Tread direction question
/ Tread direction question #1
Conservation
OK. This sounds silly. But I have never put ag tires on, and I'm not sure I put my R4's on right either. I am putting on my new R1's tomorrow, and want to make sure I put them on the right direction. Does the tread go like an arrow into the earth/snow, pushing loose stuff out, or does it go in like a v, pushing loose stuff toward the center? I think I know the answer, but I don't really want to do the job twice.
Pictures if you got em'. Words if you don't.
Thanks!
/ Tread direction question #2
Using your terminology, you want them like an arrow, with the point of the "V" hitting the ground first. The self cleaning works better this way. The sidewalls will most likely have a directional arrow as well. When run backwards (packing mud at the center of the tread), the tread won't clear. I've never noticed a difference in traction either way, just differences in the cleaning ability.
-John
/ Tread direction question #4
John's description is good, here is a picture to help:
Image courtesy of John Weetman Equip.
/ Tread direction question #5
like this
I forgot to put the caution tape in this trench ;but I'm not digging it back out to install it.
Tilling the dirt with the used BX1500 to make it finer for back filling the trench for the electric line.
Finished trench.
/ Tread direction question #6
That is a unique trencher or is that just your backfiller you are using. I never thought of a tiller as a trencher, but if it works? I wouldnt think a tiller would dig a ditch deep enough to bury electrical cable. Finished product looks great though.
/ Tread direction question #7
Take another look-see the ditch has already been dug with my BX23 BH.
The tiller is just tilling the dirt I took out from diging the ditch before I pushed it back into the trench with this.
/ Tread direction question #8
Actually therte is quite a difference in traction if you are in sand or soft soil. The wrong way will dig holes a lot quicker, the right way will press against the side of the hole, especially with R1s
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
2021 Soil Warrior 4500 (A63116)
2021 Soil Warrior...
300 GALLON FUEL TANK (A62131)
300 GALLON FUEL...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
2461 (A58376)
2461 (A58376)
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
