Replacing middle buster point with subsoiler point
/ Replacing middle buster point with subsoiler point #1
queen of spades
Has anyone tried replacing the wide middle-buster shank with a narrow sub-soiler point? I need to break up a section of rock-hard red clay next weekend and hoped to save buying yet another attachment for this job alone.
thanks!
/ Replacing middle buster point with subsoiler point #2
thanks!
Not sure if this is the same application, but I purchased a 24" piece of 3/4" X 2 1/2" flat bar that I tooled and installed into my center scarifier hole on my box blade.
It did a good job of tearing up some heavy soil and tree roots so I could bury an electric line.
Good Luck C-YA RL
/ Replacing middle buster point with subsoiler point #3
Sure have, I swap between the middle buster shovel and a 2 1/2" wide subsoiler point regularly. Don't know the bolt arrangement on yours but mine takes most common points and sweeps for S-tine cultivators also. I haven't found a need for any of them but they do fit!
Hope this helps!
I'll try and snap a photo tonight. I'm not sure where to buy these points either. There aren't any TSC or farm equipment stores where I live.
/ Replacing middle buster point with subsoiler point #5
There are other places online but these folks have a good selection, good prices, and fast reasonable shipping. The search function is all but useless thought.
TILLAGE - Agri Supply
here it is
/ Replacing middle buster point with subsoiler point #7
I don't own a middle buster tip, but only have a subsoiler tip on mine. I used mine behind a 100 hp tractor ripping up an area I was clearing. Unfortunately I hit a buried rock and snapped the tip right off. My subsoiler was made in the 40's and parts aren't exactly available. I bought a couple of replacement scarifiers for a box scraper and used 3 3/4 grade 8 bolts bolting one on. (I didn't want to weld it on just in case it didn't work right)
The first time out I twisted that scarifier into a pretzel. An old farmer by me told me to take my good one, heat it up a bit with a rosebud torch and dip it in used motor oil; repeat several cycles. Now make sure you don't get too hot and that you have someone close with a fire extinguisher in case you start the used motor oil on fire. I did a couple of times, but it was a weak fire and easy to put out. Anyway, after a few cycles of doing that I hardened the cheap tip to the point where it worked great. He told me that what I did was a poor mans version of making high carbon hardened steel out of mild steel. I dunno, but it did work. Good luck!
/ Replacing middle buster point with subsoiler point #9
Try a cultivator point shank. I bought one from TSC and the holes matched.
I used plow bolts, again from TSC,to fasten the the shank point.
Easy! ;)
/ Replacing middle buster point with subsoiler point #10
thanks!
I have one of those KK middle buster/subsoiler combos from Tractor Supply.
I bought a sweep from Agri-Supply and it fits the KK frame no problem
Measure the hole pattern on your middlebuster frame and call Agri-Supply to see if they have a subsoiler that matches.
Agri Supply - Where we have Something for Everyone for your Farm Shop & Home
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
20' CONNEX BOX (A67714)
20' CONNEX BOX...
HYDREMA 912HM ARTICULATED DUMP TRUCK (A65056)
HYDREMA 912HM...
2016 WIRTGEN W150CFI MILLING MACHINE (A65056)
2016 WIRTGEN...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
