JD 2305, powerbeyond, rear remotes
   / JD 2305, powerbeyond, rear remotes #1
ChrsDrn
Member
Auburn NH
I am trying to add a rear remote to my JD 2305, I bougth the JD fittings that go to thier powerbeyond kit and then bought the hose of the right length to go to my control valve, not knowing which port on the tractor was the power or return. I connected the tractor end of the hoses and placed other ends in a bucket... fluid came out both... I must be missing something. Looking at the parts catalog the only part of the powerbeyond kit that I can not identify its function is Part #T142616 it is called a "pipe plug". Do you think this is my problem? if so where does it go?
Thanks
Chris
   / JD 2305, powerbeyond, rear remotes #2
I think I can help...but need clarification: Do have have the whole PB kit installed, or did you just buy some parts to add your valve?
On my 4110, and I know on the 2520's there is a plug (relay just a Allen head set screw about 10mm in diameter) that goes into the block mounted between the SCV and the transmission-the plug blocks the flow of oil thru the block and directs it to the OUT port.
Hi Thanks for the quick responce,
Ken,
I only bought the fittings that connect to the tractor from the powerbeyond kit... basicly they are O-ring to JIC adapters.
Jim,
I have read your thread many times very well done. I think what I need to do is install that plug, I just need to figure out where. the tractors hydralics seem to be set up diffently.
Chris
   / JD 2305, powerbeyond, rear remotes #5
Yes, you will need the plug to direct the flow to the ports. It will go somewhere between the two ports.
it appears that the ports are located on the rockshaft control valve, I order the plug today when it comes in I will see if I can bother the mechanics at the dealership for the location where it goes.
Thanks
Chris
   / JD 2305, powerbeyond, rear remotes #7
Here's a link to where you can download the 2305 Power Beyond install manual. I think it will show what you want to know. Just click the link, choose "download now" from the yellow box. Should take under a minute
2305 pby.pdf
   / JD 2305, powerbeyond, rear remotes #8
2305 pby.pdf
That's awesome! It's just what he needs...
yes that is awsome thank you very much
Chris
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
