Creating my "Over the Top" Deer Blind
   / Creating my "Over the Top" Deer Blind #41
It has been brought to my attention that the top half of the blind is for Steph and me, but the bottom half is for the kids. It is officially their garage!!! :D:D:D
Eddie
Eddie, I have been going to build a similar tower on one of my fields also. My plan is to cover the entire building and leave an opening so I can pull the atv inside to protect it from being seen by the deer and keeping the snow and rain off it while I hunt. I am debating about building a door for the atv garage and may do so just so I can lock the building up completely from critters and trespassers.
Up top I was going to build it big enough for two people to sit comfortably. I already have a couple Mr. Heaters we bought when Quality Farm and Fleet went under. I use one in my pop up tent right now and it is hooked to a 20 pound propane tank. It last a while and keeps me plenty warm in the popup so I can imagine I will be toasty in the tower once it is all insulated.
I helped build one for my friend (his tower is 20' to the deck) and learned a few things to do and not do. When you get done and finally use it I would appreciate a review of things you like and don't like or would have done different so I can figure those into my stand.
Good luck to you. So far this year has not been good around here. There are very few shots and the deer contest are not seeing many deer come in. I am not sure what happened because there are plenty of deer around but for various reasons they are staying hidden. Of course the first week of season has seen a vast array of weather changes from rain storms to snow storms, 60 degrees to 20 degrees. The one great day was a couple days ago when the winds stopped and before the snow started. The deer were out and moving comfortably.
   / Creating my "Over the Top" Deer Blind #42
Robert could you elaborate a little. Especially on the do not. I would be interested in hearing your experience and I'm sure others who are planning something similar would as well.
jk
   / Creating my "Over the Top" Deer Blind #43
jk
One thing I learned is to not build it 20' to the platform. The supports alone and bracing is substancial and there was nothing gained going 20' for his area. He could have went 10' and been just as far ahead. Another problem with that much height is he has to climb a ladder to get up there which with our snow can be slippery. 20' to the platform makes building a stair case a large undertaking in itself. Even for his propane tank he had to build a platform 12' in the air as his hose for the heater was only 12' long so he has to carry the 20 pound take most of the way up there and strap it to one of the legs. He designed his shooting windows too high so he can't stay sitting to shoot. He made the door tiny for some reason (think Alice in Wonderland, you have to crawl on your hands and knees to get into this stand from the platform. And lastly, he made it too small as far as depth. You are very snug inside and it would be impossible to use this stand for bow season because you can't pull the bow back in there.
I don't want to build a 2000 square foot house for a stand but I do know I want it to be large enough that I have plenty of room and can take my daughter and fiancee with me without them being in the way or uncomfortable. My fiancee went with me the other day to the pop up tent and with the heater in there it made it too crowded. I was fine to shoot out the left window but I wouldn't want to shoot thru the front window as she wouldn't have anywhere to move to.
Regardless to how big you build it off the ground you will want a lot of braceing to help fight the wind. I watch a farmer build a tower on a running gear. That tower was at least 20' in the air on top of the running gear. They are in a very hilly section of the county and were building the stand at the farm and were going to haul it to the field where they wanted it. All I could see is this stand falling over in transit if it made it that long. We have hay racks blown over by winds and they have slats to let the air thru. If I or anyone I know are going to be in one of these stands I am going to build it as stable as possible like Eddie is doing. A few dollars in extra lumber is cheap insurance. I can design it as cheap as possible but I would rather build it to last forever and for it to last it needs to hold up to the elements and wind is going to be one of the hardest elements on a tower stand.
Robert,
I never thought about parking anything under the blind, it's just dead space that I've been wondering about. In time, it will become part of the playground, but until then, it's probably just a place for wasp nests.
Good information on your friends blind. I considered four feet and six feet and twelve feet, but 8 feet just seemed to work the best for what I was hoping to do. I did lower the ceiling height to 7 feet to make it easier to keep warm and lower the overall height a bit, though not a significant amount. I wanted a full sized door to get in and out of and based my wall height on the door opening. With the header in place, I have 75 1/2 inches. If you are over 6'3" tall, you'll have to duck to get through it. I considered puttting the header above the top plates, but decided not to go that rought for the few extra inches lower that I could put the ceiling.
