Tools a tractor owner must have
/ Tools a tractor owner must have
Grease gun.
I have an air powered grease gun but it is not the type that keeps on pumping as you hold the trigger down. You have to pull the trigger every time you want it to pump a dollop of grease out. Has anyone used one of the battery powered guns. They look like they might be handy
/ Tools a tractor owner must have #42
I have a Lincoln 12v and I like it. It makes the chore of greasing the tractor less of a pain.
/ Tools a tractor owner must have #43
How is it, say if the zerk was plugged? Does it cut out? How long will the battery last? Lincoln, as in welders etc?
/ Tools a tractor owner must have #44
How is it, say if the Zerk was plugged? Does it cut out? How long will the battery last? Lincoln, as in welders etc?
I haven't run into a plugged Zerk, so I can't really say how the Lincoln will handle it. I suspect it would do the same as a manual grease gun.
I don't use it often, so I can't say how long the battery lasts with regular use; but I bought the gun to make my life easier when greasing the tractor. I just hold the hose end tight to the Zerk after it's attached to the fitting and bump the trigger as many times as needed for a fitting; usually 3 quick bursts. It sure is a lot easier to grease, especially when the fitting is in a tight spot.
I don't believe they are related other than the name. Lincoln Lubrication Equipment
/ Tools a tractor owner must have #45
I bought a cordless impact wrench, and if memory serves it was needed to build the wife's horse run in. She paid for it :D. I got the same brand and voltage as my other tools, drill and such so I have extra batteries charged all the time. I really like the impact to run out and change a tire or do a small chore with out stringing a cord or air hose.
/ Tools a tractor owner must have #46
I needed a pair of snap-ring pliers the other day when I was doing a job for an elderly lady. She only had 4'1" between her fence and shed, and my BX24 was just a tad wide to go through with the BH on. Since it was the BH I was to use in her back yard, my only option was to remove the feet on the stabilizers and reattach them on the other side. Worked out OK, but the proper tools would've been nice.
/ Tools a tractor owner must have #47
I'm surprised that no-one posted "bandaid" or least "needle and thread" if the bleeding doesn't stop.
/ Tools a tractor owner must have #50
Speaking of duct tape.. i had the sole of a boot come off one day and had to silvertape it back together for the remainder of the work day!
soundguy
I used my new zerk fitting opener I got from Northern Hydraulics you take the metal plunger out and fill it full of something like wd40 you put the plunger back in and then after putting it on the grease fitting in question whack the heck out of it with a hammer. I only tried it on one stuck fitting so far but it opened it up really well.
/ Tools a tractor owner must have #53
That's essentially what Nu-Skin is; it just has antiseptic added in. I keep a bottle of it in the first aid kit and like it for small cuts and abrasions that don't warrant a band-aid.
The only nuskin I've ever heard of is the cosmetics company that sells through a Pyramid marketing scheme.
I got the superglue idea when I worked as a scrub tech for a veterinarian when I was in college. On cats they'd use "skin glue" so that there weren't stiches showing for the cat to pick at. The vet said that it was basically superglue
/ Tools a tractor owner must have #54
I just checked the first aid kit and the stuff is called "New Skin." With all the purposeful misspelling of words by the marketing wonks, it's easy to fall into that trap. I'm sure the "New Skin" I keep in the kit is not the same medical grade products available to doctors and other medical industry professionals. In any case, I do like it for small cuts.
/ Tools a tractor owner must have #55
I carry one of these at all times in the tractor. Also use it occasionally in the shop. I know them as fencing pliers. Very adaptable to a variety of tasks.
/ Tools a tractor owner must have #56
Those are truly great tools! I have a newer one with only one set of 'teeth' at the top.. but also have a much older set that have 2 'teeth' acrosss the top.. found it on the road.. great for pulling staples and a good hammer and wire cutter.
soundguy
/ Tools a tractor owner must have #57
on a fencing tool, two teeth at the top are much, much better than just one... I hope I never lose my set!
/ Tools a tractor owner must have #58
I just bought a new fence tool at Tractor Supply (Chinese) in a package. When I got home and opened it, it was so tight it took two hands to open or close it. I have tried everything to loosen it up with no avail. :(
/ Tools a tractor owner must have #59
Put in a couple miles of fence.. by then it will loosen up..
If you got a young kid.. give it to him and tell him to open and close it 5000 times and you'll give him 5 bucks.. give him a can of wd-40 to spray the joint with now and then.. if that don't loosen it up.. then you might have a problem...
soundguy
/ Tools a tractor owner must have #60
Or better yet, take the Chinese made piece of pot metal back to TSC and get an exchange or refund. If an exchange, test it out in the store before taking it home.
Why waste time trying to make a cheaply made tool work properly?
2015 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 PETERBILT 579...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2023 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2023 UTILITY VS2RA...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
