55 Gal Rear Weight
/ 55 Gal Rear Weight #1
SouthernX
Hi All,
I need to make a weight to hang of my 3pt hitch. The old 55gal drum filled with cement would do nicely. I've read some of the old threads on this subject in the TBN forums but I really didn't find a comprehensive set of instructions for the task. I understand the basic design / approach:
1) Insert steel rod through lower portion of barrel.
2) Fill barrel with cement.
3) Set bracket in cement at top of 55gal drum to hook top link to.
That seems easy enough but I do have some specific questions.
1) My three point accommodates either Cat 1 or 2 implements. I assume as the barrel will weigh around 1000lbs that a Cat 1 sized steel rod will suffice. Is that assumption correct?
2) As you all know, not all steel is created equal. I don't want to use a steel rod of insufficient strength only to have the ends snap on me and allow the barrel to possibly fall against and damage the tractor frame. Assuming at Cat 1 size diameter of steel rod, do I need to obtain a rod with a specific tensile strength rating? Does the rod need to have been processed / produced in a certain manner (i.e. cold rolled, forged, etc.)?
3) How far out do most of you allow the rod to extend out from the barrel? 4", 5", 6"???
4) Does it matter much whether you drill the rod and use a pin as opposed to threading the rod and secure it to the 3pt with a lock-washer and nut?
5) What do you most of you use for the bracket on the top that attaches to the 3pt top link? A U-Plate that you welded together? Just stick two pieces of steel plate in the cement? A pre-fabed U-Plate that you can buy? Do I need a certain tensile strength? What is the minimum thickness for the steel plate that I should use?
Obviously this is the first time I've built one of these and I want to make sure I get it right. I did search the Web in addition to TBN but I couldn't find anything about building one of these.
/ 55 Gal Rear Weight #2
I believe I'd pass a pipe through the bottom instead of a rod...that way the rod insert could be replaced if bent or snapped.
/ 55 Gal Rear Weight #3
You could use a draw bar. Relatively cheap, available, and that way you know it's strong enough and the right size. I'm using a Cat 2 bar with 26" spacing so that it fits right into my quick hitch without adapters. Got all the parts together just haven't gotten to it.
Tractor Supply Company - SpeeCo 3 Point Drawbar, Category 1
/ 55 Gal Rear Weight #4
Hey, don't forget to put some PVC pipe in so you can carry tools. I think that's one of the coolest features of the concrete-filled ballast...
/ 55 Gal Rear Weight #5
I made mine using a drawbar from TSC like KML suggested. I used a hole saw to cut the 2 round ends of the oblong holes on each side of the barrel and finished the cuts with a saws-all. Slide the bar in place and seal the gaps on the inside of the barrel with duct tape.
While I was at TSC, I grabbed a stabilizer bar, some 1/2" all-thread, nuts and washers. I cut the stabilizer bar in half, drilled 3 holes in each half for the all thread (4" from the factory hole, and then 2" and 6" in from the cut end). The all-thread was used to hold the bars evenly spaced, and by using 10" pieces in the lower holes it works as an anchor in the concrete. The factory hole was left to the top for the top link, and one 4" piece of all thread a few inches below that holds the bars properly spaced. On at least the top all-thread you'll need 4 nuts (one on each side of each bar) to sandwich it in place holding the exact spacing and providing strong support when in use. I kept the bars tilted forward at a slight angle, off center and towards the tractor side of the barrel a few inches too. I got the measurements for the pin placements from some of my other attachments.
I used the premade materials because it was easier and relatively inexpensive. I had the holes cut and brackets made in less than an hour. Then I hand mixed many many batches of concrete in a wheelbarrow using an assortment of leftover cement types I had laying around. I used gravel and sand from piles I had left from other projects too. The whole project was done and mess cleaned up by 11:00 a.m., and didn't cost much at all.
I almost forgot... If you use the factory hole in the stabilizer bar for the toplink like I did, it is too large for the head of a toplink pin. I add a washer to the pin so it doesn't slide through the hole.
/ 55 Gal Rear Weight #6
why not just use/make something similar to a '3pt carry all' and just fill the drum with water? (strapped to carry all)
that will give a multi-purpose setup that would have many uses.