I have sheething on all four sides, and that locks it together real good. No sway or movement with that done. All four of us have been up there and there's plenty of room. Anything less wouldn't work for all of us to be able to enjoy it at the same time.
My window sils are 3 feet off the floor. I put them at that height after sitting in a chair and measuring where I like to rest the rifle. That felt very good, so I went with 20x30 windoows. There's no real advantage to the 3ft height of the windows, but it's just a few bucks more over a 20x20 window.
My last blind had a ladder to get into it. I hated it. Stairs are the only way to go. Just walk right up them. It don't get any easier. The ladder was a struggle to carry the rifle and any gear up there. Allot of the time I would have to make three trips to get what I wanted up there. This time, it's all about being easy and simple to use.
Here are some pictures from today. Steph helped me with the sheething, but we didn't finish. What is up still needs more time to get it all screwed down. Guessing, I think it's about 75% fastened.
After getting the rafters installed, I've changed my plan on the roof. I was going to put in a two level roof, plus a pergula. From the edge, after I cut it for the fascia boards, I'll have 49 inches to where a 2 foot pergula would fit. That's just about right for a single roof and a good sized pergula, so that's the new plan.
Eddie
   / Creating my "Over the Top" Deer Blind #46
It's not over the top, but its better than sitting outside. Opening morning was about 12 degrees, but warm inside :D. I like the stairs, never thought about using them for a stand. I enjoyed watching the progress, some really good ideas and different ways to look at building my next one. The last pic was the newest addition
   / Creating my "Over the Top" Deer Blind #47
It looks like it would be hard to shoot out of the last one:D. Can you bow hunt out of the first one, or is it only for rifle? I can't wait to build one of my own, you guys have me real jealous.
   / Creating my "Over the Top" Deer Blind #48
how do you explain it to your wives when you put the window unit AC in them....
"well, honey, i have to start early seeing where their paths are and where they hang out....."
i think it would be really hard to see/hear/shoot a deer out of a deer stand with a hot tub, AC and a hammock!:D
I did some more to the blind, but it's all small stuff that had to be done, but doesn't really show up for pictures.
One of the key features that I really want is to have a weather vane on a cupola. The weather vane that I bought is pretty big, so my cupola has to be just as extreme. I built it in two peices so that I could get it up there. The bottom half will hold 8 glass blocks. Eventually there will be a light in there to light them up, but for now, they will just be decorative.
After I install the bottom half, I'll install the top half. It slides into the bottom and will allow my to screw them together for a very strong fit.
Wind will not be a problem.
Eddie
I didn't even come close to gettting done what I wanted to do, but that's just part of the holidays and having everyone over for Thanksgiving. I had to clean the shop!!! :D
I did manage to get the cupola installed. That top part was allot heavier then I wanted to deal with, but I went slow and thought about what I was doing first, then moved it from resting place to resting place until it was in place.
Eddie
   / Creating my "Over the Top" Deer Blind #51
Yep it's hard to shoot out of the last one, unless you leave the door open. And it needs heat :D. No you can't bow hunt out of it, I put the windows up to high. Now I have a reason to build another one
   / Creating my "Over the Top" Deer Blind #52
Eddie, your deer stand is definitely NOT as over-the-top as the deer stand in the pictures below. I haven't seen this before, so if you have, my apologies. I thought it had a nice tractor theme to it. Happy Thanksgiving!
Jim,
I have seen the trailer pics before and really admired it. Not sure if it's something I'd want on my land, but there is a certain "cool" factor to it!!!!!!!
