Industrial Massey Ferguson Loader ?
/ Industrial Massey Ferguson Loader ? #1
Killin Time
I have a M F tractor looks like my 135,but has beefed up front end with FEL,
perkins 152 gas engine.there is no model #. Has serial # 9A 98088,,any info
on what model and year this might be?? THANKS
/ Industrial Massey Ferguson Loader ? #2
Can you post a picture?
Aaron Z
Sorry no way to post pic. The tractor is yellow with 3speed H/L trans. with a shuttle shift
/ Industrial Massey Ferguson Loader ? #5
1970 model MF20.
OR....
Maybe a mistake on my part. The MF20 uses the same engine as the 135 but has somewhat different sheet metal. There's an industrial version of the 135 that was a commercial mowing tractor of sorts, the 2135. It used the same sheet metal as a standard 135. You MAY have that. Without a visual, I can't determine which you have. Serial numbers of all "DX series" Masseys were mixed together. It IS a 1970 model though.
/ Industrial Massey Ferguson Loader ? #6
OR....
I looked for some pictures to compare it to, here is what is reputed to be a MF20: http://i91.photobucket.com/albums/k...ction/Coldridge8MF20Industrial135withrear.jpg
Here is a another MF20 (in slightly rougher shape): http://cbemall.com/images/mf20.jpg
Another MF20, this one has a backhoe: http://www.hurryburry.com/MF20.jpg
Here is a 1960's 2135: Antique Tractors - 1960s Massey Ferguson 2135
Here is a 2135 of unknown vintage (which looks a lot like my dads Industrial 30, but the controller on the loader is wrong (dads has a Parker valve on it), IIRC the rod going from the steering box to the power steering is on the wrong side and the rims are different (again IIRC)): http://www.fawcett.cc/Salvage/salvage-images/2008/eq-wt1545-1.JPG
another one (Turf 2135): http://www.fawcett.cc/Salvage/salvage-images/eq-ft1292.jpg
So, Killin Time, do any of those look like your tractor?
Aaron Z
You got it.the 1960s 2135,,Thank you !!!
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
John Deere 4955 Tractor (A66285)
John Deere 4955...
F450 Utility Service Truck (A63689)
F450 Utility...
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
10' Feed Bunk (A66408)
Timberjack 608B FellaBuncher (A62679)
Timberjack 608B...
