4 WAY FLASHERS NOT WORKING.
   / 4 WAY FLASHERS NOT WORKING. #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
BX 1500 4 way flashers won't flash or light up when switch is turned on.
Turn signal lights do work ok,so I don't think a burned out bulb is the problem .
I suspect the switch or the 4 way flasher.
What do you all think?
How do i go about checking it out?
Anyone got any other ideas?
Thanks,
LB.
   / 4 WAY FLASHERS NOT WORKING. #3
bulbs, flasher, switch, wires & fuses.
   / 4 WAY FLASHERS NOT WORKING. #5
Am I missing something, but shouldn't you just use a different tractor that has the working flashers installed?
* shouldn't you just use a different tractor that has the working flashers installed?
*Good idea.
except this one won't clear snow off the driveway worth a hoot.
Must be the turf tires.:D
   / 4 WAY FLASHERS NOT WORKING. #7
Could the switch have gotten wet? I had that happen to my BX but it did the opposite, wouldn't shut off.
*Could the switch have gotten wet? I had that happen to my BX but it did the opposite, wouldn't shut off.
*I did too with my BX23 but this is the BX1500
that's parked inside.
It was not snowing or raining out side when I was using it yesterday.
   / 4 WAY FLASHERS NOT WORKING. #9
swap the switches around it wont take long to find the problem.
If you have to buy a replacement dont go with the dealer way to high
i bought 3 from this place very cheap.The one your talking about is
a 3 pole i believe they should have it for just a few dollars.
0852/0862 Series Euro-Style Switches
   / 4 WAY FLASHERS NOT WORKING. #10
First check the fuse. Second (assuming it is not the fuse) you need to figure out if it is the switch.. Just unplug the wires from the switch then short them together. If the lights work, the problem is your switch. Same thing with the flasher, short around it to see if the lights light.
If it is your switch, it is probably just dirty.. Pop it out, pop it open, see if anything is broken, clean the contacts, apply a little dielectric grease, put back together. I did this just a couple weeks ago.
Jeff
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
2023 Chevrolet Tahoe SUV (A59231)
2023 Chevrolet...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56438)
2-Row Peanut...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
