Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #231
Charlton John,
No, I don't think you will need the short receiver. It only seems like the BX series.
   / Pat's Easy Change System - Order Online! #232
Charlton John,
Thanks again Pat! Last question. If I decide on your product what is the best way to go about ordering it?
   / Pat's Easy Change System - Order Online! #233
Charlton John,
You do get a discount through the TBN store. TBN members get almost a $20.00 discount.
   / Pat's Easy Change System - Order Online! #234
Hey, pat, you have convinced me. Now, how to get a check to you for one and have it shipped? Currently do not have a credit card for online (relationship/name change) but am willing to let the check clear before shipping? Did not see this particular situation in other posts, but then i did not read them all. Cat 1 jd 4720
   / Pat's Easy Change System - Order Online! #235
Call him at [FONT=Book Antiqua, Times New Roman, Times]888-243-4204 He'll work with you on that
[/FONT]
   / Pat's Easy Change System - Order Online! #236
Hey Pat,
I just wanted to report that after 3 years of hard use on my big Kama, I've beat the crap out of your system. I've broken the "U" bolts and all the adjuster bolts that hold it tight to the lift arm. I've replaced them 2 times already and your system is still working. That's not a fault of your system though. I tilt my boxblade severely and stressed the He## out of it, so the little bolts popped off. I've left the adjuster bolts off this time and they're only held on with the large pins now. I have way more movement available that way. I think I've leave them like that. I can still hook up easily, which was why I bought them in the first place.
Do you see any problem doing that?
   / Pat's Easy Change System - Order Online! #238
Pat (or anyone else w/ expirence using these) I have been doing some research on my options for the easiest way to attach and take off my implements. I am fairly new to tractors so please bare w/ me. The example I have for you is this. This past weekend I was taking off my rake and putting on the box blade. When attempting to put the box blade on (which was on fairly level ground) I had to get off the tractor and and adjust my lift arms to fit the box blade pins. Now on my Kubota 2620 I can lower my right lift arm to bring it down to line up w/ the box blade but I cant do this on the left side. So once I got the right side lined up and on the pin I litterally had to lift the right side of this 500lb implement to get the height of the left side to also match and then bassiclly use my leg to push the pin through while I was holding this thing up in the air. I know there has to be an easier way and I am wondering how your system will help me w/ this scenerio. Thanks
   / Pat's Easy Change System - Order Online! #239
Charlton John,
All you have to do is line the hooks up and lift your arms and they hook. Now if you are a little off use the bumper on the top to help move the equipment instead of trying to push and pull it yourself. Check out the video at Agdeal features new and used farm equipment for sale such as tractors, combines, and attachments. just scroll down to Greenwell Mfg. Pat is out of town for the Sunbelt Ag Expo, but if you have any more questions let me know and I will get back with you.
Vicky
   / Pat's Easy Change System - Order Online! #240
Thanks Vicky, I did watch the video as you suggested which does help me understand the product more, thanks. Couple of questions, you mention in your reply to me "if a little off use the bumper on the top to help move the equipment instead of moving myself." What bumper are you refering too?
Also as mentioned in my original note my problem w/ being off was with the lower lift arms. When I removed my rake to install the box blade I had to move my one lower lift arm (right) a lot lower to match up to the BB pin but on the other side (left) I cant manually lower that arm like I have the option to do on the right so I was at the point of having the side I can manually lower hooked up but my other side arm was a lot higher than the pin (as I cant lower this anymore by hand) which led me to having to lift the other end of the BB to get the pin holes lined up. This could be a tractor issue I dodnt know. I hope I am not confussing you I am new to these toys (tractors) so I am learning as I go. I want to make these changes easier for me. Thanks
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
Drago Olimac 6R Corn Head (A59814)
Drago Olimac 6R...
Woods 1800 Batwing Mower (A59814)
Woods 1800 Batwing...
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