1. carry all = a 3pt platform to transport a variety of items
2. 55 gal drum = many liquid uses. plastic drums recommended if spraying liquid fertilizers (corrosive) if a pto pump is in the future (55 x 8.3 = 456.5 lbs of water)
Rhett
/ 55 Gal Rear Weight #7
Can also mount the drawbar on the bottom so that it is not permanently part of the weight.. a couple long carriage bolts screwed into the bottom of the drum, sticking down, to line up with holes inthe drawbar.. once cemented in.. will hold good.. just slip the drawbar onto the 'studs' protruding fromt he bottom.. add nuts and washers and go.. later.. if you ever ditch the weight.. reclaim your drawbar.
soundguy
Thanks for the posted pic and the link. Like they say, a picture is worth a thousand words. Using a drawbar may be the way to go. Thanks.
I'm not sure if I am going to use a rod or a drawbar like KML suggested. If I do use a rod, putting a pipe in as you suggested is a great idea. Thanks.
Rhett
Great idea Rhett. I think I'll make a cement drum and a water drum. They would both be useful to have. I like the ability to vary the weight by how much water you would put in the barrel. That would be useful. Seems so obvious once you mentioned it.
/ 55 Gal Rear Weight #11
I made ballast out of an old weight-lifting bar and plates. I cut the bar to max width of 3pt, and welded drawpins on each end. I collected old weight plates at garage sales and people who got tired of working out. You have to use 45lb plates to really get a large ballast, 25lb plates will work if you don't need so much. It also gives you some flexibility if you ever want to take some of the ballast off. I leave it on the ground in the field, pick it up with 3pt when I need it.
Funny you should mention this, Mark. I was in WalMart (ugh!) the other night and looking at weights and thinking the very thing you are describing.
Thanks to everyone who responded. You each had some good input. Thanks.
Ford850,
Thanks for the detailed repsonse. It will come in handy.
/ 55 Gal Rear Weight #15
Why design it to fail... IF I used a pipe thru it.. it would be a 3" one big enough to accept a drawbar.. not a small one for a 'replaceable rod to sacrafice now and then...
soundguy
/ 55 Gal Rear Weight #16
And how big are the ends on the drawbar? Weakest link. I can't see wasting a drawbar when an inexpensive steel rod will do...his original plan was to cast the rod into the barrel. I merely suggested using a pipe instead cast into the barrel to allow one to replace the rod if needed
/ 55 Gal Rear Weight #17
I made the mistake of putting my pins in the center of the barrel, on each side. This left the barrel balanced with almost no weight on the the toplink. When I inadvertantly hit the draft control lever the barrel lifted all the way up & bent the toplink to a 90 degree angle. :eek: If I were to build another I'd put the pins in the front third of the barrel. Also put a flat plate out thru the back to bolt/weld/attach a hitch to. MikeD74T
/ 55 Gal Rear Weight #18
While the pin on the drawbar is the weakest part of it.. I've jet to have one break off lifting a load on my 3pt.. so I don't think we need to worry about that here.
'Wasting" a drawbar??? How are we wasting it? Either we slide it thru a chase pipe and use it.. or we bolt it to the bottom.. those were the options I posted.
In one case, you simply 'slide it out' to recover it.. in the other case, you run 2 nuts off of studs ont he bottom.. then recover it.
can't see how this constitutes waste????
( casting it solid into the body of the weight might constitute waste.. etc.. but i didn't suggest that ).. and if you are going to the trouble to cast a pipe into it to hold a rod that you believe will need replacing.... might as well just use a bigger pipe and then slide a drawbar thru.. and not worry about the?flimsy? rod that you were worrying about being replaceable.
soundguy
/ 55 Gal Rear Weight #19
Well excuse the **** out of me. I'm not worried about anything to do with this. The OP asked for suggestions and I gave him one. Did I attack your plan which came later? NO
Sorry it didn't meet your "much more expensive solution" standards :mad:
/ 55 Gal Rear Weight #20
I would say it wouldn't be 'wasted' if it were used , just another cost of materials for the project.Although myself would use some sort of scrap metal, and weld or bolt two new pins to it.
I don't believe there would be too much trouble anyways. I have a 55 gallon filled to the top, and used a piece of heavy angle iron to go on the bottom (in cement). On it I welded a bolt the diameter needed, and also slipped a tong of metal out the back for a trailer ball.
In my case I set the bottom about a third the way to center the barrel thus giving some weight to the rear so as to have weight pulling on the top link, I had to use a piece of PVC pipe for a form for the cement to create a "valley' for the top link to "reach' into in order to maintain the prober measurement .
. Been 10 years and no troubles. (knock on wood).
I did a search , as I thought I had seen these drawbars for about 15 dollars, but guess I was wrong.
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A64553)
2023 John Deere...
East Texas Gooseneck Trailer (A65563)
East Texas...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
Landhonor 8" Mini Excavator Bucket (A66285)
Landhonor 8" Mini...
