Industrial Massey Ferguson Loader ?
/ Industrial Massey Ferguson Loader ? #1
Killin Time
I have a M F tractor looks like my 135,but has beefed up front end with FEL,
perkins 152 gas engine.there is no model #. Has serial # 9A 98088,,any info
on what model and year this might be?? THANKS
/ Industrial Massey Ferguson Loader ? #2
Can you post a picture?
Aaron Z
Sorry no way to post pic. The tractor is yellow with 3speed H/L trans. with a shuttle shift
/ Industrial Massey Ferguson Loader ? #5
1970 model MF20.
OR....
Maybe a mistake on my part. The MF20 uses the same engine as the 135 but has somewhat different sheet metal. There's an industrial version of the 135 that was a commercial mowing tractor of sorts, the 2135. It used the same sheet metal as a standard 135. You MAY have that. Without a visual, I can't determine which you have. Serial numbers of all "DX series" Masseys were mixed together. It IS a 1970 model though.
/ Industrial Massey Ferguson Loader ? #6
OR....
I looked for some pictures to compare it to, here is what is reputed to be a MF20: http://i91.photobucket.com/albums/k...ction/Coldridge8MF20Industrial135withrear.jpg
Here is a another MF20 (in slightly rougher shape): http://cbemall.com/images/mf20.jpg
Another MF20, this one has a backhoe: http://www.hurryburry.com/MF20.jpg
Here is a 1960's 2135: Antique Tractors - 1960s Massey Ferguson 2135
Here is a 2135 of unknown vintage (which looks a lot like my dads Industrial 30, but the controller on the loader is wrong (dads has a Parker valve on it), IIRC the rod going from the steering box to the power steering is on the wrong side and the rims are different (again IIRC)): http://www.fawcett.cc/Salvage/salvage-images/2008/eq-wt1545-1.JPG
another one (Turf 2135): http://www.fawcett.cc/Salvage/salvage-images/eq-ft1292.jpg
So, Killin Time, do any of those look like your tractor?
Aaron Z
You got it.the 1960s 2135,,Thank you !!!
12ft T/A Utility Trailer (A64557)
12ft T/A Utility...
2022 EZ-GO ELITE...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
Smalline 4in. Double Diaphragm S/A Towable Trash Pump (A64553)
Smalline 4in...
2013 PROFAB 200BBL CRUDE TANKER (A65643)
2013 PROFAB 200BBL...
2022 EZ-GO ELITE...
