Thoughts on adaptability of sub-compacts
   / Thoughts on adaptability of sub-compacts #32
I have 300 lb on the front of my tractor and 200 gallon sprayer on the back. There is18.4x24 tires on the back. I try to float across the wet spots and so far it has worked but i come close in the marshes sometimes. If it gets bad I can back out so far. Maybe I am just lucky.
Renovator
   / Thoughts on adaptability of sub-compacts #33
Yeah, but from high school I remember that if A = B, and B = C, then A = C.
So therefore, if 2310 tractor = estate tractor, and if I own a 2310 tractor, then I own an estate. :D
Can't argue with science. :rolleyes:
Jay
Did you learn how to look up the word estate in the dictionary in High School? :eek:
   / Thoughts on adaptability of sub-compacts #34
I've heard that sayin' around here before...however the third part of saying isn't hoofs. Your granddad was being nice. plowking
King, the other version was for trouble...
   / Thoughts on adaptability of sub-compacts #35
I really like my GC2310, but:
1) low ground clearance
2) not a lot of power to the loader/backhoe
I feel the power to the loader and the buck are more than sufficient. In both cases the available amount of power is enough to exceed the rated limits of the tractor. Available power and ability, is as good as it gets in its class.
Keep in mind, if the machine has more power than the mechanics can handle, it is only going to break its self all the time. And, its light weight is going to limit its digging ability no matter how much power it has.
Make it heavier, and stronger, with more power, and more ground clearance, then it's no longer a subcompact.
   / Thoughts on adaptability of sub-compacts #36
Not necessary, since I have read a book or two over the past 50+ years. But if there's lingering confusion, here's a definition brought to you by the nice folks at dictionary.com that seems to fit:
es·tate
-noun
1. a piece of landed property, esp. one of large extent with an elaborate house on it: to have an estate in the country.
When I leave my estate in the AM to go to work, I'll be sure to enjoy how my property and elaborate house have benefited from my little red tractor.
:D
Jay
   / Thoughts on adaptability of sub-compacts #37
es??キtate
-noun
:D
Jay
Ok, heres another word for you:
delusion
de-lu-sion, noun, A delusion is an unshakable belief in something untrue. :cool:
   / Thoughts on adaptability of sub-compacts #38
delusion
Sorry, but I'm too busy this morning surveying my vast property and elaborate house in the country to provide a more detailed response to your latest vocabulary offering.
Maybe later.
Maybe not.
:cool:
Jay
   / Thoughts on adaptability of sub-compacts #39
I own an "estate"? Wow, that's awesome! :cool:
Hey Honey, look at this....says right here on the TBN that we have an "estate".
Better get out the good plastic dinnerware, open up an extra can of brown bread, and invite the neighbors over for an "estate" party.
:D :D
Jay
Sure you have an estate. I have an estate, too. They will be settled when we croak. ;)
   / Thoughts on adaptability of sub-compacts #40
Jay
Logical falacy.. might want to check a conversational logic course, and a statistics math couse and see how those two things reconcile..
a= estate tractor does not mean that the tractor cannot have other titles.. IE.. draw 3 circles.. overlap 1 with 2, and 2 with 3, so that 2 is common to both, but 1 and 3 are not common.. 2 shares comonalities with 1 and 3.. but 1 and 3 do not share comonalities.. ..
soundguy
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
ASSET DESCRIPTIONS & CONDITION (A59575)
ASSET DESCRIPTIONS...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59575)
2007 FREIGHTLINER...
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
