Snow Equipment Owning/Operating Moving Snow
/ Moving Snow #21
I have a curvy driveway on a slope. I did get chains, but found that when it is icy, even with them it can be difficult unless I went with very heavy spiked chains. Most of the time, the snow is just fine without chains. But, I have learned a method such that I don't use the chains any more. I just keep a few yards of pea gravel off to the side of the drive. Then, whenever it gets slippery enough, I just grab a scoop of the gravel and sprinkle it down the drive. Works great.
/ Moving Snow #22
I also have hilly curvy drive.
What I have been using for the last few years is a relativly cheap grass seed broadcaster that I fill with pea gravel.
Found that a round tub type with cone shaped bottom was best.
Also seed spreaders generally have only one drive wheel so I modified it so both wheels drive.
As you know, you do not need to totally coat the icy surface to get traction, but rather a 'salt and pepper' approach i.e. a light scattering of grit is all that is needed.
I did upgrade last winter as I found (yard sale) a professional seed broadcaster that had a metal differential with pneumatic tires. (again I locked the differential)
Generally with this rig I only need about 2 bags of grit as I spread it quite lightly.
I always get my grit from a hardware store as it is bagged and dry plus I keep a cover over the broadcaster. Adding salt would be a no-no as it would only clump and probably corrode everything in a short while. Dry grit is the answer.
Basically I got the idea from tractor mounted broadcasters and just had to try it.
/ Moving Snow #23
I run a 27 old gravley that has the 18hp kohlerds engine under the seat, under the hood is the battery, gas tank and hydrawlicks, too lift the blower head. I bought some used tire chain scraps that are for roadgraders. they have a standard link with a v welded in the link. very agressive and long lasting. since my machine is 27 years old, it just has 2 wheel drive, so chains and wheel weights make a difference. plus my shrek size body also helps for traction...
/ Moving Snow #24
sanitaire:
Welcome to TBN :D! Nothing wrong with having a little personal ballast ;) :rolleyes:. Jay :)
/ Moving Snow #25
irvingj,
thanks for the reply and photo. I won't have a backhoe - but my driveway is flat as a pancake with no curves. My only issue will be accumulated snow that may have melted and re-frozen.
Since chains aren't cheap, I'll try it with my bucket and blade (and no chains) first!
/ Moving Snow #26
Sanitaire, welcome to TBN!
Yup. I've got a sloping driveway toward the road. Haven't needed chains yet. However, while using my front blade, I've gotten a bit slowed down in the snowbank at the end of the driveway. No problem. Hit the diff lock and away I go! I run R4 tires and wish I could afford a snow blower. Pushing old frozen snowbanks just doesn't work. Cue the FEL.
/ Moving Snow #27
I always enjoy reading the posts on TBN, the information is great and like one fella said, this is pretty close to seat time without the saddle sores... Just to add to the question, has anyone had any experience with chains on the front tires of a 4WD tractor? Particularly a sub-compact. I just purchased a SC2400 with a blower and wondered if front chains were worth the time? The drive way only has a slight incline but it"s about 800 feet long. I've been up here 30+ years and seen it pretty woolly at times but until now I've either plowed it myself, (4WD truck) contracted it, or used a walk behind blower. I am getting to the age where if it were too crappy out I could roll over and wait for the sun, but that won't help anyone else get in or out...lol!! Any thoughts?
/ Moving Snow #28
I did use chains on all four wheels of my Kubota B7100 [16 HP] The rear ones alone made a big difference. Adding chains to the front helped even more.
They helped in snow, on ice and in mud.:D
I do not know if it is advisable to put chains on the front.:confused:
/ Moving Snow #29
I agree with Egon on front chains on hard dry surfaces because of the need for some differential "slippage" with the front differential while in "4WD". I believe one would be "ok" on any surface with some "slip" like mud, snow, ice, etc. Jay
/ Moving Snow #30
Stay with it says the heat.
/ Moving Snow #31
If it takes chains to go I'll just stay!
/ Moving Snow #32
My driveway is quite level. It was recommended that I use them with my ATV 4 wheeler rig, so I used them.
I haven't needed them with my tractor for snowblowing despite how deep and heavy the snow was. I think whether or not you would need them would be specific to your rig. Ask the dealer if any other users have found them necessary.
/ Moving Snow #33
Updates... We've had some snow, not a lot, but also rain. Seems every day when I get home driveway is slushy, in the AM when it's time to go UPHILL, it's all ice. :mad: I'll be glad when cold weather's here to stay and we get only snow. Tractor still has had no problem going up & down driveway with turfs & no chains-- guess we'll see how that works this winter.
Coupla' before & after pics....
  • upper drive:curve.JPG
  • driveway 11:08.JPG
    driveway 11:08.JPG
  • blower 12:1:08.jpg
    blower 12:1:08.jpg
/ Moving Snow #34
irvinj:
Nice looking rig :D! IMHO as a weather geek, IMHO NE will get some snow this weekend. As usual many of the "models" are in conflict. We will probably be visited by an "Alberta Clipper". They generally drop ~3" of snow. There is a possibility that this system could intensify once it reaches the ocean. The storm track will determine who if anyone gets anything. Jay
/ Moving Snow #35
IrvingJ,
Update on my end.....I had the JD950 out a couple of times with about 5 inches of a fairly wet snowfall each time...just plowed the snow with the fel in 4wd....turfs, no chains, and not a spin of any wheel. I anxiously await a big snowstorm! (I'm glad I waited on the chains!)
hondo.
/ Moving Snow #36
Almost the same here, hondo-- little snow, mixed with rain over he past week... My slushy driveway is now an icy driveway. Been going through a fair amount of sand. Right now there's some light snow falling... you know, the type that's just enough to cover the sand and polish the ice up real nice and make even walking treacherous....
/ Moving Snow #37
Here is my new snow blower, I should get to try it out this weekend.
/ Moving Snow #38
Still waiting for some snow to try out my new toy.
/ Moving Snow #39
Well...
Woke up this morning to about 8-10 inches, blowing everywhere. Should see 12-14" before it's all said and done.
It would appear that my wish for some snow to play in has been granted. Now I need to figure out what to do with the car I drove to work ( 50 miles - 2 hours, left the house at 4A), while I clear things out. I know darn well I ain't going to make it back up the driveway tonight, and the last thing I want to do is bury it right in the middle of everything...I suppose I could park it out by the highway at the country church, and have my boy come pick me up in his Wrangler.
Hmmm.....
/ Moving Snow #40
It's been asked a couple of times about chains on the front wheels of a CUT. I have a hilly, curvy 1/4 mile long gravel driveway. I plow it with my Cub Cadet 7260, and have used chains on the front wheels only for 10 years without a problem. Huge difference in overall traction, and also helps to steer it with the weight of a plow on the 3 pt. I have chains for the rears, but have never used / needed them.
Corm
