Grapple Rake Grapple for my 555E
/ Rake Grapple for my 555E #21
You might want to compare the cost of a commercially available Quick Attach which allows use of universal skid steer mounting attachments, such as ATI's Tach-All (see their website at ATI Corporation - Tach-All(tm) Quick Attach). I don't know if they ave a model that fits the 555E specifically, but I'm sure that if they don't there is someone out there that does. They also have attachment plates to convert existing buckets.
/ Rake Grapple for my 555E #22
Here are some more pics. I spent some time this evening with my sissors and some cardboard. My first idea was a disaster, but plan B seems to be a winner. I've created a template and have my measurements figured out, so it's time to have it cut out and welded together.
Does anybody have any suggestions on what type of steel I should buy?
Thanks,
Eddie
/ Rake Grapple for my 555E #24
Since most of the loads are linear, you could go with cold (CRS) or hot rolled steel (HRS). It is less expensive than a tool steel, and HRS is less than cold rolled. But like I said, with it being welded like you bucket shows, they aren't going anywhere. Are there bushings for the pins in the pieces? I would add them if not...even a short length of tubing on each side.
I'm sure you'll get all kinds of suggestions though.
Hi Rob,
I have 8 bushings with zerk fittings already installed on the busings. They just gave them to me when I asked about them, so that was nice. I'll have them welded on when I have the brackets welded onto the Quick Attachment. After that's done, I'll have to think about some bracing or re-inforcement to make it even stronger.
Thanks,
Eddie
/ Rake Grapple for my 555E #26
Thanks,
Eddie
Man, I am interested as can be, and somehow just not following along.
Was your middle picture something that you bought as well from the same guys, that is the magic piece to have, and I am assuming that you took that picture so you have it.
As to the mounts, mine would just be regular mild steel, gain strength by increasing thickness if needed.
That would be a cool mod if you get that done. While I wonder about the strength of the universal quick tach, the bigger tracked skids now days probably have the lift etc. that that 555 has as well, and lord knows they can put some side loads etc on those things, look at the ones carrying the big mulchers and the loads they put on those things.
Looks like it will be neat as all get out!
The other thing I would add, and it will really be a pain, and might not be needed, but I would do it.
TACK all the pieces into place with solid tacks and put it on the machine and try it. I realize it may take an extra trip or two between your place and the welders, but it is sure better to do that then to have the entire assembly solidly welded to find that in the back curl up with loader arms down the quicktach hits a hydrualic line.
Good luck.
/ Rake Grapple for my 555E #27
Thanks,
Eddie
I didn't realize you already had gotten the SS adapter center section. Cool, that'll make the job a ton easier. Would you happen to know how much just the adapter was?
/ Rake Grapple for my 555E #28
Grapple looks great. Nice template for the pin adapter too. Double check the angles to get adequate dump and curl once you put your adapter on. Looks to me like you are duplicating the bucket angles which obviously should work so long as your bucket can dump all the way to put the whole bucket face on the ground and curls enough to hold a load without clamping.
What gauge steel are you going to use for the bracket linking your pins to the QA fittings? Might take some engineering calculations but I was thinking off the top of my head something like 5/16 or maybe even 3/8 give the power of your loader.
/ Rake Grapple for my 555E #29
Nice looking grapple. Do know what the weight was with the two grapples?
Rik
/ Rake Grapple for my 555E #30
Thanks,
Eddie
Eddie,
That's a great template, I suppose you need 4 of those to weld onto the back of the QA right? Due to the size and power of your TLB, I humbly suggest they be 3/8" HRS. Would you be interested in having them CNC plasma cut? That template you made is perfect, it can be scanned and the digital output uploaded into a Plasma Cam plasma cutter, after that, in a matter of a few seconds you could have 4 perfect parts exactly the same. Do you have someone who can do that and cut those parts for you? If you do that's great, if not, I'm offering to help. Perhaps you have seen several of Rob and I's projects were the parts were CNC plasma cut?
Larry
/ Rake Grapple for my 555E #31
Attached is a quickie Auto CAD drawing of your bracket. With some exact dimensions it could be quickly adjusted for a perfect fit.
Larry
Alan,
Yes, I have all the pieces, I just need to figure out how to make them all work together.
