Kubota Acrobatics & Survival
/ Kubota Acrobatics & Survival #1
Stradbash
SE Michigan
Kubota BX 25
OK, so I think I'm getting close to the purchase of a BX25.
I've read various threads about safety and those about and by people who rolled and or flipped their tractors and so far have only read about minor injuries and educational outcomes for their operators. It seems as though the Kubota ROPS are quite effective!
It occurs to me however that those who had more than minor injuries might not be able to contribute their experiences directly to this forum...
So I'd like to ask for reports of roll overs or flipping of tractors where ROPS and seat belts WERE being properly used and where there was more than just minor injury suffered by the operator. Information about how the accident happened and what mistakes might have been made by the operator would be appreciated and I think valuable to us all.
I suspect the dealers among you would be a good source of this information.
A good part of the reason I'm asking about this is that I have a significant family history of tractor induced trauma and hope to prove that it is not a genetic defect that I have inherited. My wife would never forgive me if I have!
I'll start with the educational bit, though neither tractor had a ROPS.
First incident;
A moderately experienced operator was pulling a mower straight down a mild hill mowing a path in a 30" high meddow down to his pond. There was a 2" diameter tree that had been cut down but whomever did the cutting left it about 18" high. I do not know how fast the tractor was going, but it was pretty clear that he caught that 18" high stump straight on with his right rear tire which climbed the thin stump and dumped the tractor right over, pinning the operator underneath.
Second:
The operator was not very experienced but quite aware of physics, machines and their inherent perils.
This incident was less clear to me. He was either going up a fairly steep road (he had been up this hill many times) with his loader to high and flipped over backwards or he was traveling down that same steep road and drifted off to the side and into a 70 or so degree bank that caused the tractor to roll. I've often had the thought that this happened while he was lighting a cigarette... Either scenario would have resulted in the tractor being in the position it was found in.
I made urns for both operators...
Looking forward to your replies.
/ Kubota Acrobatics & Survival #2
Fortunately I don't have any personal stories to share but just wanted to make sure you've found the safety forum on TBN.
Safety - TractorByNet.com
I don't like to read the horror stories. Someone in my town once lost their little girl off the back and through the disk. It's so easy to take safety for granted. Be safe.
/ Kubota Acrobatics & Survival #3
I've almost flopped my BX23 a couple of times...I now leave the stabilizers at half mast, just in case...ALWAYS wear the seat belt..I know some people feel stupid doing that on a tractor, but they also look pretty silly pinned under the ROPS.
Also keep the FEL low when working in muddy, rutted areas, that takes some of the isses away.
/ Kubota Acrobatics & Survival #4
There were no tractors when genes were created so I don't think it can be genetic. Now carelessness can be learned or genetic. When I get tired I get careless. At 61 when I get tired I quit when it's something that carries some extra hazards. Machinery, guns, cars, chain saws, women, lawn mowers, etc misused or carelessly used are dangerous. In 5 years of tractor use God has spared me a few times through some thoughtless actions, course that applies through my whole life but I can't hide. I just have to be thoughtful with what I am doing. I found out to not drive across a steep hillside when it's wet grass when driving across it when it's dry is no problem. I'm sure we all have some of those but they are probably to many to list. Just pay attention to what you are doing. Keep the FEL as low as possible at all times. I have known people that are so lost in their surroundings that they should never be left alone and they should not own a tractor or a car or even a lawnmower but if your not that clutsy then you may be safer than others that own tractors. Ky has coal mines which is considered dangerous but there are more deaths in Ky on farms than in coal mines so yes tractors can be dangerous as guns can if improperly respected and foolishly treated. If you take any medicine never read the possible side effects that can effect one in 20000 people or you'll never take it. How many hours have people driven tractors and never had an injury accident? Same with guns, cars, etc. I've never gotten hurt other than a limb across the face that caught on the rops on my tractor which mostly surprised me. I have scared myself a few times and realized that I shouldn't do some things they way I was doing them. If your normally careless, don't get a tractor. If your normally careful and thoughtful at what you are doing and aware of your surrounding then you may be a tractor owner candidate.
/ Kubota Acrobatics & Survival #5
John,
That, my friend, was a literary masterpiece!!!! :D
/ Kubota Acrobatics & Survival #6
from timswi
I do the same thing after I did a slow roll over once if I in a high pucker factor angle. When I did roll it loader was up dumping it tire went in a hole that was a bad combination. It was like really sloooooooooow going over I didn't even think to lower the bucket the first time. rps up and seat belt were on
tom
/ Kubota Acrobatics & Survival #7
from timswi
tom
Yup, that's exactly what happened to me when I was moving a tri-axle load of gravel into a muddy mess in my driveway..Got the FEL down in time. All I could think of is $17 large down the drain.
/ Kubota Acrobatics & Survival #8
from timswi
tom
Tom,
I'm assuming you weren't wounded through that debacle?...How much damage to the machine?
I agree with John, above. I got too comfortable with the table saw:eek:, Now I'm the only one at work that can count in fractions:D
/ Kubota Acrobatics & Survival #9
Whenever I'm doing my tractor thing, I keep the FEL bucket as close to the ground as possible...It's a habit and I think it's a good one to remember.
Don
/ Kubota Acrobatics & Survival #10
I always get in trouble with a bucket full of gravel hoisted a bit too high on unlevel ground. For some reason I never have enough counter weight!
New Quick Attach Hay Spear (A61166)
New Quick Attach...
John Deere 995 (A60462)
John Deere 995...
HYSTER 50 FORTIS STRAIGHT MAST FORKLIFT (A59823)
HYSTER 50 FORTIS...
2023 FREIGHTLINER M2 4X2 24FT SLEEPER BOX TRUCK (A59906)
2023 FREIGHTLINER...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
Cat CB24B (A60462)
Cat CB24B (A60462)
