How to charge for stump grinding?
   / How to charge for stump grinding? #11
Around here; the charge is normally by the inch; they measure the widest part of the stump and charge anywhere from $1.00 an inch to $1.75 per inch. Deals done when you have more than one stump.
   / How to charge for stump grinding? #12
$65.00 per hour seems like a good starting point, 85 and above are ideal depending on your location though. Don't forget that u can add fuel charges, soil & terrain variances, travel, & whatever other factors are in your area.
   / How to charge for stump grinding? #13
:D:D Boy this is starting to sound like the utility companies...:D:D
   / How to charge for stump grinding? #14
"Note to self. Never start a stump grinding business in Arkansas."
   / How to charge for stump grinding? #15
I have a guy that is going to grind 14 stumps for some very large tree's at my Church. He charges by the inch as well. His estimate was almost $1300. By the inch seems to be the norm here in the Seattle area. If it weren't for the fact of another piece of equipment to buy and maintain I would add that to doing tree work. There are enough Stump grinders in the Yellow Pages so ask them how they charge.
   / How to charge for stump grinding? #16
Years ago when there were very few stump grinders out there and my Dad was in the nursery business, the charge was $1.00 per inch-inch. In other words if you had a 30 inch diameter stump and wanted to take it down 10 inches it was 30 times 1 x 10 or $300 for one stump. Prices have come down a lot since stump grinders are now so inexpensive and there are so many around. The problem with charging so little is that rhe maintaince on them can be high if you keep busting carbide teeth.
Andy
   / How to charge for stump grinding? #17
I had a stump ground out in suburban NJ a while ago, it cost about $350 for a 36 inch stump so that's in line with the $10 an inch rate.
   / How to charge for stump grinding? #18
dad and the neighbors just has some done- averaged about 100$ a stump, but the calculations were by the inch. stumps were 18"-30 inches across
   / How to charge for stump grinding? #19
any of you guys operate near the DFW area? We have some 6-8" stumps we need to grind up!
   / How to charge for stump grinding? #20
I know this an old thread but I had an Rayco RG stump grinder that cost $39500 with custom trailer. You can't run something like that and make money with it unless you have a major storm. I had a 54 inch Rock Maple that took me 4 hrs. to grind with a telephone pole, sidewalk and steep slope to contend with. Cost the City $600.
I found it was best to look at the job. If I told someone $120 an hour they would choke! They didn't realize I could do a large pine stump (36") in a half an hour.
My first job I figured I'd be 1 1/2 days doing all the large stumps on an estate so I quoted $140 an hour saying it would at least a day. Took me 4 hrs and the guy was happy as heck!
All depends on the size of your machine. If you got a small machine you won't be able work as fast. A powerful machine will do 10 times the work of one of those little ones that look like a rototiller.
2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
2025 HT360W Mini...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
set of 4 tractor trailer tires Roadforce (A56438)
set of 4 tractor...
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
