Installing window sashes in a pole barn
/ Installing window sashes in a pole barn #1
RobA
Chester County, SE PA
Kubota L5030 HST
I had a wood pole barn built 2 years ago and chose not to have any ground level windows since I don't live at that property yet. A guy I work with had windows replaced in his house and gave me 16 window sashes (wood frame, double glazed). Any thoughts on the best way to install them? I'll probably want to hinge some of them for ventilation.
Windows....
Inside wall....
/ Installing window sashes in a pole barn #2
Since you have wood sashes, I think you could screw a roof edge or similar sheet metal angle to the edge of the sash thus forming a flange to screw to the barn siding. There is a roof edge that is made with a lip that could extend over the edge of the sash to weatherproof the joint.
Butch
/ Installing window sashes in a pole barn #3
I'm with tanglefoot.
Cut the hole in the siding that is smaller then the frame and screw them to the siding. I'd run a bead of silicone between them and another around the edge before flashing, but other then that, keep it simple.
Eddie
/ Installing window sashes in a pole barn #4
If it was me, I think I would build a simple 2x4 box frame to capture the sash. With hinges the top you could then cut the opening an inch smaller that the sash. Then screw the frame to the wall. A simple latch can keep the window open slightly, or closed completely against the siding.
Maybe a little more work than just screwing the sash to the wall, but I think it would look a little more finished.
I took a stab at making a window jamb last night. I like the idea of having a unit that could be installed in a rough opening. Sort of like the windows used in new construction that have a flange. Cut a rough opening, slide unit in, caulk it and screw it in place.
I used 2x4's for the frame, 1x3 barn wood for the flange and hinged the top of the window to the top of the jamb. It turned out OK but I think I need to use 1x4 instead of 1x3 for the flange so that I have more wood to attach the unit to the barn. If I go with this design I'll use jack studs to help support the unit.
Outside view...
Inside view...
/ Installing window sashes in a pole barn #6
Looking good. I would use silicon in critical areas. It is worth the effort to have a window that opens especially in the barn with all the flies and spiders.
/ Installing window sashes in a pole barn #7
That will work just fine, and I agree with the 1x4 flange. It will make the rough opening a little more forgiving...
/ Installing window sashes in a pole barn #8
Frame looks good but,
I must be tired but I don't see how you will be hinging that onto the wall ?
/ Installing window sashes in a pole barn #9
On second thought...
Will the window hinge out like that? Or are you planning to have it move inward?
/ Installing window sashes in a pole barn #10
Rob,
Something to consider is that 45 degree miters on windows, and homes in general have a way of opening up over the years and letting water in. If you absolutley want 45's, then be sure to glue them together, seal the heck out of them and keep an eye on them on a regular bases. When the wood shrinks or moves, this opening will let water in.
I like to trim out windows with a straight piece cut to the windows width at the bottom first. Then From the bottom edge of that piece to the top of the widow is how long I make the sides, and the top goes from the outside edge of both side pieces of trim. The way it was told to me was that if the seam comes apart, the water will not be channeled into the window or behind the siding since the top piece of the trim is wider then the window and any water that gets on top of it will go off to the sides.
I don't have any good pictures of any windows that I've trimmed out, but this one shows it if you look close.
Also, from what I can tell in your picture of your barn, it looks like pole construction with purlins. Jack studs are to support a header above the window when stud framing a building, and designed to carry the load over that opening. In your situation, there is no load over the window.
Instead of jack studs, you might consider larger purlins to stiffen up the wall where you cut your opening. In fact, I'm thinking that a 2x6 purlin across the top and bottom of your window opening would also make a good frame for the window itself.
Eddie
The window is hinged on the unit. The unit gets screwed to the barn wall.
Yes, the window will open in.
Rob,
Eddie
Eddie, good point about the 45 degree miters. I like the way they look but I don't want to ask for water problems. I think I'll trim them the way you suggested. Also, I used the term "jack studs" loosely. What I really was trying to do is give additional suport to the unit with 2 2"x4"'s running from the bottom of the window unit down to the next purlin.
I thought about using purlins for the opening and mounting the window on them but then the window sash would stand back from the exterior barn wall.
3' X 4' ROLLING ALUMINUM FRAME TABLE W/ SLIDE OUTS (A63745)
3' X 4' ROLLING...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2005 Fontaine Trailer, VIN # 13N1482C951524579 (A61573)
2005 Fontaine...
(NEW) 12 BLADE GROUND BOG HARROW (A63290)
(NEW) 12 BLADE...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2013 ISUZU NQR 4X2 REFRIGERATED BOX (A59910)
2013 ISUZU NQR 4X2...
