3032E non-removable loader
/ 3032E non-removable loader #1
TomWhite
Indiana
Deere 3005
Along with other models of tractors, the 3032E is one I have been looking hard at. The only thing that bothers me about this machine is the loader is a non-removable type. The bucket itself is removable.
Do you think this would cause problems down the line by adding wear to the front axle, wheel bearing, etc.?
Anyone with any real world experience on the increased wear leaving a loader on all the time might cause?
/ 3032E non-removable loader #2
If that loader would fit my 3520 Cab I'd offer a trade...I'd rather have a permanent loader that was SOLID.
I dont think it would cause any increased wear....The loader itself isnt "heavy" compared to riding around at relatively high speeds with a heaping bucket of materials...THATS what causes the accelerated wear. Honestly, the loader on my dads L2900 has NEVER been removed in the 12 years he's owned it.
Thanks for the reply, Dave. Which ever tractor I trade for, it will be used with the bush hog much, much more than any loader work.
You know, the more I read all the threads about loaders and ballast, the more I think that these tractors are not REALLY made for loaders. It gets gets goofy the amount of weight people have to add to use an already expensive option. And I'm not talking about the little 2000 series Deere machines either.
/ 3032E non-removable loader #4
I dunno if I would go so far as to say they arent designed for loaders...I think they are...the axles under these machines are built for loader work. Look at tractor front axles from 25 years ago when compacts were a novelty and look at todays axles...they're clearly designed for loader work...plus another thing that has happened is loader capacities have gone up accordingly...
Ballasting is a necessary thing regardless of tractor use....When we buy a new tractor for farm work (I'm talking real tractors of 175+ horse) we have to ballast them just as much..only difference is alot of ballast usually ends up on the front end...not too many people could sit there and say a genuine "Farm Tractor" isnt designed to pull implements because of how much ballast we need to make em work efficiently...
/ 3032E non-removable loader #5
The loader on my JD970 was slightly "tweaked". I don't think the previous owner ever considered adjusting the loader arms or even bothered with noticing that the loader arms engaged out of sync, etc.
Nonetheless, I spent a fair amount of time getting things straightened out.
IMO - the quick disconnect feature on the FEL is a maintainence area that many owner's ignore or disregard. (Until there's an obvious problem..)
If you don't plan on using the tractor for extended periods of "only" mowing; or, swapping the loader out for a front mounted blade or snow blower, etc. then dropping the bucket is a much quicker option than disconnecting the FEL. And the real need for the quick-disconnect FEL is much less important.
The ballast question is a whole different consideration/discussion than just the option of the removable/non-removable loader - IMO.
Best of luck.
AKfish
Best of luck.
AKfish
Yeah, there will be a lot of times where using the hog will be the main, if not only, work the tractor sees.
With your comments, are you saying that you might actually prefer a non-removable unit (and just dropping off the bucket) as opposed to the maint, of the removable one?
/ 3032E non-removable loader #7
Yup.. I probably removed the loader twice in 3 years. But, I didn't have to mow all summer long or need the use of a blower, front blade, etc.
It really depends on how you see using your tractor. If you want/need to have the least amount of weight in order to avoid tearing up a nicely finished lawn, etc. then removing the FEL would be an advantage. But, brush hogging... drop the bucket and get with it!
AKfish
/ 3032E non-removable loader #8
AKfish
X2, I agree with Fish. I will never take the loader off my tractor, and I work on making it tighter and more non-removable every day. Once you remove the bucket, I don't even feel its there.
nmu, I see by your signature you have about 83 tractors! Heck you could leave one implement on each of them and never need to remove it. :D
Anyway, thanks to all you guys for your answers. I suppose I am just worried about getting a loader that can't be removed and doing EXPENSIVE additional wear to a tractor that would be used mainly for hogging. The property is 40 acres, some wooded, a lake, etc. but with some nice open fields that look really great when maintained.
/ 3032E non-removable loader #10
Just my two cents. I have a 2305/200cx and a 3720/300cx cab. Load and mow with both of them. I've never taken the loader frame off to mow. I do take the bucket off to save a couple or few hundred pounds and not have that extra length hanging on but it's never been a problem to me.
The only time I take the loader off of either is to put on the snowblower on either.
I also tighten up the bolts on my 300cx to take the slop out also, disabling the quick disconnect feature without using wrenches.
/ 3032E non-removable loader #11
I dont understand why it is non-removable. Maybe not quickly removable. I had an older tractor that didn't have a quick-tach system to remove the loader frame but it was just 4 pins (2 for the loader arms and 2 for the hydraulic rams). I then put in 4 quick disconnects in the hoses. I had an old swingset that my father built that we parked it under wrapped a chain around the loader frame to hold it in place. We then pulled the 4 pins and disconnected the hoses and backed away. It initially took about 20 minutes to do this but after a couple times I can unhook it in about 7-10 minutes and hook it back up in about 10-15 minutes. For a couple times a year it wasnt bad. I would want to do it every week though.
As opposed to pins, this loader is bolted at the base of each mast. It would be a royal pain, and even a greater pain to re-mount.
/ 3032E non-removable loader #13
I was really talking about the whole frame coming off just the front part. Pulling the 4 pins and adding quick disconnects. This is how I did it on my old 8n loader frame.
/ 3032E non-removable loader #14
/ 3032E non-removable loader #15
My dealer has a low opinion of the E series tractors. I asked about them because their modest price and high power to weight ratio really appealed to me. For some reason, so did their stying and size, both of which I like. They seem a little bigger than a 2000 series but not as big as a 3000 series. My dealer listed a lineage of reasons why he does not like them, one of them being the "permanently" fixed loader mounts. He says as soon as one buys one there will be some reason to disconnect the loader and it won't come off. I guess he has a point there. There have only been two or three times my dealer has refused to let me buy something, and this was one of those. I guess we can take that for its worth.
John M
/ 3032E non-removable loader #16
I'm not sure what the problem with a non-removable loader is either. I've got the 300CX on my 3520, and I'd much prefer a "permanent" system. The number of times I've had my loader off is exactly zero. The loader really doesn't stick out too far without the bucket if you need more maneuverability. At least in my opinion.
/ 3032E non-removable loader #17
Most of my use is loader work, and I have a removable loader. Although I don't take the loader off very often, getting it out of the way makes doing the 200-hour maintenance chores a lot easier. Also having the loader off made it easier to do some of my modifications to the tractor.
However, I do feel a non-removable loader will be more rigid, the ease of doing major maintenance and if a worse case scenario of major repair is required, having the loader out of the way makes life easier.
I see what you are saying as far as the frame on your 8N. On the 3032E, I don't know that there are actually pins in those locations. I know there are grease zerks in those areas, but I don't know that the frame can be disconnected there.
Thanks for the idea.
/ 3032E non-removable loader #19
I suspect you'll find a 24MM nut on the side opposite the grease zerk. If the nut is removed the pin / zerk can be removed. The head of the zerk is slightly offset from the "pin" so the shaft does not spin, so effectively it can only be inserted in one position.
/ 3032E non-removable loader #20
That is how my upper pins on the 8n where. You could only put them in one way. the lower pins did not have grease zerks into the pins. The zerk was in the end of the hydraulic ram.
