Ford & IH finalize diesel divorce
/ Ford & IH finalize diesel divorce #61
I have put chips on all three of my diesel trucks with no issues what so ever. The first truck I put one on was my 99 F350, then on my 04 F-250, then on my 06 F-350. I personally like Quadzilla products. I have driven nearly 200,000 miles on these 3 trucks with no effects other than wearing out tires and getting better MPG. I still have 2 of these trucks and use them 75% of the time to tow. I do turn down the tune to about 80HP gain when towing. I put all them on all three trucks as soon as the first oil changes were done at 5,000 miles along with different air cleaners/intakes and larger exhaust.
Chris
/ Ford & IH finalize diesel divorce #62
I'm with ya man, but just arbitrarily saying "add another cat" may not come close to the PPB level the EPA has mandated or else the auto companies would do just that.
maybe your all not following what im trying to say I dont like the emmissons very much they have seemed to ruin the diesel for me, not that i wouldnt own a new diesel because i will one day, but theres no black smoke its weird:eek: the new Dmax and Cummins are very torquey motors even with those DPFs on there havent even been in a 6.4 or even a 6.0liter for that matter.
They do work, more fuel, but I would NEVER buy one. All the things you break will NOT be covered by warranty. GM now has the technology that once hooked up to their scanners that will show a tamper/programmer code.
NOT worth it.
Especially when you have a 360HP/650TQ truck that runs like a dragster right off the dealers lot. :)
I couldn't fathom how on earth anyone could need more than 325-350HP from a light truck, not to mention a medium duty.
My IH with my pump & turbo modifications runs about 270/700 which is real nice for a medium duty. Even when fully loaded, it gets the job done, without excessive wear on my drivetrain.
/ Ford & IH finalize diesel divorce #64
Diamond thats the way to go with any truck gas or diesel, buy it run it for an oil change then put the mods on it. Exhaust,Chip,and intake. I also like to add a little bigger tires and a leveling kit too.
/ Ford & IH finalize diesel divorce #65
Didnt you say you were looking a new dump??
/ Ford & IH finalize diesel divorce #67
Chris
Yep, my Dmax has been chipped since 03 and 7k miles. It now has close to 90k, and the only failures caused by the chip so far has been the tread balding on the rear tires.All 3 sets to date.
/ Ford & IH finalize diesel divorce #70
IMO, I would stay clear of any International medium duty between 02 and 06 with the multiplex electrical system. The multiplex system works similar to cable television, and one multiplex circuit can carry up to 25 channels, which cuts way down on wiring, that is a good thing. The reason I dislike these trucks in particular, is that one, International engineers, in their infinite wisdom mounted the main fuse box under the hood right above the drivers side front wheel, and took very litttle provisions to sheild the bottom of it. Once all this Ohio salt ramped up with calcium chloride coats this fuse box for a year or 2, you can imagine how the 100 or so wires hooked up to it start to break off of their terminals at the worst possible time, or just corrode to the point that their is a ton of resistance, which can realy confuse that multiplex electrical system. Second, I have seen high school kids do neater jobs of wiring their stereo systems than IH did running wires under that hood, can you say rub through. In 07, they finaly cleaned up the wiring and put the fuse box in the cab.
/ Ford & IH finalize diesel divorce #71
Im with ryan im a IH fan but there fuse box was is the worst place between 02-06 then they came out with the new motors the MaxxForces and there great ive road in a few of them,Pete makes a good truck too the 335 i belive is the model seen them at the dealer with the new cat motors and the dealer says stay away from the new cat motors and I have no idea about the GMs heavy duty trucks all i know is its got a 7.8 Dmax.
And back to the EPA happy new pickup diesels, ATS performance is making a high flow DPF so were all good. LOL
All the trucks I have my eyes on are 1998-2000.
/ Ford & IH finalize diesel divorce #73
ID get a pete with a Cat motor then if you can find one with a good price and low miles
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
2007 VIKING TRIPLE AXLE TRAILER (A65643)
2007 VIKING TRIPLE...
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
2006 FREIGHTLINER COLUMBIA (INOPERABLE) (A65643)
2006 FREIGHTLINER...