Thanks,
Eddie
   / Creating my "Over the Top" Deer Blind #54
Wife's uncle built one that we used for years, but he got sick and sold the property to a neighbor who doesn't allow anyone except him to hunt on the property. Not sure if the stand is even still standing. It was constucted with four by four STEEL posts, 20 foot long, with a smaller sized post added inside at the top to get the height he wanted. Bottom is 20 feet off the ground. He used a ladder built under the floor and gained acess to the 10x10 room via a door in the floor. Everything that went up or down got raised with a rope that hung from the top of the ladder. It was well insulated, heated, with a pitched roof. They talked about added an A/C but power would have been a problem, as it was a long way from the nearest point of acess. The windows were slider types, so you could just slide them and poke the barrel thru. I often worried about breaking the glass, or scratching my stock on them, but they never caused any problems that I heard about. When I used it, I always took a small towel with me to set the barrel on in the window. Other windows could be used to let some of the heat out, as it tended to get really warm in there with the small propane heater going.
David from jax
I really expected to have the roof on and the windows in by the end the weekend. Even now that the weekend is over, I'm still shocked at the lack of progress. Two days of strong winds, one day of rain, another day of heavy mud and Thanksgiving sure can put a dent into the time I had to work on the blind. Oh yeah, the water heater died on me and I had to clean the shop out for Thanksgiving.
When it was raining, I put my door together. I'm still not sure why, but I insulated it. I wasn't going to, but I walked by some 3/4 inch foam at the store, and it was just too overwhelming for me to walk by and not buy any.
Anyway, I did manage to get the weathervane on. It's my deer decoy, I just hope the deer don't know the difference between an elk and a deer!!!
Eddie
   / Creating my "Over the Top" Deer Blind #56
Holy cow Eddie, or should I say holy Elk?
That is one fine looking weather vane you got.
Where did you say you got it? Is it possible to get over an Internet purchase? Too bad you didn't get done as much as you wanted, I know how that goes. Sometimes you get side tracked or little things like the weather screws plans up.
I'm loving your thread so far!!
   / Creating my "Over the Top" Deer Blind #58
Isn't it "interesting" how things tend to break when you have a crowd coming? Last July 4th my septic pump quit working right before my picnic and fireworks. Luckily, I lifted it out of the tank and found it was only a clogged inlet. Whew! I dodged a stinky bullet.
The blind and the vane look like they are made for each other. You are doing a great job.
The holidays and Mother Nature have kept me busy. I didn't get anything done on my deer blind for a month. A few days ago, I started working on it again, but ran into problems right off away. I'm terrified of heights, it's just one of many fears that I have, but this one really challenged me on the roof. I have a certain height that I can function on a ladder, but the closer I get to my limit, the less I can do.
Carrying sheets of OSB two stories up on a ladder was just beyond me, so I used the loader on my tractor. That worked for getting them up there, but was too short for me to get on top of the roof. I tried the ladder, but got too scared with so little room to move around. Up high, I like lots of space and this was freaking me out.
I have a metal set of portable stairs that a client gave me a few years ago. We use it for standing on when putting hydraulic oil into the dozer. I decided to use them on my pallet forks to give me a few more feet of height that I needed to work on the roof of the blind. Since regular pallets are so flimsy, I built one out of 2x4's and 2x6's using three inch screws. It's super tight on the bottom and there is no wobble. I then raised the metal stairs to the height that I needed with an added platform to my homemade pallet. Then the stairs are held in place with two nylon straps. If one breaks, I hope to heck that the other holds long enough for me to get to safety. It's a gamble being up there, but one I"m more comfortable with then the ladder.
I also lock the loader in the upright position for a small bit of safety. My cell phone is in my pocket just in case something happens.
If anybody wishes to warn me against this, or tell me how dangerous it is, thank you. I wont' respond to your warnings, but appreciate the thought.
Eddie
   / Creating my "Over the Top" Deer Blind #60
Wow you have the beginning of a real nice castle. You need to make a 3 more to mark the corners of the courtyard and build walls in between them and then dig a mount around the outside and fill it with crocs :D
Real nice project going there Eddie.
I know what you mean about the heights thing I have my limit also and you still wouldnt of got me on those forks climbing them stairs without my knes wobbling like crazy.
Great work and still looking forward to the final masterpeice.:)
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2019 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2019 KOMATSU...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
204549 (A52707)
204549 (A52707)
2012 Husqvarna LTH18538 38" Riding Mower (A59231)
2012 Husqvarna...