I'm not going to weld it together myself. My skills are just not up to that level that I want out of the parts. The welder has everything, and he'll make sure it's all square and lined up. He's the same guy who took apart the bracket for my dump truck when the pin broke and half the bed came down, twisting the brackets. He took it apart, straightened it out and welded it up perfectly square. It's not cheap, but it will be right, so that's worth paying a little extra.
islandtractor,
When I drew the template, the first thing that I did was to coply the brackets that are on my loader bucket. I got the pin spacing and angle exact. Then I cut out the amoutn of steel around the pins.
With that drawing, I cut it out on another sheet of paper to fit the angles on the Quick Attachement part. It was pretty simple, but I still had to add paper to an area that I cut too short.
tlbuser,
I have a stack of stuff with the receipt in there somewhere, but right now, I don't have a clue what it cost. When I find that receipt, I'll be sure to update this thread.
wnsllc,
I'll have to check to see if I have a weight for the grapple some place. It's six feet wide, but other then that, I don't have a clue what it weighs. I have 4,000 pounds of lift on my loader, so the weight of the grapple isn't a concern.
Larry,
I finished off a job on Monday, so I took yesterday off, and brought the template, bushings and Quick Attach to the welder. They are also a machine shop, but mostly they are known for being a place that gets the job done and does it well.
I told them that I wanted it made out of 3/8's steel and then I asked what type of steel did they have? His reply was Stainless, Aluminum and Hot Rolled Steel. It was a no brainer. hahahaha
Thank you for the offer to help, it's very much appreciated. I already tried to talk Rob into making the grapple for me, but only jokingly as I know he has more then a few things going on already. Getting the two of you to help would be like winning the Lottery!!!!!!!
Once the welding is done, it should be a simple task of removing the bucket and instaling the QA Attachement. The hoses are maped out and I made a bracket to hold the switch this evening. I'm letting it cool down right now and tomorrow I'll prime and paint it. Then I'll take a few pics and post them
Thank you,
Eddie
I made a bracket from some angle iron for the valve. I cut two pieces to fit on either side of it so that the hoses would fit and have good access. Then I spray painted it all black. I'm also going to create some sort of cover for it. I'm not sure if it's needed, but I figure it might be a good idea.
Eddie
To make operate the valve, I decided to use a button that already exists on my loader controler. The red button puts my transmission in neutral. I've never understood what this was for or where I would use it, so for the last five years, I've never used it.
Now it will switch the hydraulics from tilting the bucket, to operating the grapple. I just push the botton and then the controler will open and close it. I let go of the button, and it goes back to controlling the angle of the bucket.
Eddie
/ Rake Grapple for my 555E #35
Eddie that button is designed to disengage the trans when you run into a large pile of dirt etc. and you disengage the trans to give the hyd pump full power to lift the load quickly without the trans going into stall----sure saves a trans when using the loader for moving alot of piles of dirt into dump trucks etc.---read the op manual for some tips on using the red button---may save you a trans job!!!
Thanks for the info. That makes sense, though I wonder how you get a full load without the assistance of the tires helping out?
No biggy since I've never used it, and now that it's been disconected, I never will.
Every now and then I'll do a search on Ebay for my 555E and other equipment. I'm always hopeful of finding something like the Owners Manual or some other manual that I might need.
Eddie
The welder is done and the price came to $466 for the steel, cutting the plates, adding two support plates to each side and welding it all together. Unfortunately, out of four sets of bushings, my pin will only slide through one of them. Two are close and one is just a mess.
He'll get it back today and I'm back to the waiting game. The good news is that I'm booked up with work this weekend and there's no rush on when I'll have time to get to it anyway.
Eddie
/ Rake Grapple for my 555E #38
Eddie,
PM me if you want some lathe help with those bushings. (I can't figure out how to PM someone else)
John
Hey John,
Thanks for the help. I'm not sure what happened with the welder, or why he missed three out of four bushings, but they are also a machine shop with a really good reputation. I didn't have the new pins at the time, so it could be that they just didn't have any 1 1/2 inch pins and tried to use what they had on hand. I don't know, but they messed it up and they are the type of place that will make it right. It's one of the reasons I use them, they are the only welding shop in the area with a good reputation that I'm aware of.
In fact, I'm out the door right now to go see them.
Thanks,
Eddie
/ Rake Grapple for my 555E #40
Eddie,
Ah! I just assumed the ID's were undersized and could be opened up. Sounds like something changed after welding? No lathe job, that!
Good Luck.
John
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
2010 Scag STT52V-27CH 52in Zero Turn Mower (A61572)
2010 Scag...
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
2019 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2019 Chevrolet...
