideas #18
That calculator is a neat thing. So my bucket cylinder using 24 inch stroke will only take 3.9 seconds to extend and 2.4 seconds retract. Thats with a 2" cylinder and 5GPM pump. For my needs that will be pretty fast. We are talking homemade backhoes. Note the one on the Harbor Freight site has a 2.5GPM pump. With the same pump a 6inch cylinder would take 34 seconds to extend so yes that would be slow.
Hydraulic Cylinder* Speed Calculator
jb
Where are you finding used PTO pumps for $100? :confused: If I could find that kind of a deal, I might just go with it.
One of the reasons I'm thinking of going with the mid PTO is that I may convert the loader to run off it too. I have nothing else that I'm running off the mid PTO, and I'd probably just disable the seat safety and leave it hooked up permanently. Then I could use the rear PTO for the tiller or bush-hog without needing to remove the loader.
As far as clearance goes, I'll have to measure. I'm already pretty low due to mounting the Loader subframe under the front wheel drive shaft. The surplus center pumps are about 5 inches, and I think I'd have the clearance. The only thing I'm still unsure of is how to adapt from the splined shaft of the mid PTO to the Pump.
I suppose I could figure my onboard pump output by timing my loader arms. What's a typical time for a backhoe boom cylinder to fully extend or retract?
/ Backhoe Design Ideas #20
My 3pt Backhoe mount is braced to an oversized 2 pin toplink. Once the pins are in the 3PT cannot move up or down. It is not as rigid twisting as a frame mount would be, but I can move the tractor around with it.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
JOHN DEERE 325G SKID STEER (A65053)
JOHN DEERE 325G...
48in Hydraulic Forks and Frame Skid Steer Attachment (A64553)
48in Hydraulic...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
